Relay G50/G55/G90 Series FAQs
  • https://line6.com/media/ips/uploads/monthly_10_2013/ccs-1582879-0-20166200-1381432799.png
Deutsch
Français
Q: Can I use multiple transmitters with 1 receiver?
A: Yes, you can use multiple transmitters with 1 receiver, however not at the same time on the same channel. The best practice for that type of usage is to have Transmitter A on channel 1 and Transmitter B on channel 2. Then switching the channel on your receiver from channel 1 to channel 2 will toggle which transmitter you will be hearing. You can do this with as many receivers as you have channels, provided each transmitter is on a different channel and you change the channel on your receiver accordingly. You can also set multiple transmitters to one channel, and turn them all off except for the one you'd be using. This way, when you switch instruments, you'd turn off transmitter A on the first instrument, then pick up the next instrument and turn on transmitter B. Just be sure that no one else using a Line 6 wireless system is using the same channel.
Suggested channels settings to avoid interfering with Wi-Fi.
If your wifi network utilizes the channel listed, use the channel # listed under the Line 6 wireless channel column.
Q: Are all Line 6 wireless transmitters and receivers interchangable?
A: Yes, any Line 6 brand wireless transmitter or microphone will work with any Line 6 receiver. It does not matter if they are XD-V or Relay systems, you can mix and match receivers with transmitters and they will work as long as the transmitter and receiver correspond to the same channel.
Q: Is the Relay G5/G90 transmitter compatible with the X2 receiver (or vice versa)?
A: Both systems run in completely different frequency ranges, so they are not interchangeable. However, the X2 and Relay units can be used on the same stage (along with any other analog wireless systems) with no problems.
Q: Where do I get a Relay G50/G90 Series Wireless System?
A: The Relay G50/G90 wireless units are available at all authorized Line 6 dealers. To locate a dealer near you, please see the Line 6 Dealer Finder: Line 6 Dealer Finder
Q: Where can I purchase replacement Relay G50 transmitters (TBP12) or receivers (RXS12)?
A: Individual transmitters and receivers can be ordered from any Line 6 dealer.
Q: What are the specs on the provided Relay G50 Series power supply?
A: 9V DC, 500mA, center pin negative (2.1mm). See the following link for more power supply FAQs: Power Supply and Amp Power F.A.Q.
Q: How is the Relay G90 receiver powered?
A: The Relay G90 uses a standard IEC power cable.
Q: Can I use a Voodoo Lab Pedal Power Plus 2 to power the Relay G50 receiver?
A: Yes, but you will need to use the Voodoo lab "current doubler" cable and you will need to use outputs 5 & 6 of the Pedal Power Plus away from "normal" position. VooDoo model PPAP.
Q: What type of cable do I need between my guitar & Relay TBP12 transmitter?
A: The Relay G50/G90 Transmitter (TBP12) uses a TA4F to 1/4" cable.
Q: What is the pin-out for wiring to a TA4F connector?
A:
Pin 1 - Gnd
Pin 2 - V+
Pin 3 - Signal
Pin 4 - Z (leave open for instrument)(short to pin 3 for mic)
For a normal, everyday, run-of-the-mill, Tip/Sleeve (TS) connector for a 1/4" instrument cable end,... the signal goes from 1/4" Tip to TA4F pin-3 (Signal), and 1/4" Sleeve goes to TA4F pin-1 (Gnd). Don’t worry about pins 2 and 4, those are used for Lavaliere Mic connections.
Q: How many channels does the G50/G90 have?? Do they share channels with the G30 system?
A: The G50/G90 have 12 channels, which share the first 6 channels with the G30.
Q: Can I use the TBP12 from a G50 to transmit to a G90 or G30 (or vice versa?)
A: Yes. All 2.4gHz Line 6 transmitters work with all Line 6 2.4gHz receivers to the lowest limitation, channel count, features, etc.
Q: What type of antennas work with the G50 and G90?
G50: 1/4 wave antennas, BNC-type connectors; detachable.
