StageScape M20d Firmware 1.20 Update Information
line6jonb
  • https://line6.com/media/ips/uploads/monthly_09_2013/ccs-1582879-0-33685600-1379959262.png,monthly_09_2013/ccs-1582879-0-89226200-1380038884.jpg,monthly_09_2013/ccs-1582879-0-21157400-1380038933.jpg,monthly_09_2013/ccs-1582879-0-72904400-1380038962.jpg,monthly_09_2013/ccs-1582879-0-45229500-1380038995.jpg,monthly_09_2013/ccs-1582879-0-91383500-1380039022.jpg,monthly_09_2013/ccs-1582879-0-92159000-1380039044.jpg
Version française.
Deutsche Version.
The 1.20 firmware update for the StageScape M20d features a new fader view for enhanced control on touch screens and Artist Presets.
****Please be aware that if you are updating from firmware 1.00 directly to 1.20, the update file will state that you are installing version 1.32. This is a typo that will be fixed in the future and it will have no affect on your firmware 1.20 installation or functionality.****
IMPORTANT NOTICE: This version of the StageScape firmware works only with StageScape remote app v1.10. Please update your StageScape remote app on your iPad when updating your StageScape firmware.
When updating firmware, have ONLY the SD card or USB drive that is being used to install the update plugged into the StageScape.
This update is available from this web address http://line6.com/software/index.html. Be sure to select StageScape M20d under All Products, click the red Go button, and you will be able to download the Firmware 1.20 update. You will have to download this file and save it to a SD card or USB thumb drive. Insert that device into your StageScape M20d, go to the i menu, Show System Settings, Update M20d, Update System Firmware.
The update file will have to be in the top hierarchy of your media device. Firmware install files will not be recognized if they are placed in a folder. Be sure to unplug any other media device (USB, SD card or PC) from your StageScape that is not being used for the firmware update. New Features
Bug fixes:
  • Output preset recall resetting output level
  • Minor bug fixes
Fader View:
With the new 1.20 firmware, the perform mode now has a fader view option on the touch screen of the StageScape M20d. This allows you to view and manipulate levels for your inputs, monitors, global FX, and main mix as virtual faders on the touch screen. You can also control your trim, pan, and global FX send levels with the rotary encoders under each virtual channel strip.
Artist Presets: Brad Madix and Daniele Di Giovanni
Brad Madix:
Rock Kick - Aggressive rock bass drum. Sits in the mids when you really lay into it, somewhat more natural when played quietly.
Rock Snare - A "fat" rock snare with a bottom that is shaped using the dynamic eq. Pushes up the low end for that "arena rock" sound.
Drum Buss Crush - Crush a drum sub mix. Really pumping compression. Scary on its own, but blend it back in with the uncompressed drums and the whole kit will come forward. A little goes a long way.
Rock Bass - Big mid boost to get the bass to pop out in the mix
Rock Guitar - Bright and cutting. Best for leads.
Vocal - Bright and clear without sibilance using the de esser Brighten up that male vocal without it getting too "essy".
Daniele Di Giovanni:
Grand Piano (PianoMic)- Earthworks PianoMic at its best
Attention, cette version du firmware StageScape a une nouvelle vue fader pour un contrôle augmenté sur les écrans tactiles et les presets Artistes.
***Si vous installez firmware 1.20 sur 1.00, la mise à jour indique que vous installez version 1.32. C’est une faute de frappe. Ignorez ca. Il n'aura aucun effet sur ​​votre firmware 1.20 ou l’installation.***
Attention, cette version firmware fonctionne uniquement avec l’application StageScape Remote 1.10. Donc vous devez mettre à jour l’application StageScape pour l’utiliser avec la nouvelle version du firmware.
Débranchez tous les appareils USB de votre StageScape sauf l’appareil avec le nouveau firmware.
Vous pouvez trouver la mise à jour ici : http://fr.line6.com/software/index.html. Sélectez le StageScape M20d sous « All Products » et cliquez « Go ». Téléchargez le Firmware 1.20 et sauvez le fichier sur une carte SD ou clé USB. Insérez la carte ou la clé dans votre M20d et cliquez sur le menu « i », « Show System Settings », « Update M20d » et « Update System Firmware ».
