Sign in to follow this
StageScape M20d Setup Examples via L6 Link
  • https://line6.com/media/ips/uploads/monthly_07_2013/ccs-1582879-0-53979600-1374539306.jpg,monthly_07_2013/ccs-1582879-0-64843400-1374539332.jpg
Deutsch
Français
All L6 Link Connections require AES/EBU cables with a maximum 50 foot length.
StageScape M20d Small PA :
  • Connect the L6 LINK out from a StageScape M20d mixer to the rear panel L6 LINK In on any speaker in the network.
  • Any L3t/L3m towers and L3s subs on an L6 LINK network are numbered independently.
  • In the illustration above, the two L3s subs (labeled SUB 1 and 2) will, by default, play left and right, respectively. The two upright L3t/L3m towers (numbered 1 and 3) will, by default, play left and right, respectively. L3t/L3m number 2, because it?s laid on its side, will automatically play discrete monitor feed A.
  • Any speaker on the network can have its channel assignment changed from the M20d's touch screen interface.
StageScape M20d Large PA :
  • In the illustration above, four L3s subs (labeled SUB 1-4) and seven L3t/L3m speakers (independently numbered 1-7) are daisy-chained from an M20d mixer. The subs and upright towers automatically configure themselves to be a powerful stereo mains system. L3t/L3m speakers on their side (numbers 3, 4, and 5) automatically configure themselves as stage monitors, and play monitor feed A, B, and C respectively.
  • You can also reassign any speaker from the M20d touchscreen.
Toutes les connexions L6 Link ont besoin d’un câble AES/EBU avec une longueur maximale de 15 mètres.
StageScape M20d : Système de sonorisation petit :
  • Branchez la sortie L6 LINK du M20d à l’entrée L6 LINK d’un haut-parleur.
  • Tous les L3t, M3m et L3s ont des nombres différents.
  • Pour l’illustration, les L3s (SUB 1 et 2) jouent gauche et droite respectivement. Les L3t/L3m (1 et 3) jouent gauche et droite respectivement automatiquement. Le L3t/L3m 2 est en mode Moniteur parce qu’il est mis sur sa côté.
  • Vous pouvez assigner les canaux pour tous les haut-parleurs séparément sur le M20d.
  • Pour cette illustration, on a chaîné 4 L3s et 7 L3t/L3m avec un M20d. Les L3s et L3t/L3m verticaux se configurent automatiquement en mode Stereo Main System et les autres, qui sont sur la côté se configurent en mode Moniteur.
  • Vous pouvez réassigner tous les haut-parleurs avec le M20d.
Alle L6 LINK Verbindungen benötigen AES/EBU Kabel mit einem Maximum von 15 Metern.
StageScape M20d: Kleine Beschallungsanlage:
  • Verbinden Sie den StageScape L6 LINK Ausgang mit dem L6 LINK Eingang eines Lautsprechers im System.
  • Jeder L3t, L3m und L3s hat eine bestimte Nummer.
  • Für die obige Darstellung werden die 2 L3s automatisch jeweils rechts und einer links abspielen, die beiden augestellten L3t/L3m werden sauch automatisch rechts une einer links abspielen. L3t/L3m Nummer 2 wird sich als Monitor konfigurieren, da er auf der Seite liegt.
  • Jeder Lautsprecher im System kann anhand des M20d einen neuen Kanal zugewiesen bekommen.
StageScape M20d: Große Beschallungsanlage:
  • Oben werden 4 L3s und 7 L3t/L3m dargestellt, die in Reihe geschaltet und an einen M20d angeschlossen sind. Die Subwoofer sowie aufrechten L3t/L3m werden sich selbst als Stereo Main System einstellen und die L3t und L3m die auf der Seite liegen als Monitore.
  • Alle Laustsprecher können andere Kanäle zugewiesen bekommen, falls gewünscht.