G90: 1/2 wave antennas. The antennas can be detached but RG58-50 ohm radio wire connection is required. Be sure the antennas are not inside a metal case or touching any metal and get your antennas as high as possible.
Q: How long does the pair of AA batteries in the transmitter typically last?
A: 8 hours on high power & 11 hours on low power. If you leave the transmitter cable plugged but turn the power off on the transmitter, there is no battery draw.
Q: How does the battery meter work?
A: The battery meter displays 20 minute increments. Be aware of "alkaline rebound" when turning off the unit and turning it back on, as it may look like it has more power than it really has.
Q: Can I use rechargeable batteries?
A: Yes, but the hours and minutes are calibrated to alkaline batteries so the power reading may be inaccurate. Some rechargables while labeled AA are not true AA size and will not work.
Q: What is the difference between the main output and the tuner output?
A: The only difference is the tuner output still works when the transmitter is muted.
Q: What is different about the Relay G50/G90 system compared to the X2 series?
A: The Relay system works on a higher frequency (2.4 Ghz) and operates on 12 channels rather than 5.
Q: Can the RXR12 Receiver antennas be linked together?
A: Up to 6 receivers can be daisy-chained together. The last unit in the chain should be "terminated" when linking receivers together.
Q: I'm a harmonica player and would like to use the G30 with a bullet microphone (high impedance and high output). Its output peaks at approximately 3V to 4V. Will there be clipping or distortion of the output?
A: No problem with either impedance or input level. The Relay transmitters (TBP06 and TBP12) will handle 6V inputs.
Q: What does the red audio LED mean on the G50 receiver?
A: It means the incoming signal is clipping. This will not produce an audio dropout unless the red LED is on for a few seconds. This state will not damage the receiver.
Q: How do I register my Relay G50/G90 System?
Line 6 Product Registration F.A.Q.
Q: What do the different colors states mean on the TBP12 transmitter?
TBP12 LED States:
Blue LED = full
Solid red LED = Low
Flashing red LED = Very Low / Change batteries
Audio LED - Green LED = Audio Signal
F.A.Q. zur Relay G50/G90 Serie
Kann ich mehrere Sender mit einem Empfänger verwenden?
Ja, aber nicht gleichzeitig auf den selben Kanälen. Für diese Nutzung schalten Sie am besten Sender A auf Kanal 1 und Sender B auf Kanal 2. Wenn Sie dann auf dem Empfänger von Kanal 1 auf 2 wechseln, wechseln Sie den Sender, den Sie hören. Sie können das mit sovielen Empfängern machen, wie Sie Kanäle zur Verfügung haben, solange Sie die Sender alle auf verschiedenen Kanälen haben und den Kanal des Empfängers demnach anpassen. Sie können auch mehrere Sender auf den selben Kanal stellen und dann alle abschalten, mit Ausnahme von dem, den Sie verwenden möchten. So können Sie Instrumente wechseln indem Sie einfach den Sender des Instrumentes A abschalten und einfach den Sender des Instrumentes B einschalten. Stellen Sie aber sicher, dass keine anderen ein Line 6 Wireless System im selben Kanal wie Sie verwenden.
USB 3.0 Computerkabel und –geräte sind dafür bekannt Interferenzen bei Radio Frequenzen im 2,4GHz Bereich zu erzeugen was zu verringerter Reichweite und Performance für alle 2.4GHz Geräte (inklusive kabellose Tastatur oder Maus sowie WiFi und viele andere) in der Nähe führen kann. Wir empfehlen alle digitalen Kabellosempfänger mindestens 2m von den USB 3.0 Geräten und deren Verkablung weit weg zu plazieren.
Sind alle Line 6 Wireless Sender untereinander austauschbar?
Ja, alle kabellosen Line 6 Sender oder Mikrofone funktionieren mit jedem Line 6 Empfänger. Es macht keinen Unterschied ob diese XD-V oder Relay Systeme sind. Sie können Empfänger und Sender mischen wie Sie wollen und dies wird funktionieren solange Sender und Empfänger den gleichen Kanal haben.
