Sign in to follow this
WiFi Connectivity & SD Card Compatibility
  • https://line6.com/media/ips/uploads/monthly_03_2014/ccs-1582879-0-20470100-1395255084.png,monthly_03_2014/ccs-1582879-0-04684600-1395255095.png,monthly_03_2014/ccs-1582879-0-62380700-1395255114.png,monthly_03_2014/ccs-1582879-0-09457900-1395255195.png,monthly_03_2014/ccs-1582879-0-78807100-1395255208.png,monthly_03_2014/ccs-1582879-0-24095900-1395255407.png,monthly_03_2014/ccs-1582879-0-42958100-1395255420.png,monthly_03_2014/ccs-1582879-0-70630100-1395255431.png,monthly_03_2014/ccs-1582879-0-73452300-1395255539.png,monthly_03_2014/ccs-1582879-0-48369400-1395255554.png,monthly_03_2014/ccs-1582879-0-31223400-1395255569.png,monthly_03_2014/ccs-1582879-0-08893400-1395255589.png,monthly_03_2014/ccs-1582879-0-79764100-1395255601.png,monthly_04_2014/ccs-1582879-0-98292900-1396892920.png,monthly_04_2014/ccs-1582879-0-56191600-1396892931.png,monthly_04_2014/ccs-1582879-0-59488200-1396892943.png,monthly_04_2014/ccs-1582879-0-04159400-1396892953.png,monthly_04_2014/ccs-1582879-0-82853500-1396892962.png,monthly_04_2014/ccs-1582879-0-05726400-1396892972.png,monthly_04_2014/ccs-1582879-0-88221100-1396892980.png,monthly_04_2014/ccs-1582879-0-88989000-1396892989.png,monthly_04_2014/ccs-1582879-0-31141100-1396892998.png
Deutsch
Français
The convenience of mobility has become integral to so many aspects of our lives, and the M20d extends that convenience to the stage. Use the StageScape Remote app to connect one or more iPad devices simultaneously (via optional USB Wi-Fi adapter - refer to the Wifi USB adapter compatibility document in our support documents) for complete remote control over all mixer functions. Adjust the front-of-house mix from anywhere in the audience.
Each iPad can control different screens or different parameters in addition to the mixer's own touchscreen. Whether you're a band member adjusting your monitor mix or a sound man out in the audience, you've got full control.
The following USB WiFi adapters are compatible with the M20D StageScape for use in conjunction with your iPad:
  • Recommended WiFi Routers:
    • Apple USB to Ethernet adapter (UPC: 885909439560) in conjunction with Apple Airport Express **Most highly recommended**
    • Cisco Linksys E2500
    • Belkin N600
    • Apple Airport Express
    • Any Router with DHCP
    [*]Supported USB-Wifi Adapters:
    • EnGenius EUB-9801
    • Samsung WIS12ABGNX - WIS9ABGN and a WIS10ABGN are NOT compatible
    [*]Supported USB-Ethernet Adapters
    • Apple USB to Ethernet adapter (UPC: 885909439560) - ***OTHER ADAPTERS MAY NOT WORK***
The following SD cards are compatible with the M20D:
  • Any class 10 SD card is compatible with the M20D. Only class 10 SD cards formatted as FAT32 are compatible.
  • 32 GB maximum SD storage space
***NOTE: You must set up the Apple Airport Express as a router on a Mac or Windows computer using the Apple Airport Utility before using with the Stagescape M20d. This can be downloaded from Apple's website. Here is a link for instructions on setting up the Apple Airport Express on your computer:
Apple Airport Express Setup Guide
Please contact Apple support if you have trouble setting up your Airport Express as a router with your computer.
The Apple Airport Express has an 1/8" audio output that can be connected into the StageScape M20d. When you do this, you can play music from your iPad's music library while using the StageScape app. This allows you to play audio from your iPad through your StageScape without preparing a SD card.
