Posts
3,477 -
Joined
Last visited
Days Won
95
Everything posted by DunedinDragon
I agree with @themetallikid. Over the years the Helix has had numerous improvements in making things simple in terms of creating presets, the most prominent of which are the favorites. By selectively using favorites along with a standard preset template I've cut my preset development time to 1/3 of what it used to be. It's all a matter of thinking about your particular workflow and process and using the tools that are already there rather than starting off with a blank slate every time.
Not to dissuade you from finding that IR, but you're likely to lose a TON of flexibility using an IR unless that person created a bunch of different IRs with different mic's in different positions. What you're trying to do isn't anything unusual and most of us can get a decent guitar recording just using the stock cabs in Helix and knowing how to set them up to get the sound we want. It's really not that hard.
You can't get an amp in the room sound because that requires a physical amp in a physical room. Once you mic an amp cabinet it becomes a recorded sound which is what is always the case in recordings. IR's, by definition are cabinet recordings. Generally something sounding further back in the room will be related to things like reverb or delays or an early reflections setting that's too high, but it could also simply be that you need more presence and "bigness" to the sound which suggests you may want to add some compression.
There is no capability to change the theme of HX Edit. It's never been a problem for me, but if it's a problem for you, you might consider putting in an entry into IdeaScale on the subject since Line 6 doesn't really monitor this user forum.
- 1 reply
- 1
Helix Rack as audio device - some kind of global bypass?
DunedinDragon replied to astueger's topic in Helix
If it puts your mind at ease I have one of my Helix Floor units that's been attached to my main desktop computer since I got it in 2015 and is used as my audio interface with my two Yamaha HS7 studio monitors and it works just fine every day since then with no problems. I figure since I have to power up my speakers anyway, powering up the Helix is really no different than If I had a standalone interface that requires power. Both, as well as my Casio stage piano are all powered on and powered off via a single Alexa enabled wall plug in so it's easy to turn them on and off. -
Since this is your first foray into an all digital rig it's really hard to say what you'll find a need for. That's because it's not about digital, it's about modeling. The way you worked with a traditional rig is often due to the limitations of space or convenience. In the modeling world all of that goes away and the doors are open to a much wider range of possibilities because your entire rig is "virtual". A classic example might be you would like to design a preset where you start off with a simple, straight-forward chunky mono setup with a classic amp such as a vox with a vox cabinet and a few effect that at some point instantaneously changes to a different, more aggressive amp going through a Marshall cab mic'd differently with some polyphonic effects such as a key change and is in stereo. Not something you'd likely attempt too much with a traditional setup, but something that's easily achievable in the modeling world, but only with an LT or a Floor due to the expanded capabilities. Modeling is more like having access to a HUGE studio with a large inventory of gear that you can reconfigure at will even in the middle of a song. That kind of thing may or may not appeal to you. I don't commonly use it, but I still have a Floor unit. That's because it's better to have it and not need it than need it and not have it.
That seems to me to be a limitation of the VooDoo Labs GCP, not the Helix. You should touch base with them to get an answer
Technically that noise isn't happening between "patches", it's happening because of changes in the patch when engaging the snapshot. In other words some change you're making to one of the blocks in your preset is significant enough to create the sound when it changes. It could be the variax change or any other element since the preset remains live while the changes get made. But without knowing more about the changes it's hard to guess what it might me. Often it can be something that creates a big difference in the output volume or gain in my experience.
Really dumb question about my Helix Floor (please don't hate me)
DunedinDragon replied to LuckyBystander's topic in Helix
Another consideration which might save you a lot of time when upgrading is you can export individual presets or individual setlists to your hard drive BEFORE you start an upgrade so you can recall them as needed. -
How to Change HX Stomp Presets with a Boss RC-500?
DunedinDragon replied to paulsmusic's topic in Helix
It could very well be the format of the PC message from the RC-500 that's causing problems. In essence the Helix expects two messages to select a preset. One is the CC Msg for the preset change and the next is a PC message designating the preset number. These are technically sent as two distinct messages, but that may not be the way the RC-500 formats the message. The PC message number may also not be a direct correlation to the RC-500. For example, to select preset one you would typically send a CC:32 value of 4 followed by a PC:0. Preset 2 would be CC:32 value of 4 followed by a PC: 1. It might be useful to download a MIDI spy program to see what's actually being sent. -
Absolutely. Everything works the same in both, you just have to trim things down a bit to fit within the contraints of the Stomp.