Ist der Relay G50/G90 Sender kompatibel mit dem X2 Empfänger? (oder andersrum)
Beide Systeme laufen auf vollkommen unterschiedlichen Frequenzbereichen und sind somit nicht kompatibel. Sie können jedoch zusammen auf der selben Bühne verwendet werden. (zusammen mit anderen analogen, kabellosen Systemen)
Woher bekomme ich ein Relay G50/G90 System?
Die Relay G50 und G90 Systeme sind bei allen autorisierten Line 6 Händlern erhältlich. Um einen Händler in Ihrer Nähe zu finden, klicken Sie folgenden Link an: Line 6 Dealer Finder
Wo kann ich Relay G50 Ersatzsender (TBP12) und –empfänger (RXS12) kaufen?
Einzelne Sender oder Empfänger können Sie bei Ihrem Line 6 Händler bestellen.
Was sind die technischen Daten des Netzteils für die Relay G50 Serie?
9V Gleichstrom, 500mA, negativer Zentralpin (2.1mm). Klicken Sie folgen Link um weitere Informationen bezüglich Netzteilen zu erhalten:
Wie sieht die Stromversorgung des G90 Empfängers aus?
Das Relay G90 benutzt ein standart IEC Stromkabel.
Kann ich ein Voodoo Lab Pedal Power Plus 2 benutzten um den Relay G50 Empfänger zu betreiben?
Ja, aber dazu brauchen Sie ein Voodoo Lab "doubler" Kabel und Sie müssen die Ausgänge 5 und 6 des Pedal Power Plus verwenden, die auf "normal" eingestellt sind. Klicken Sie auf den folgenden Link um mehr Informationen über "doubler" Kabbel von Voodoo Labs zu erhalten:
Voodoo Lab Kabel
Welche Art Kabel brauche ich für die Verbindung zwischen Gitarre und Relay TBP12 Sender?
Der Relay G50/G90 Sender (TBP12) verwendet ein TA4f zu ¼" (6.35mm) Kabel.
Wie sieht die Pinbelegung für einen TA4F Stecker aus?
Pin 1: Masse.
Pin 2: Postiv.
Pin 3: Signal.
Pin 4: Z (Nicht anschließen bei Instrument) (Kurzschließen mit Pin 3 für Mikrofon)
Wieviele Kanäle hat das G50/G90? Teilen sie sich Kanäle mit dem G30 System?
Die G50/G90 Systeme haben 12 Kanäle und sie teilen sich die ersten 6 mit dem G30.
Kann ich das TBP12 eines G50 verwenden um an einen G90 oder G30 zu senden? (oder andersrum?)
Ja. Alle 2.4GHz Line 6 Sender funtionieren mit 2.4GHz Line 6 Empfängern.
Welche Antennen funktionieren mit den G50 und G90?
  • G50: Viertelwellen-Antennen, BNC Stecker; abnehmbar.
  • G90: Halbwellen-Antennen. Die Antennen könne abgenommen werden, dann ist aber eine RG58-50Ohm Funkverkablung notwendig.
Stellen Sie sicher, dass die Antennen sich nicht innerhalb einer Metallkiste befinden oder Metall berühren. Stellen Sie die Antennen imemr so hoch wie möglich auf.
Wie lange hält ein Paar AA Batterien in einem Sender?
8 Stunden auf High Power und 11 Stunden auf Low Power Einstellung. Wenn Sie das Kabel des Senders stecken lassen während der Sender ausgeschaltet ist, dann wird kein Strom verbraucht.
Wie funktioniert die Batterieanzeige?
Die Batterieanzeige aktualisiert in 20 Minuten-Intervallen. Achtung bei Alkaline Batterien kann es sein, dass Ihnen eine falsche batteriemenge angezigt wird nachdem Sie das Gerät abgeschaltet haben und wieder einschalten. Dies ist ein bekanntes Problem mit Alkaline Batterien.
Kann ich aufladbare Batterien verwenden?
