Sign in to follow this
Relay G30/G50/G90 Device Firmware 2.0 Update
German instructions: Deutsche Ãœbersetzung ist unter
French instructions: Traduction française est ci-dessous
Relay G30/G50/G90 Device Firmware 2.0 Update Release Notes
This release is recommended for all G30/G50/G90 system owners who desire compatibility with Line 6's RF2 mode products. The benefits of RF2 mode on the G30/G50/G90 are as follows:
  • Less impact on other devices operating in 2.4GHz space
  • Compatibility with other RF2 devices such as the XD-V75, XD-V55 and XD-V35
NOTE: An XD-V75 Receiver is required in order to perform this upgrade. If you cannot access an XD-V75 Receiver via a friend or retailer, please contact Line 6 Customer Service for assistance. TBP12 transmitters must currently be loaded with firmware v1.03 or greater to upgrade via Monkey. If your TBP12 has an earlier version firmware installed, it will need to be returned to Line 6 for upgrading.
How to determine the currently installed firmware version:
  • Relay G30 Bodypack
  • Slide the Channel Switch to channel 1, then turn on the Relay G30 Bodypack.
  • Wait for the LEDs to settle, then immediately switch the Channel Switch from 1 to 6, then back to 1 three times (1->6->1->6->1->6->1).
  • The AUDIO LED will blink the version number - Green for the major number, and Red for the minor number, i.e. 1 green blink, 2 red blinks indicate v1.02).
Instructions for updating the Relay G30/G50/G90 Receivers:
  • Obtain an XD-V75 Receiver
  • Connect the XD-V75 Receiver to your PC or Mac using a USB cable
  • Disconnect, then reconnect the DC power plug for the XD-V75. "Loader Enabled" should be displayed.
  • Connect the XD-V75 Receiver to the G30/G50/G90 Receiver by using a cable with TRS to TRS (stereo) 1/4 inch phone plugs on either end. The cable should plug into the 1/4 inch audio output of both the XD-V75 and the G30/G50/G90 Receivers
  • Launch Line 6 Monkey, then Log In, then select "Relay G30/G50/G90 Receiver" as your device and follow the on screen instructions
Instructions for updating the Relay G30/G50/G90 Transmitters:
  • Launch Line 6 Monkey, then Log In, then select "Relay G30 Transmitter (1.0)" as your device and follow the on screen instructions.
  • If Line 6 Monkey is not able to connect to the Transmitter, select "Relay G30 (or G50/G90 depending on your system) Transmitter" as your device and follow the on screen instructions.
  • NOTE: G30 Transmitter owners with firmware version 1.0 should select "Relay G30 Transmitter (1.0)" in Line 6 Monkey in order to connect to the transmitter. G30 Transmitters with firmware 1.01 or later should select "Relay G30 Transmitter" in Line 6 Monkey.
***Transmitter Updaters: please use this Device Positioning document for visual reference on how to place the Transmitter to the XD-V75 Receiver for optimal data communication: http://line6.com/support/page/kb/_/live-sound/relay-digital-wireless/device-positioning-for-updating-transmitters-an-r77
Die neue Firmware V2.0 wird allen Nutzern empfohlen die eine Kompatibilität zwischen G30/G50/G90-Systemen und RF2-Modus-Produkten von Line 6 gewährleisten wollen. Die Vorteile des RF2-Modus sind folgende:
  • Weniger Einfluss auf andere Geräte, die im 2,4 GHz-Bereich arbeiten
  • Kompatibilität mit anderen RF2-Geräten wie XD-V75, XD-V55 und XD-V35
Bitte beachten Sie:
Für diese Aktualisierung brauchen Sie einen XD-V75 Empfänger. Wenn Sie keinen Zugriff auf einen XD-V75 Empfänger über einen Händler oder Bekannten haben dann nehmen Sie Verbindung mit dem Line6 Kundendienst auf. TBP12-Sender müssen zur Zeit mindestens die Firmware V1.03 aufgespielt haben, damit sie über Monkey aktualisiert werden können. Wenn Ihr TBP12 eine frühere Firmwareversion hat, müssen Sie es zur Aktualisierung an Line 6 schicken.
Anleitung zur Aktualisierung des Relay G30/G50/G90- Empfängers:
  • Besorgen Sie sich einen XD-V75- Empfänger
  • Verbinden Sie den XD-V75- Empfänger per USB-Kabel mit ihrem PC oder Mac
  • Verwenden Sie ein Kabel dass Stereo-Klinken-Stecker auf beiden Seiten des Kabels aufweist um den XD-V75- Empfänger mit dem G30/G50/G90-Empfänger zu verbinden.
  • Schalten Sie beide Geräte ein.
  • Trennen Sie den Netzstecker vom XD-V75 und verbinden Sie Ihn wieder.
  • Auf dem Display des XD-V75 erscheint ‚‘‘ Loader enabled‘‘.