Airport Express Setup Utility Pages (MAC):
Airport Express Setup Utility Pages (Windows):
Airport Express Setup Utility Pages (iPad):
Wireless network connectivity procedures:
For the EnGenius EUB-9801, plug in the USB Internet adapter to the USB port on the M20d. Do not worry if the lights on the USB adapter do not light up, you will have internet connectivity. On the StageScape, go to the i menu, then Show System Settings, then WiFi. The WiFi menu will display Unit Name and Security Pin. The Unit Name will be the name of the Wireless Network that you connect to on you iPad. The Security Pin will be the password. To connect to this wireless network on your iPad, go to Settings - General - Network - and you will see the M20d Unit Name as a network option.
For the Apple USB to Ethernet adapter, plug the adapter into the USB port on your M20d. Then connect the adapter via Ethernet cable to ANY wireless internet router. Then on the StageScape, go to the i menu, then Show System Settings, then WiFi. The WiFi menu will display Unit Name and Security Pin. The Unit Name will be the name of the Wireless Network that you connect to on you iPad. The Security Pin will be the password. To connect to this wireless network on your iPad, go to Settings - General - Network - and you will see the M20d Unit Name as a network option.
Kompatibilität und Konnektivität mit WLAN USB Adaptern:
Der Komfort der Mobilität ist wesentlich geworden für viele Aspekte des Lebens und das M20d erweitert diesen Komfort auf die Bühne. Verbinden Sie ein oder mehrere iPad® Geräte gleichzeitig (über USB WLAN Adapter – siehe Dokument zur WLAN USB Adapter Kompatibilität in unseren Handbüchern) mit Ihrem M20d um vollständige kabellose Kontrolle über alle Mixerfunktionen zu haben. So können Sie den Front of House Mix von egalwo aus dem Publikum anpassen.
Jedes iPad® kann so auf individuelle Einstellungen zusätzlich zum eigenen Touchscreen des Mixers zugreifen.
Folgende USB WLAN Adapter sind kompatibel mit dem StageScape M20d in Verbindung mit einem iPad:
Apple USB zu Ethernet Adapter (UPC: 885909439560) in Verbindung mit einem WLAN Router:
1. Empfohlene WLAN Router:
  • Belkin N600
  • Apple Airport Express (höchst empfehlenswert)
  • Jeglicher DHCP Router
2. EnGenius EUB-9801
3. Samsung WIS12ABGNX - WIS9ABGN and a WIS10ABGN are NOT compatible
Folgende SD Karten sind kompatibel mit dem M20d:
  • Jede SD Karte der Klasse 10 ist kompatibel.
  • Ausschließlich SD Karten der Klasse 10 mit FAT 32 Formattierung sind kompatibel.
  • Maximal 32 GB SD speicherplatz
Das Apple Airport Express hat einen 3.5mm Klinkenstecker Ausgang, der an das StageScape M20d angeschlossen werden kann. So können Sie Musik von Ihrem iPad abspielen während Sie die StageScape App benutzen. Also können Sie Musik von Ihrem iPad über das StageScape abspielen ohne SD Karte zu benutzen.
Verfahren zur WLAN Verbindung:
Für das EnGenius EUB-9801 und das Samsung WIS10ABGN brauchen Sie nur einen der USB Internet Adapter an den USB Port des M20d zu stecken. Machen Sie sich keine Sorgen wenn die Lichter auf dem USB Adapter nicht leuchten, Sie haben eine Internetverbindung. Wenn Sie eines der Gerät mit Ihrem StageScape verbunden haben wird das M20d keine Meldung machen. Im StageScape klicken Sie oben rechts auf das "i" dann "Show System Settings" und "WiFi".Hier wird Ihnen jetzt "Unit Name" und "Security Pin" angezeigt."Unit Name" ist der Name des WLAN Netzwerks auf welches Sie dann mit Ihrem iPad zugreifen und der "Security Pin" ist das dazugehörige Passwort. Um auf dieses Netwerk nun zuzugreifen gehen Sie auf Ihrem iPad nach Einstellungen -> Allgemein -> Netzwerk, hier wird jetzt der "Unit Name", den Sie auf dem M20d ange geben haben als Netzwerkoption angezeigt.