Ja, aber die Stunden/Minuten-Anzeige ist für Alkaline Batterien konfiguriert und wird so ungenau. Manche aufladbaren Batterien, auf denen AA steht sind nicht in Wirklichkeit AA Batterien und passen somit nicht.
Was ist der Unterschied zwischen Main Ausgang und Tuner Ausgang?
Der einzige Unterschied ist, dass der Tuner Ausgang auch dann weiterläuft, wenn der Sender stumm geschaltet ist.
Was ist der Unterschied zwischen G50/G90 und X2 Serie?
Das Relay System läuft auf höherer Frequenz (2.4GHz) und 12 Kanälen anstelle von 5.
Können RXR12 Empfänger Antennen verbunden werden?
Ja, bis zu 6 Empfänger können in eine Kette geschaltet werden. Die letzte Einheit der Kette muss einen Abschlusswiderstand angeschlossen haben.
Ich bin ein Harmonikaspieler und würde gerne das G50 mit einem Kugelmikrofon benutzen (hohe Impedanz und Ausgang). Der Ausgang befindet sich da höchstens bei ca. 3V oder 4V. Wird dies zu Übersteuerung oder Verzerrung am Asugang führen?
Nein, weder Impadanz noch Eingangspegel sind hier ein Problem. Die Relay Transmitter (TBP06 und TBP12) kommen mit Eingängen von bis zu 6V klar.
Wie kann ich mein G50/G90 System registrieren?
Was bedeuten die verschiedenen LED Zustände des TBP12?
Blaues LED: Batterie voll.
Durchgehend leuchtendes rotes LED: Batterie schwach.
Blinkendes rotes LED: Batterie fast leer, bitte ersetzen.
Audio LED – Grünes LED: Audio Signal vorhanden.
F.A.Q.: Les séries Relay G50 et G90
Est-ce que je peux utiliser plusieurs émetteurs avec 1 récepteur?
Oui, mais vous ne les pouvez pas utiliser en même temps sur le même canal. Le plus simple est de mettre transmetteur A sur canal 1 et transmetteur B sur canal 2. Si vous changez le canal sur le récepteur, de canal 1 sur canal 2, ca aussi change quel transmetteur vous pouvez entendre. Vous pouvez faire ca avec autant de récepteurs que vous avez canaux. Chaque transmetteur doit avoir un canal différent et vous changez le canal sur l'émetteur. Vous pouvez également mettre plusieurs transmetteurs sur le même canal et éteindre tous sauf pour l'un que vous voulez utiliser. Comme-ca, si vous changez les instruments, vous pouvez éteindre transmetteur A sur le premier instrument et allumer le transmetteur B du deuxième instrument. Attention, vérifiez que personne n'est en train d'utiliser des appareils Line 6 sur le même canal que vous.
Est-ce que tous les transmetteurs et émetteurs Line 6 sans fil sont interchangeables?
Oui, tous les transmetteurs et microphones sans fil de Line 6 fonctionnent avec des récepteurs Line 6. Si vous utilisez des systèmes XD-V or Relay, ce n'est aucun problème. Vous pouvez mélanger tous les récepteurs avec les transmetteurs et ca fonctionne à condition qu'ils correspondent au même canal.
Est-ce que le transmetteur Relay G50/G90 est compatible avec le récepteur X2 (ou inversement)?
Les deux systèmes travaillent en différents gammes de fréquence, donc ils ne sont pas interchangeables. Les appareils X2 et Relay peuvent être utilisés sur la même scène sans problème. (Ainsi que tous les autres systèmes sans fil analogiques)
Où est-ce que je peux acheter les systèmes sans fil G50/G90?
Vous les pouvez commander de n'importe quel distributeur autorisé.
Où est-ce que je peux acheter des transmetteurs G50 (TBP12) ou récepteurs (RXS12) de remplacement?
Transmetteurs et récepteurs individuels peuvent être commandés à partir de n'importe quel revendeur Line 6.
Quels sont les spécifications d'alimentation Relay G50?
9V CC, 500mA, pin central négatif (2.1mm). Visitez le lien suivant pour plus d'informations concernant les alimentations:
Comment est-ce que le récepteur G90 est allumé?