  • Starten Sie Line 6 Monkey und verbinden sich mit Ihren Benutzerdaten und wählen
  • "Relay G30/G50/G90-Receiver" als Gerät aus.
  • Trennen Sie nun den Netzstecker vom G30/G50/G90 Empfänger und klicken auf ‚‘‘OK‘‘ in Monkey.
  • Die Nachricht ‚‘‘ Preparing Receiver erscheint auf dem Bildschirm.
  • Auf dem Display des XD-V75 erscheint ‚‘‘ Programming MCU‘‘
  • Das nächste Fenster fordert Sie auf den Netzstecker wieder mit dem G30/G50G90 zu verbinden.
  • Im Aktualiesierungsfenster von Monkey das nun erscheint wählen Sie ‚‘‘ FLASH MEMORY‘‘ und klicken auf ‚‘‘ UPDATE SELECTION‘‘.
  • Akzeptieren Sie die Lizenzbedingungen und klicken auf ‚‘‘ OK‘‘.
  • Das nächste Fenster weist Sie darauf hin dass die Aktualisierung vorgenommen wird, klicken Sie auf ‚‘‘ YES‘‘.
  • Der Fortschritt der Aktualisierung wird im Dispaly des XD-V75 angezeigt und kann einige Minuten dauern.
  • Wenn die Aktualisierung abgeschlossen ist bekommen Sie die Meldung von Monkey ‚‘‘Receiver update successful‘‘.
  • Trennen Sie nun den Netzstecker vom G30/G50G90 und verbinden Sie Ihn wieder und schalten den Empfänger ein.
  • Trennen Sie den Netzstecker vom XD-V75.
Anleitung zur Aktualisierung des Relay G30/G50/G90-Senders:
  • Besorgen Sie sich einen XD-V75-Empfänger
  • Verbinden Sie den XD-V75-Empfänger per USB-Kabel mit ihrem PC oder Mac
  • Verbinden Sie eine einzelne Antenne mit dem Antennenausgang B OUT.
  • Positionieren Sie Ihren eingeschalteten Sender ( RELAY) wie unter folgendem link ( *** ) aufgezeigt über der Antenne.
  • Starten Sie Line 6 Monkey und verbinden sich mit Ihren Benutzerdaten.
  • Wählen Sie Ihr Bodypack "Relay G30/G50/G90 Bodypack" als Gerät aus.
  • Drücken und halten Sie den ‚‘‘ VALUE ‚‘‘ Schalter und schieben den ‚‘‘ON/OFF‘‘ Schalter in die OFF Position.
  • Während Sie den ‚‘VALUE‘‘ Schalter gedrückt halten drücken Sie die ‚‘‘ SELECT‘‘ Taste 8 mal bis das Zeichen ‚‘‘ LOADER‘‘ auf dem Display erscheint.
  • Klicken Sie auf ‚‘‘OK‘‘ in Monkey.
  • Eine Verbindung zum Bodypack wird aufgebaut, sollte die Verbindung nicht zustandekommen wird ein Fenster geöffnet dass Sie darauf hinweist.
( In diesem Fall einfach das Bodypack repositionieren bis sich die Nachricht von alleine schliesst)
  • Wählen Sie ‚‘‘ FLASH MEMORY‘‘ und klicken auf ‚‘‘ INSTALL UPDATE‘‘.
  • Um die Aktualiesierung zu starten klicken Sie auf ‚‘‘ YES‘‘ im folgenden Fenster.
  • Auf dem Display des XD-V75 erscheint ‚‘‘ Programming MCU‘‘.
  • Die Aktualiesierung kann einige Minuten dauern.
  • Nachdem die Aktualisierung abgeschlossen ist schalten Sie den Bodypack ein währen Sie die ‚‘‘SELECT‘‘ Taste gedrückt halten, das Display zeigt Ihnen nun die neue Versionsnummer an.
### Wenn Line 6 Monkey sich nicht mit dem Sender verbinden kann, wählen Sie „Relay G30 Transmitter“ (oder G50/G90 je nachdem, welches System Sie benutzen) als Gerät aus.
HINWEIS: Wenn Sie einen G30-Sender mit der Firmware-Version 1.0 benutzen, wählen Sie im Line 6 Monkey „Relay G30-Transmitter (1.0)“ als Gerät aus, um Monkey mit dem Sender zu verbinden. Bei G30 Sendern mit der Firmware-Version 1.01 oder höher wählen stattdessen „Relay G30-Transmitter“.
***Wenn Sie einen Sender aktualisieren:
Bitte nutzen Sie diesen Link Visuelle Referenz ,
in dem visuell dargestellt wird, wie Sie Sender und Empfänger platzieren müssen, um eine optimale Datenübertragung zu gewährleisten.
Relay G30/G50/G90 mis à jour version 2.0
Cette mise à jour est recommandé pour tous les propriétaires de systèmes G30/G50/G90 qui désirent la compatibilité avec les produits Line 6 qui fonctionnent en mode RF2.
