Set Up Helix Native (All Recording Programs)
Line6Tony
  • Links to individual articles that will help you set up Helix Native with your DAW. We will add more DAWs over time.
日本語は下記をご覧ください
How to Activate Helix Native
  • Download the latest version of Helix Native at http://line6.com/software/.
  • Run the Helix Native installer. We suggest you temporarily disable all third party antivirus programs during the installation. During the install, take note of the VST3 and AAX Plugin folder locations. If you choose to install the PC VST2 plugin, you will be able to choose your own folder location. On Mac, VST2 is installed at /Library/Audio/Plug-Ins/VST/.
  • PC VST2 only: Open your recording program's preferences and point it to the folder that Helix Native was installed to.
  • Start your DAW, create an audio track, then add Helix Native as a plugin (see below for links to your particular DAW).
  • On first run, you will be prompted to sign in to your Line 6 account to authorize your license.
Individual DAW Set-up Articles
Q: I can't find the Helix plug-in, even after following the steps in the articles above.
A. Possible causes:
  • The default VST3 folder on Windows is C:\Program Files\Common Files\VST3\. Ensure your DAW has scanned that directory.
  • Helix Native is a VST Effect. When searching your DAW's plug-ins list, make sure to look under VST Effects and not VST Instruments.
  • Helix Native is 64-bit only, and therefore won't appear in a 32-bit DAW.
Q: What are the default locations for Helix Native plug-in files?
This version of Helix Native plug-in installs on a Mac to:
AU Plug-in
/Library/Audio/Plug-Ins/Components/Helix Native.component
VST2 Plug-in
/Library/Audio/Plug-Ins/VST/Line 6/Helix Native.vst
VST3 Plug-in
/Library/Audio/Plug-Ins/VST3/Line 6/Helix Native.vst3
AAX Plug-in
/Library/Application Support/Avid/Audio/Plug-Ins/Line 6/Helix Native.aaxplugin
This version of Helix Native plug-in installs on Windows to:
VST3 Plug-in
C:\Program Files\Common Files\VST3\Line 6\Helix Native (x64).vst3
AAX plugin:
C:\Program Files\Common Files\Avid\Audio\Plug-Ins\Line 6\Helix Native.aaxplugin
n
NOTE: The VST2 plugin installation location, if installed, will be determined by the user during the installation process.
Helix Nativeをアクティベートする方法
  • Helix Nativeの最新バージョンを http://jp.line6.com/software/. からダウンロードします。
  • Helix Nativeインストーラを起動します。インストール中はすべてのサードパーティー製アンチウィルスソフトを一時的に無効にしておくことを推奨します。インストール中に、VST3およびAAXプラグイン・フォルダの場所を控えておきましょう。Windows PCVST2プラグインをインストールすることを選択する場合は、フォルダの場所を自身で選択することができます。Macでは、VST2は /Library/Audio/Plug-Ins/VST/ にインストールされます。
  • PC VST2のみ: レコーディング・プログラムのプリファレンスを開き、Helix Nativeがインストールされたフォルダを指定します。
  • DAWを起動し、オーディオ・トラックを作成してから、Helix Nativeをプラグインとして追加します。 (DAW別には以下のリンクをご参照ください 英文).
  • 最初に起動した際に、ライセンスをオーソライズするため、Line 6アカウントへのログインを求められます。
DAW別設定 (英文)
Q: 上記の手順に従っても、Helix Nativeプラグインが見つけられないのですが。
A. 以下の原因が考えられます:
  • Windows上のデフォルトのVST3フォルダは、C:\Program Files\Common Files\VST3\にあります。DAWがそのディレクトリをスキャンしているか確認してください。
  • Helix NativeVSTエフェクトです。DAWのプラグイン・リストを探す際は、VST InstrumentsではなくVST Effectsis a VST Effectを確認してください。
  • Helix Native64-bitのみなので、32-bit DAWには表示されません。
Q: Helix Native プラグイン・ファイルのデフォルトの場所はどこにありますか?
このバージョンのHelix Nativeプラグインは、Macの以下の場所にインストールされます:
AU Plug-in : /Library/Audio/Plug-Ins/Components/Helix Native.component
VST2 Plug-in : /Library/Audio/Plug-Ins/VST/Line 6/Helix Native.vst
VST3 Plug-in : /Library/Audio/Plug-Ins/VST3/Line 6/Helix Native.vst3
AAX Plug-in : /Library/Application Support/Avid/Audio/Plug-Ins/Line 6/Helix Native.aaxplugin
このバージョンのHelix Nativeプラグインは、Windowsの以下の場所にインストールされます::
VST3 Plug-in : C:\Program Files\Common Files\VST3\Line 6\Helix Native (x64).vst3
AAX plugin: C:\Program Files\Common Files\Avid\Audio\Plug-Ins\Line 6\Helix Native.aaxplugin
 NOTE: もしVST2プラグインをインストールした場合は、インストールの途中でユーザーが指定した場所になります。
