Sign in to follow this
Relay G55 FAQ
  • https://line6.com/media/ips/uploads/monthly_06_2016/ccs-411956-0-42754100-1466463084.png,monthly_06_2016/ccs-411956-0-76371000-1466463874.png,monthly_06_2016/ccs-411956-0-99353100-1466467291.png
Français
Deutsch
Q: What is the cable tone on my Relay G55 and what does it do?
A: The cable tone button simulates the slight change in tone that happens when using cables of varying length. The cable tone length that the Relay 55 uses is a 25 foot length guitar cable. At shorter lengths this change in tone is hard to recognize, but as length gets up to 100 feet and beyond, the extreme high end of your tone "rolls off" and loses volume. A cable length of 25 feet will not affect your audio below aproximately 15kHz.
Q: Can I use my Relay G55 transmitter or receiver with other Line 6 wireless?
A: Yes, all Line 6 wireless devices are compatible to work with one another. So, if you have a Line 6 XDV receiver, any transmitter from a Relay system will work with it, and vice versa. However, it is important to realize that Line 6 wireless systems in RF2 mode will not work with coresponding units in RF1 mode - regardless of the system they are from. You cannot use RF2 mode in the presence of any older Line 6 2.4G wireless (including Relay) in the same venue. If you try you will likely get failures in both the old and new units. So it is important to know if you are using RF1 or RF2 mode.
You must either flash older models to the newer V2.0 firmware (and you must have access to a V75 receiver and do this via Monkey) or you can shift the newer models (or any that have been flashed with V2.0) into RF 1 mode.
If an XD-V75 unit is being added to a setup that already includes any devices running in RF1 mode, the XD-V75 can be used to update the older devices to run RF2 mode by using an internet-connected computer attached to the XD-V75’s USB port. See the Firmware Updating Procedure section for more information. Alternatively, the XD-V75 transmitters can be setup to operate in RF1 mode if it is necessary to use the transmitters with older Line 6 receivers.
Q: How do I switch between RF2 mode and RF1 mode?
A: Relay G55 systems can be used in RF1 or RF2 mode.
To Set TBP12 Transmitters (Relay G50/55/90):
Enter Setup mode by holding the select button, and you will know you are in setup mode when the current channel is displayed flashing. Continue holding the select button. Then press the value button. RF2 will display showing that you are now in RF2 mode. Press and hold select to exit setup mode. Repeat this process to switch between RF1 and RF2 mode.
Note: It is IMPORTANT to note that once you shift (in either direction) the transmitters will only remember the change if you power cycle the transmitter. Just turn it off with the power switch and then back on. If you were to pop a battery before doing this then it will revert back to the last "saved" mode.
Q: How can I avoid wi-fi interference?
A: Page 11 of the Pilot's Guide provides more details, but here are suggested channels settings to avoid interfering with wi-fi:
Relay G55 F.A.Q.:
Qu'est-ce que le bouton Cable Tone sur mon Relay G55?
Le bouton "Cable Tone" simule le change de tonalité si on utilise un câble de longueur variable. Le Relay 55 utilise une tonalité d'un câble guitare de 7,5m. Aux longueurs plus courtes, ce changement en tonalité est difficile à reconnaitre mais si la longueur devient jusqu'à 30 mètres, l'extrémité haute de votre ton perd volume. Une longueur du câble de 7,5m ou moins n'affectera pas votre son au-dessous d'environ 15kHz.
Est-ce que USB 3.0 produit d'interférence dans la gamme de fréquences 2.4 GHz?
Est-ce que je peux utiliser mon émetteur ou récepteur Relay G55 avec autres appareils sans fil Line 6?
Oui, tous les appareils sans fil Line 6 sont mutuellement compatibles. Donc, si vous avez un récepteur Line 6 XDV et n'importe quel transmetteur Relay travaillera et inversement. Mais attention, les appareils Line 6 sans fil en mode RF1 ne fonctionnent pas avec les appareils un mode RF2 indépendamment du système. Vous ne pouvez pas utiliser le mode RF2 en présence de Line 6 2.4GHz Wireless dans le même lieu. Si vous essayez, vous aurez probablement des échecs dans les anciens et les nouvelles unités. Donc, c'est important de savoir si vous utilisez RF1 ou RF2.
Vous devez soit installer les anciens modèles sur le firmware V2.0 (ou plus récent) ou vous pouvez mettre les nouveaux modèles en mode RF 1.
Si vous mettez l'unité XD-V75 dans un setup avec des appareils en RF1, vous pouvez utiliser le XD-V75 pour mettre à jour les appareils plus anciens d'être capable d'utiliser RF2 en utilisant un ordinateur avec internet connecté. Branchez le XD-V75 dans votre ordinateur via USB. Visitez la section de la mise à jour firmware pour plus d'informations. Alternativement, vous pouvez mettre les transmetteurs XD-V75 sur RF1 si c'est nécessaire de las connecter aux récepteurs Line 6 plus anciens.
Comment est-ce que je peux commuter entre mode RF1 et RF2?
  • Placez l’émetteur sous tension, et maintenez la touche "Select" enfoncée jusqu’à ce que le numéro du canal clignote.