Voici les avantages de RF2 mode sur le G30/G50/G90 :
- Moins d'impact sur d'autres appareils fonctionnant dans le réseau 2,4 GHz
- Compatibilité avec les autres appareils RF2 comme les XD-V75,V55 et XD-XD-35
REMARQUE: Un récepteur XD-V75 est requis pour effectuer cette mise à jour.
Si vous ne pouvez pas accéder à un récepteur XD-V75 par un ami ou revendeur, veuillez contacter le Service clientèle de Line 6 pour vous assister.
Les émetteurs TBP12 doivent avoir le firmware v1.03 ou plus pour pouvoir les mettre à jour avec le logiciel Line6 monkey.
Si votre TBP12 est muni d'une version du firmware antérieure à 1.03 , l'appareil doit être retourné chez Line 6 pour la mise à jour,
veuillez alors contacter le Service clientèle de Line 6.
Instructions pour la mise à jour des Récepteurs RELAY G30/G50/G90 :
  • Procurez-vous un récepteur XD-V75.
  • Connectez le récepteur XD-V75 à votre PC ou Mac à l'aide d'un câble USB.
  • Branchez le récepteur XD-V75 au récepteur G30/G50/G90 en utilisant un câble jack TRS vers TRS (stéréo).Le câble jack stéréo doit être branché entre les sorties jack audio du XD-V75 et du récepteur G30/G50/G90.
  • Allumez les récepteurs
  • Débranchez, puis rebranchez le câble d'alimentation du récepteur XD-V75.
  • Le message ‘’ LOADER ENABLED’’apparaît sur l'affichage du XD-V75.
  • Lancez Line 6 Monkey, puis connectez-vous avec votre nom d'utilisateur et mot de passe, sélectionnez votre récepteur "Relay G30/G50/G90 Receiver" comme dans l’image ci-dessous.
  • Déconnectez le câble d'alimentation du récepteur G30/G50/G90.
  • Cliquez sur OK .
  • Le message ‘’ Preparing Receiver’’ apparaît sur l'ecran.
  • Sur l'écran du XD-V75, vous verrez le message ‘’ Programming MCU’’
  • Le message suivant vous indique de rebranchez le câble d'alimentation du récepteur G30/G50/G90.
  • Accepter le contrat de licence et cliquez sur ‘’OK’’
  • Cliquez sur ‘’ Yes’’ dans la fenêtre suivante.
  • L'état d'avancement de la mise à jour peut être vu sur l'écran du XD-V75 et peut prendre quelques minutes.
  • Le message ‘’ Receiver update successful’’ sera affiché lorsque la mise à jour est terminée.
  • Débranchez, puis rebranchez le câble d'alimentation du récepteur G30/G50/G90.
  • Débranchez le câble d'alimentation du récepteur XD-V75.
  • La mise à jour et complet.
Instructions pour la mise à jour des transmetteurs RELAY G30/G50/G90 :
  • Connectez une seule antenne à la sortie B OUT
  • Positionnez votre transmetteur RELAY comme indiqué dans le lien suivant (***).
  • Lancez Line 6 Monkey, puis connectez-vous avec votre nom d'utilisateur et mot de passé.
  • Sélectionnez votre émetteur "Relay G30/G50/G90 Bodypack ".
  • Tout en cliquant et en maintenant le commutateur ‘’VALUE’’ déplacer le commutateur ‘’ON/OFF’’ à la position ‘’OFF’’ et cliquer 8 fois sur le bouton ‘’ SELECT’’.
  • Vous devriez maintenant voir le message ‘’LOADER’’ sur l'écran du émetteur.
  • Cliquez sur OK dans Monkey.
  • Une connexion avec l'
(Si vous recevez un message sur l'écran que la connexion a échoué, il suffit de repositionner le émetteur jusqu'à ce message disparait).
  • Choisissez Flash memory et cliquez "Update Selection" pour démarrer la mise à jour.
  • Allumez le emetteur tout en maintenant ‘’SELECT’’après la mise à jour est terminée, l'écran vous montrera le nouveau numéro de version
  • Déconnectez le câble d'alimentation du récepteur XD-V75.
REMARQUE: Si votre émetteur G30 n’est pas reconnu par Monkey,
essayez s.v.p. de choisir « Relay G30 Bodypack (1.0) » (firmware 1.0) dans Line 6 Monkey afin de vous connecter à l'émetteur. Pour vous connecter aux transmetteurs avec le firmware 1.01 ou ultérieurs, vous devez sélectionner « Relay G30 Bodypack » dans Line 6 Monkey.
***Si vous mettez à niveau un émetteur: S'il vous plaît utilisez le lien Référence visuelle pour une référence visuelle sur la façon de placer l'émetteur au récepteur XD-V75 pour une communication de données optimale.