I think you may want to be a bit more descriptive about your problem. I'm assuming "setting it to 10k" refers to setting your Guitar-InZ to 10K but it could be anything such as your low cut filter. But I'll just assume you mean you changed it from Auto to 10K. First, why? Auto should work just fine. That's the default and that's where it works at first. Did you try changing it back to Auto and see if that fixes your output problem? What leads you to think your input impedance needs to be set to 10K?
That's probably because very few people ever mess with factory presets. They prefer to just build their own by examining the factory presets and learning how to do things. Not to mention these presets change with pretty much every Helix firmware release and no one's willing to keep up with that.
The vast majority of the time harmonies (other than oriental genres) tend to revolve around the basics of the 1 (tonic), 3, 5 and 7th in the key you're playing in. Where you place them might vary depending on the sound you want to achieve. For example if you're playing in the key of C and your tonic note is C, your basic harmonies will be E (3rd), G (5th), and B (7th). However the sound of that harmony can have a different sonic feel if instead of going UP the scale, you go down the scale on some notes. So the sound of a 1, 3, 5 will be different if you play it 1 (C), 5 (G) below the C, and 3 (E) above the C. This often makes a harmony that feels tighter because all of the notes are closer in timbre. That's just the very basics of harmonies which is a very complex study when you get into it deeper. The main thing is that the harmony intervals usually need some minor adjustment out of the basic 1, 3, 5, 7 key of the song depending on the chord progression just as they do when you're playing lead.
Helix vs HD500: Some feedback as to why the sound of the HD is better
DunedinDragon replied to markwesse's topic in Helix
I have no doubt that you believe everything you say about the tone you're getting and how impressed you are about the differences between the HD500 and the Helix. I also believe that, based on the description of what and how you play, you're more of a marginal case than most of us. After getting my Helix over 15 years ago I got rid of my HD500 because I saw no need for it. And over the last 15 years I've also gotten rid of every traditional amp and physical cabinet I owned for the same reason. Everything I play or perform on goes direct to a mixing board either live or in the studio. I may represent the far extreme from the way you approach modeling, so my experience is quite different. I also have a long history of live performance and studio work dating back to the late 60's, so I'm no novice. I wouldn't say I specialize in any particular genre of music. I've played rock, blues, country, jazz, funk, punk, aggressive metal, melodic acoustic either strummed or fingerpicked using various electric and acoustic guitars as well as banjo and resonator guitars. I'm not a big advocate of drenching anything I play with effects as I only want to achieve a functionally accurate tone that sits well in a mix with other instruments and matches the feel of the genre I'm playing. Based on that description of how and what I play there is no doubt in my mind I would never be as happy with the results of working with an HD500 as I am with the Helix. The reason I say that last statement is based on the fact that I'm not trying to please myself when I dial in a preset, I'm trying to achieve a sound my audience will identify with based on their music listening experience whether on a recording or live. In all of my years recording and playing live that's only become possible with my Helix as the core unit for processing my sound. -
Practicing to music without laptop/usb - options?
DunedinDragon replied to themetallikid's topic in Helix
If you're just doing everything by ear I might suggest a simple, cheap audio interface that would allow you to plug in the Helix XLR out to a XLR input and your spotify audio output into a USB input and just use the headphone output on the interface. An M-Audio M-Track Duo would probably work fine for $69 from Sweetwater. -
Using different sounds while keeping overall volume consistent ?