Le Relay utilise un câble d'alimentation standard IEC.
Est-ce que je peux utiliser un Voodoo Lab Pedal Power Plus 2 pour allumer le récepteur Relay G30?
Oui mais vous devez utiliser le câble Voodoo Lab "doubler" et les deux sorties 5 et 6 du Pedal Power Plus sur la position "normal". Visitez le lien suivant pour plus d'informations sur les câbles "doubler" disponibles de Voodoo Lab:
Câbles Voodoo Lab
Quel câble est-ce que j'ai besoin pour la connexion guitar – transmetteur Relay TBP12?
Le transmetteur Relay G50/G90 (TBP12) utilise un câble TA4f à ¼" (6.35mm).
Quelle est le brochage pour câbler le connecteur TA4F?
  • Broche 1 – Terre.
  • Broche 2 – V+
  • Broche 3 – Signal
  • Broche 4 – Z (laissez ouvert pour l'instrument)(court avec broche 3 pour connexion avec mirco)
Combien de canaux est-ce que le G50/G90 a? Est-ce qu'ils partagent les canaux avec le système G30?
Les G50/G90 ont 12 canaux et partagent les premières 6 avec le G30.
Est-ce que je peux utiliser le TBP12 du G50 pour transmettre à un G90 ou G30? (ou inversement?)
Oui, tous les transmetteurs Line 6 2.4GHz fonctionnent avec tous les récepteurs Line 6 2.4GHz.
Quelles antennes fonctionnent avec le G50 et G90?
  • G50: Antennes quart d'onde, connecteurs BNC détachables.
  • G90: Antennes demi-onde. Les antennes peuvent-êtres détachés mais une connexion RG58-50 Ohm est nécessaire.
Assurez-vous que les antennes ne sont pas dans un boîtier métallique ou touchent un métal. Mettez les antennes le plus haut possible.
Combien de temps dure la paire de piles AA dans l'émetteur?
8 heures sur configuration "High Power" et 11 heures sur "Low Power". Si vous laissez le câble branché mais vous éteignez l'émetteur, il n'ya pas de vidange de la batterie.
Comment est-ce que la jauge de batterie fonctionne?
La jauge de batterie affiche des incréments de 20 minutes. Parfois, la jauge peut vous indiquer plus de batterie qu'en réalité disponible. C'est un problème connu avec les batteries alcalines.
Est-ce que je peux utiliser des batteries rechargeables?
Oui, mais les heurs et minutes sont calculés à partir des batteries alcalines, donc peuvent êtres inexactes. Quelques batteries rechargeables Certains rechargeables tandis étiquetées AA ne sont pas vraies AA et ne fonctionneront pas.
Quelle est la différence entre la sortie Main et la sortie Tuner?
La sortie Tuner fonctionne si le transmetteur est mis en sourdine.
Quelle est la différence entre les systèmes G50/G90 et la série X2?
Le Relay fonctionne sur la fréquence plus haute de 2.4GHz avec 12 canaux plutôt que 5.
Est-ce que les antennes de récepteur RXR12 peuvent-être reliées?
Jusqu'à 6 récepteurs peuvent être chaînés. Le dernier appareil dans la chaîne doit être "terminé" si vous relies les récepteurs.
Je suis un harmoniciste et je voudrais bien utiliser le G50/G90 avec un micro harmonica (impédance et sorite haute). Sortie d'environ 3V à 4V. Est qu'il y aura du clipping ou de la distorsion du signal de sortie?
Pas de problème ni avec l'impédance ou niveau d'entrée. Les transmetteurs Relay (TBP12) peuvent traiter des entrées de 6V.
Comment est-ce que je peux enregistrer mon système Relay G30?
Vous le pouvez enregistrer ici: Enregistrement Line 6.
États LED:
TBP12:
LED Bleu: Batterie pleine.
LED Rouge continu: Batterie faible.
LED Rouge clignotant: Batterie très faible, changez la batterie.
Audio LED: Vert: Signal audio.