  • Maintenez la touche "On/Mute" (alimentation) enfoncée et appuyez rapidement sur "Select" et sur "Value"; appuyez dans la seconde qui suit — n’attendez pas plus, sinon l’émetteur se place hors tension.
  • Notez que la ligne supérieure de l’écran LCD indique temporairement [RF-1] à la place de [CH], ce qui indique que l’émetteur est dans un mode de transmission compatible avec les récepteurs G90 et G30.
  • Pour revenir au mode de transmission RF2, répétez les opérations précédentes en appuyant rapidement sur la touche de mise sous tension puis en appuyant rapidement sur "Select" dans l’écran [CH]. La ligne supérieure de l’écran LCD indique temporairement [RF-2], ce qui correspond au changement de mode.
  • Notez que le mode de transmission est mémorisé ; même après la mise hors tension.
Comment est-ce que je peux éviter des interférences WiFi?
Ci-dessous sont réglages des canaux suggérés pour éviter les interférences avec WiFi:
F.A.Q. zum Relay G55
Was ist der Cable Tone Knopf und was bewirkt er?
Der die Cable Tone Einstellung simuliert die kleine Veränderung des Klangs bei Benutzung von Kabeln bestimmter Längen. Das Kabel, welches für diese Modifizierung benutzt wurde für das Relay 55 ist ein Gitarrenkabel der Lange 7,5m. Bei kürzeren Kabeln ist es schwer den Unterschied zu hören aber bei Längen über 30 Metern verliert das extrem hohe Ende des Klangs an Lautstärke. Ein Kabel von 7,5m beeinträchtigt den Klang unter ca. 15kHz nicht.
Verursacht USB 3.0 Interferenzen im 2,4GHz Frequenzbereich?
USB 3.0 Computerkabel und –geräte sind dafür bekannt Interferenzen bei Radio Frequenzen im 2,4GHz Bereich zu erzeugen was zu verringerter Reichweite und Performance für alle 2.4GHz Geräte (inklusive kabellose Tastatur oder Maus sowie WiFi und viele andere) in der Nähe führen kann. Wir empfehlen alle digitalen Kabellosempfänger mindestens 2m von den USB 3.0 Geräten und deren Verkablung weit weg zu plazieren.
Kann ich meinen Relay G55 Transmitter oder Empfänger mit anderen Line 6 Wireless Geräten verwenden?
Ja, alle kabellosen Line 6 Geräte sind kompatibel mit miteinander zu kommunizieren. Wenn Sie also einen Line 6 XDV Empfänger und irgend einen Transmitter mit Relay System wird dies funktionieren, sowie umgekehrt. Achtung, Line 6 Geräte im RF2 Modus werden nicht mit Geräten im RF1 Modus funktionieren, egal welches System benutzt wird. Sie sollten keinen RF2 Modus in der nähe alter Line 6 Geräte verwenden, wenn Sie dies versuchen werden es wahrscheinlich zu Fehlern auf beiden Geräten (alt und neu) führen. Also müssen Sie sich immer sicher sein welchen Modus Sie verwenden RF1 oder RF2.
Sie müssen dann entwerden die alten Modelle auf die V2.0 Firmware aktualisieren (zusätzlich müssen Sie Zugriff auf einen V75 Empfänger und Monkey haben) oder auf den neuen Geräten (oder älteren auf Firmware Version 2.00) RF1 einstellen.
Wenn ein XD-V75 in ein Setup; welches bereits Geräte beinhaltet, die auf RF1 laufen; kann das XD-V75 dazu verwendet werden, die älteren Geräte zu aktualisieren, damit diese RF2 benutzen können. Das XD-V75 muss an einen Computer via USB mit bestehender Internetverbindung angeschlossen sein. Schauen Sie sich dann die Firmware Update Sektion für weitere Informationen an. Alternativ können die XD-V75 Transmitter so eingestellt werden, dass diese im RF1 Modus laufen, wenn es nötig ist, dass die Transmitter mit alten Line 6 Empfängern kommunizieren können.
Wie kann ich zwischen RF1 und RF2 wechseln?
  • Schalten Sie den Sender ein und halten Sie seinen SELECT Knopf so lange gedrückt, bis die Kanalnummer blinkt.
  • Halten Sie den ON/MUTE Knopf gedrückt, während Sie schnell SELECT und VALUE drücken. Sie müssen innerhalb einer Sekunde drücken. Wenn Sie nämlich länger warten, wird der Sender ausgeschaltet.
  • In der oberen Display-Zeile wird [RF-1] (statt [CH]) angezeigt: Der Sender verwendet jetzt den für Relay G90 und Relay G30 Empfänger benötigten Modus.
  • Um später wieder den RF2-Modus zu wählen, müssen Sie auf der “CH”-Seite zuerst den Netztaster und gleich danach SELECT drücken. In der oberen Display-Zeile wird kurz “RF-2” angezeigt, um die Moduswahl zu bestätigen.
  • Der mit diesem Verfahren gewählte Modus bleibt auch nach dem Ausschalten erhalten.
Wie kann ich WiFi Interferenzen vermeiden?
Im Anschluss finden Sie verschiedene empfohlene Kanal-Einstellungen um Interferenzen zu vermeiden:
