iOS Privacy 'Microphone Access' - No Input
Line6Don
  • https://line6.com/media/ips/uploads/monthly_09_2013/ccs-1319933-0-52829100-1380149466.jpg,monthly_09_2013/ccs-1319933-0-27964900-1380149476.jpg,monthly_09_2013/ccs-1319933-0-47217700-1380149484.jpg,monthly_09_2013/ccs-1319933-0-21383700-1380149492.jpg
Deutsch
Français
With the release of Apple's iOS 7, Apple added a new privacy feature that can disable audio input from our mobile interfaces. The problem occurs the first time you launch the app under iOS7 and above, if you do not allow iOS along with the particular app you are using to have access to the 'Microphone', than you will temporarily not be able to receive input from mobile interfaces. The solution is to make sure that you press 'OK' when you see this prompt, but this prompt only appears the first time you launch the app.
If you did not press 'OK' on this prompt and are not able to receive input from your Line 6 Mobile Interface, than you will need to do the following steps:
  • Tap your iOS settings button.
  • Tap the tab for 'Privacy' located on the left hand side of the screen.
  • Than tap the option for 'Microphone' on the right.
  • You will than see a list of apps that have requested access to the 'Microphone'.
  • Simply tap the switch next to each that you would like to use the Line 6 Mobile Interface with.
  • Relaunch all of the apps that you would like to use your Line 6 Mobile Interface with.
Avec la publication d’Apple iOS7, Apple a ajouté une nouvelle fonction de confidentialité qui peut désactiver tous l’audio qui vient des Sonic Port et Mobile In. Ce problème se produit la première fois que vous lancez l’application sous iOS7 et si vous ne permettez l’accès au Microphone, vous ne pouvez pas recevoir du audio avec nos interfaces portables. La solution est simple, appuyez le bouton OK si votre appareil vous donne le choix. Attention, cette invite apparaît une seule fois.
Si vous n’avez pas appuyez OK et vous n’avez pas d’entrée avec l’application, suivez ces instructions :
  • Tapez le bouton « Réglages » sur l’appareil iOS.
  • Tapez sur Confidentialité à gauche.
  • Tapez sur Micro à droite.
Maintenant, vous pouvez voir une liste des applications qui ont demandés de l’accès au micro.
Tapez le commutateur à droite de l’entrée de votre application.
Relancez tous les applications que vous voulez utiliser avec l’interface Line6.
Seit der Version 7 von iOS, hat Apple eine neue Datenschutzfunktion eingeführt, die den Audioeingang des Gerätes mit einem Mobile In oder auch Sonic Port blockieren kann. Das Problem taucht beim ersten Start der App auf, nach dem Update auf iOS Version 7. Sollten Sie der App hier nicht den Zugriff auf das Mikrofon gewähren, wird dieses für die App in Frage temporär abgeschaltet. Klicken Sie also auf OK wenn Sie die App zum ersten Mal starten, um das Mikrofon freizugeben.
Sollten Sie nicht OK gedrückt haben können Sie das Mikrofon aber immernoch in den Einstellungen freigeben:
  • Drücken Sie auf Einstellungen,
  • Dann auf Datenschutz links und
  • Dann auf Mikrofon rechts.
Hier können Sie dann eine Liste aller Apps einsehen, die Zugriff auf das Mikrofon angefragt haben.
Drücken Sie hier einfach den Schalter, der das Mikrofon für eine bestimmte App blockiert.
Starten Sie dann alle Apps neu, die Sie mit der Line 6 Schnittstelle verwenden möchten.
