StageScape M20d Firmware 1.10 Update Information
  • https://line6.com/media/ips/uploads/monthly_07_2013/ccs-1582879-0-55387800-1374258384.jpg,monthly_07_2013/ccs-1582879-0-92125500-1374258415.jpg,monthly_07_2013/ccs-1582879-0-75821400-1374258465.jpg
Deutsch
Français
StageScape Firmware v1.10
IMPORTANT NOTICE: This version of the StageScape firmware works only with StageScape remote app v1.10. Please update your StageScape remote app on your iPad when updating your StageScape firmware.
When updating firmware, have ONLY the SD card or USB drive that is being used to install the update plugged into the StageScape.
This update is available from this web address http://line6.com/software/index.html. Be sure to select StageScape M20d under All Products, click the red Go button, and you will be able to download the Firmware 1.10 update. You will have to download this file and save it to a SD card or USB thumb drive. Insert that device into your StageScape M20d, go to the i menu, Show System Settings, Update M20d, Update System Firmware.
The update file will have to be in the top hierarchy of your media device. Firmware install files will not be recognized if they are placed in a folder. Be sure to unplug any other media device (USB, SD card or PC) from your StageScape that is not being used for the firmware update. New Features
  • New recording features, including marker functions (create, list and seek to marker) and fast forward/reverse 10 seconds at a time.
  • Join an existing wireless network.
  • Stereo Monitoring
Fixed Issues:
  • Status of the phantom power of channel 7- 12 was not saved with setups on previous firmware version.
  • An audio "clicking" artifact in the chorus effect has been removed.
  • Other minor bug fixes.
Informationen zum StageScape M20d Firmware Update 1.10
ACHTUNG, WICHTIG: Diese Version der StageScape Firmware funktioniert ausschließlich mit der StageScape remote app v1.10. Bitte aktualisieren Sie Ihre StageScape remote app auf Ihrem iPad wenn Sie die StageScape Firmware aktualisieren wollen.
Wenn Sie Firmware aktualisieren entfernen Sie jegliche Geräte von Ihrem StageScape und lassen Sie nur die SD Karte oder den USB Stick im StageScape, den Sie brauchen um die Firmware zu aktualisieren.
Dieses Update können Sie auf der folgenden Webseite herunterladen:
http://de.line6.com/software/index.html
Wählen Sie im "All Products" Menu StageScape M20d aus und klicken Sie auf den "Go" Knopf dann können Sie die 1.10 Firmware herunterladen. Laden Sie sich die Datei herunter und speichern Sie diese auf eine SD Karte oder einen USB Stick. Stecken Sie das Gerät in Ihren StageScape M20d, gehen Sie in das "i" Menu -> Show System Settings -> Update M20d -> Update System Firmware
Die Datei zur Aktualisierung, muss im Stammverzeichnis des USB Sticks/SD Karte sein. Installationsdateien für die Firmware werden nicht erkannt wenn diese in einem Ordner sind. Entfernen Sie alle anderen Geräte, Ihren PC oder SD Karten vom StageScape, die nicht zum Update benötigt werden.
  • Neue Aufnahmemöglichkeiten: Marker Funktionen (erstellen, auflisten und suchen nach Markern) und 10 Sekunden Vorspulen oder Zurückspulen pro Klick.
  • Einem bestehenden kabellosen Netzwerk beitreten.
  • Stereo Monitoring
Behobene Probleme:
  • Der Status der Phantomspeisung für die Kanäle 7 bis 12 wurde nicht abgespeichert auf vorherigen Firmware Versionen.
  • Ein "Klick" Artefakt im Chorus Effekt wurde entfernt.
  • Andere kleinere Fehlerbehebungen.
StageScape M20d: Informations concernant la mise à jour 1.10 de la firmware
REMARQUE IMPORTANTE: Cette version de la firmware StageScape fonctionne exclusivement avec la version 1.10 de la StageScape remote app. Veuillez mettre à jours votre StageScape remote app sur votre iPad si vous voulez mettre votre firmware StageScape à jours.
Si vous actualisez votre firmware, détachez tous sauf la carte SD ou clé USB que vous avez besoin pour installer la mise à jour.
Cette mise à jour est disponible sur ce site web: http://line6.com/software/index.html. Choisissez StageScape M20d dans la catégorie "All Products", cliquez le bouton rouge "Go" et vous pouvez télécharger la mise à jour 1.10 de la firmware. Téléchargez ce fichier et enregistrez-le sur un disque amovible. (Carte SD ou clé USB) Insérez ce périphérique dans votre StageScape M20d, allez dans le Menu "i" -> "Show System Settings" -> "Update M20d" -> "Update Firmware".
Le fichier doit être dans le dossier racine de votre clé USB/carte SD. (Le fichier ne peut pas être dans un sous-dossier.) L'appareil ne reconnait pas le fichier s'il est dans un dossier. Détachez tous les autres appareils media (PC, clé USB, carte SD) de votre StageScape que vous n'avez pas besoin pour cette mise à jour.
  • Nouvelles fonctions d'enregistrement. Des fonctions marqueurs (créer, inscrire et chercher à marqueur) et avance ou retour rapide de 10 secondes par clic.
  • Joindre un réseau sans fil.
  • Monitoring stéréo.
Problèmes résolus:
  • L'état d'alimentation fantôme sur les canaux 7 à 12 n'enregistrait pas sur les versions précédentes de la firmware.
  • Un artefact "clic" a été enlevé dans l'effet chorus.
  • Autres corrections des bugs mineurs.