Für den Apple USB zu LAN Adapter müssen Sie ersteinmal den Adapter in den USB Port Ihres M20d stecken, dann verbinden Sie den Adapter via LAN Kabel an irgend einen WLAN Router stecken. Im StageScape klicken Sie oben rechts auf das "i" dann "Show System Settings" und "WiFi".Hier wird Ihnen jetzt "Unit Name" und "Security Pin" angezeigt."Unit Name" ist der Name des WLAN Netzwerks auf welches Sie dann mit Ihrem iPad zugreifen und der "Security Pin" ist das dazugehörige Passwort. Um auf dieses Netwerk nun zuzugreifen gehen Sie auf Ihrem iPad nach Einstellungen -> Allgemein -> Netzwerk, hier wird jetzt der "Unit Name", den Sie auf dem M20d ange geben haben als Netzwerkoption angezeigt.
Compatibilité et connectivité avec les adaptateurs USB Wifi:
Le confort de mobilité est devenu important pour nombreux aspects de la vie et le M20d développe ce confort à la scène. Connectez un ou plusieurs appareils iPad® (avec un adaptateur USB Wifi – consultez le document sur la compatibilité des adaptateurs USB Wifi dans nos manuels) simultanément avec votre M20d pour contrôle sans-fil maximale des fonctions du StageScape. Comme-ca vous pouvez régler le mix de la salle de n'importe où dans l'audience.
Chaque iPad® peut accéder des réglages individuels en plus du écran tactile du M20d.
Les adaptateurs Wifi USB suivants sont compatibles avec le StageScape M20d en a ssociation avec un iPad:
1. Adaptateur USB à Ethernet de Apple (UPC: 885909439560) en liaison avec un routeur Wifi:
Routeurs WLAN recommandés:
  • Belkin N600
  • Apple Airport Express (le plus fortement recommandé)
  • Tous les routeurs DHCP
Les cartes SD su ivantes sont compatibles avec le M 20d:
  • Toutes les cartes SD de classe 10 sont compatibles.
  • Seulement les cartes SD de classe 10 avec formatage FAT 32 sont compatibles.
  • 32 Go d'espace de stockage maximal SD
L'Apple Airport Express a une sortie 3.5mm Jack, qui peut être connecté au StageScape M20d. Comme-ca vous pouvez jouer de la musique de votre iPad en utilisant l'application StageScape. Donc, vous pouvez jouer de la musique de l'iPad via le StageScape sans devoir utiliser une carte SD.
La méthode pour connecter Wifi:
Pour l'EnGenius EUB-9801 et le Samsung WIS10ABGN, vous devez seulement connecter un des adaptateurs internet USB à un port USB du StageScape. Si les lumières sur l'adaptateur ne s'activent pas, c'est normal. Vous avez une connexion pourtant. Le M20d ne fait aucune notification si vous avez connecté l'appareil. Dans le StageScape, tapez le "i" en droite supérieur après "Show System Settings" et "WiFi". Vous voyez "Unit Name" et "Security Pin". "Unit Name" est le nom du réseau sans fil, sur lequel l'iPad se connectera et "Security Pin" est le mot de passe. Pour accéder ce réseau, allez sur votre iPad dans Réglages -> Général -> Réseau. Ici le réseau avec le nom que vous avez choisissez, "Unit Name", s'affiche comme option.
Pour l'adaptateur USB à Ethernet Apple, vous devez branchez l'adaptateur dans le port USB du StageScape et le connectez via câble Ethernet à un routeur WiFi. Dans le StageScape, tapez le "i" en droite supérieur après "Show System Settings" et "WiFi". Vous voyez "Unit Name" et "Security Pin". "Unit Name" est le nom du réseau sans fil, sur lequel l'iPad se connectera et "Security Pin" est le mot de passe. Pour accéder ce réseau, allez sur votre iPad dans Réglages -> Général -> Réseau. Ici le réseau avec le nom que vous avez choisissez, "Unit Name", s'affiche comme option.