Placez le fichier directement sur la carte SD ou clé USB et pas dans un dossier sur la clé/la carte. L’appareil ne trouvera pas le fichier si vous le placez dans un dossier. Débranchez tous les autres dispositifs du StageScape M20d que vous n’utilisez pas pour la mise à jour.
  • Corrections des bugs mineurs.
Fader View
Avec la mise à jour du firmware 1.20 le mode perform a une option Fader View sur l’écran tactile qui vous permet de voir et manipuler les niveaux des entrées, moniteurs, Global FX et du mix principal comme curseurs sur l’écran tactile. Vous pouvez aussi contrôler Trim, Pan et Global FX niveaux d’envoi avec les encodeurs rotatifs dessous les canaux.
Presets Artistes: Brad Madix et Daniele Di Giovanni
Brad Madix:
Rock Kick: Grosse caisse rock agressive. Très naturel si vous le jouez doucement.
Rock Snare: Basses formés avec l’EQ dynamique. Augmente les basses pour un son « arena rock ».
Drum Buss Crush: Compression massive. Jouez-le avec une batterie non compressée.
Rock Bass: Un boost pour les mis.
Rock Guitar: Très bien pour le joueur principal.
Vocal: Pour on son très clair.
Grand Piano (PianoMic) – Le PianoMic de Earthworks à son meilleur.
Das Firmwareupdate 1.20 für StageScape M20d erweitert Ihr M20d um zusätzliche Schiebregler für mehr Kontrolle und neue Artisten Presets.
***Achtung, wenn Sie von Firmware 1.00 auf 1.20 aktualisieren wir das Update Ihnen anzeigen, dass Sie Version 1.32 installieren. Dies ist ein Schriftfehler, der in Zukunft behoben wird. Ignorieren Sie diesen Fehler, denn er beeinträchtigt die Funktionalität des Updates nicht.***
Achtung, diese Firmware Version funktioniert nur mit der StageScape Remote App 1.10. Wenn Sie die Firmware aktualisieren, entfernen Sie bitte zuerst alle anderen SD Karten und USB Sticks abgesehen vom USB Stick oder SD Karte, auf welcher die neue StageScape Firmware abgespeichert ist.
Dieses Update können Sie auf der Internetseite http://de.line6.com/software/index.html finden. Wählen Sie das M20s unter All Products aus, klicken Sie dann auf Go und dann sollten Sie das Update auch schon sehen. Laden Sie sich hier dann Version 1.20 herunter. Speichern Sie es dann auf einem USB Stick oder einer SD Karte ab. Stecken Sie diese dann in den M20d. Auf dem M20d gehen Sie dann auf das i Menu, Show System Settings, Update M20d und Update System Firmware.
Die Datei muss sich direkt auf der SD Karte/USB Stick befinden un dort nicht innerhalb eines Ordners.
Fehlerbehebungen:
Kleinere Fehlerbehebungen.
Neue Schiebregler:
Mit der neuen Firmware Version 1.20 ist der Perform Modus um ein Set Schiebregler erweitert worden. Mit diesen können Sie Input, Monitor Global FX und Main FX Pegel auf dem Touchpad einstellen. Außerdem können Sie Trim Pan und Global FX Pegel via der normalen Drehknöpfe verändern.
Artisten Presets:
Brad Madix:
Rock Kick: Agressives Rock Schlagzeug. Klingt sehr natürlich wenn man es ruhig spielt.
Rock Snare: Die niedrigen Frequenzen sind per dynamischem EQ geformt. Drückt den Bass außerdem nach oben für den typischen Arena Rock Sound.
Drum Bass Crush: Extreme Kompression. Mischen Sie diese dann mit unkomprimiertem Schlagzeug um einen einzigartigen Sound zu bekommen.
Rock Bass: Boost für die Mitten.
Rock Guitar: Perfekt für den Lead.
Vocal: Für klaren Sound.
Grand Piano (PianoMic): Earthworks PianoMic.