DunedinDragon replied to vincentm77's topic in Helix
Peak levels are pretty much the basic core of live music gain staging for ALL channels. Perceived levels have always been more the domain of broadcast or recorded music. Pre fader signal levels have always been important but became much more important as we moved into digital equipment. Fortunately in recent year the mixing board technology has become a bit more forgiving in that regard, but it always comes at the price of automatic limiters that get engaged on the signal once it exceeds certain boundaries. A VERY bad thing in a live performance for dynamics. Generally speaking once you get your signal levels gain staged appropriately the fader positions pretty much fall in line and are relative to where the channel sits in the mix for most live setups which is ultimately the job definition for the soundman. -
I think it's important to bear in mind that the OP's post was prompted specifically by the live performance soundman's need to have a consistent signal level coming into the board, not about loudness, and those are two separate issues. Volume or loudness is pretty much irrelevant when you're going direct from the Helix into a mixing board as the OP is doing. Volume/Loudness will be controlled by the channel faders on the mixing board and will be adjusted relative to the other instruments and voices on their various channels. What needs to be managed from the Helix when going direct is easily controlled by adjusting the level on the output block which can be measured by simply selecting the output block and examining the signal meter readings on the Helix unit. It doesn't really matter what that actual level is as long as it's consistent preset to preset or snapshot to snapshot. The soundman will make the appropriate adjustments on the gain/trim knob to get the signal where he/she needs it to be in order to be consistent with the rest of the instruments and voices. Only then will they concern themselves with volume levels both for mains and for monitors via the faders. -
PLEASE VOTE: Different frequency curves for hi/lo-cut in cab block
DunedinDragon replied to Elephantstomp's topic in Helix
Add it as a comment to the original idea. -
Eleven tips on lowering fizz in Helix direct to PA
DunedinDragon replied to garybradley's topic in Helix
Personally I think the vast majority of "fizz" problems come from trying to fix it in isolation. It's only a problem when it sticks out and interferes with the end mix of things. Personally I can't remember the last time I ran into that problem, but then I don't overabuse distortion in any situation which is the most common source and I also only listen to it through my live PA with other instruments when I'm dialing in my presets. And I haven't even come close to having that problem using the new Helix cabs and mic placements. -
I don't think the driver is your problem since that's the same driver I have on my PC and it's working fine.
This has to be something with the internal configuration of USB ports on different PCs. I have my studio Helix Floor unit connected to one of my main USB ports on the rear of my ASUS PC, sometimes for hours (even overnight sometimes by mistake) and it's never timed out so it's not likely a driver problem, but simply how some manufacturers interface to the USB ports as either a direct connection to the bus versus an internal hub. I'm also on Windows 10 so it's not likely to be the OS itself, but I could see how having certain configurations of the OS or security software could play into it. I have had my Helix Floor stop working as an audio interface on occasion but that's easily fixed by selecting a different audio device such as the internal sound card on the PC then when I reselect the Helix as my audio device it functions fine.
There's really no "opinions" involved in this situation. The sound engineer is simply wanting to have a consistent signal level so he can gain stage the band. That's a simple process performed on each channel so that the signal level coming into the mixing board is at the same level on what's referred to as the Pre-Fader Listen (PFL) input which is before any EQ or mix volume output of the channel and achieved by adjusting the gain/trim knob on each channel. That's done to make sure there's ample headroom in the signal level so it doesn't overmodulate or distort, and that's the level that needs to remain consistent because the overall mix of instruments which is done on the channel faders will determine the mix of the instruments and IS done by ear. What the sound engineer is trying to avoid is having to re-adjust the gain/trim knobs because the inbound signal level varies when you change presets which adversely affects the mix. -
Using the Helix Control Floor for midi and plugins on computer or iPad
DunedinDragon replied to GoD_X's topic in Helix
Every Helix comes with the capability to connect and control external devices via USB or by the multi pin USB connection on the larger units. It's up to you to set everything up correctly to make the connections and send the appropriate CC and PC messages to whatever you're controlling. You define the MIDI messages through HX Edit program typically or you can do it directly through the Helix interface. Other than that, it's not clear what you're wanting to do exactly. You can just plug it into your Mac, but the Plugins you're controlling would have to be configured in some way on the Mac (depending on the device and the plugin) to receive MIDI commands. In the same way you can control the actions of the Helix from external MIDI devices also. It's all extensively covered in the manual. -
The simplest way is to select the output block on your signal chain which will then display the signal level output on your Helix device. By adjusting your output block level you can adjust signal level output to a consistent reading without affecting the tone of your preset. Normally at about 60 to 65 percent on that display will give you an adequately consistent signal the sound man can work with. If you have access to a mixing board you can just plug your Helix output into a channel and then using the gain/trim knob on that channel set to 12 o'clock you can adjust your output from the Helix using the output block to adjust the signal level to a unity reading (0 db) on the mixing board.
