reyrios10
Posts
11 -
Joined
Last visited
Posts posted by reyrios10
Those were god suggestions. I checked the grill and move the amp around just in case something was stucked there. Couldn't find anything. I even used a dusting air can to cleaning between the grille and the speaker.
Then I tried it with the headphones and I can hear the "blown" sound as well. So something is wrong with my firmware update. Unfortunately, I don't have a warranty anymore but I might have to take to a service store to see if it would be feasible and able to be fixed.
Unless anyone else has anything other ideas?
Thanks. Those are some good ideas that I will check today.
Once I upgraded my Spider V 120 to 1.05 or 2.0 all of my distortion sounds have this buzzing or almost like a blown speaker sound. If I downgrade to 1.01 or x.03 for example, everything sounds fine, except that I don't the classic amp setting from 2.0. So I can assume is not a blown speaker and a firmware issue.
I have tried everything I know. Factory Reset (FR). Downgrading to 1.01, FR, installing each firmware up until 2.0, factory resetting each time. Installing 1.05, FR, installing 2.0. Doing the upgrade from my iPad, from my PC using Line6 Updater, from my PC using the downloaded file. Every time I have the same outcome.
Has anyone seen this? Any other things I can try?
When in Amp mode, hit edit and scroll down to Speaker. You will see classic and full range.
I had the same issue. Support sent me this and it solved the problem:
Please do exactly this: First install the older version of firmware, the one before 2.0, then once finished performer a factory reset on the amp. Once you've done this update to 2.0 again and the issue should disappear. Let me know how you make out afterwards.
- 1
Thanks! I will give the Attenuation a try.
Application: Spider V Remote.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
at MainApplication.WindowsCommon.App.AppProperties.getAppProperty(System.String)
at MainApplication.WindowsCommon.Editor.Editor..ctor()
Exception Info: System.Reflection.TargetInvocationException
at System.RuntimeTypeHandle.CreateInstance(System.RuntimeType, Boolean, Boolean, Boolean ByRef, System.RuntimeMethodHandleInternal ByRef, Boolean ByRef)
at System.RuntimeType.CreateInstanceSlow(Boolean, Boolean, Boolean, System.Threading.StackCrawlMark ByRef)
at System.RuntimeType.CreateInstanceDefaultCtor(Boolean, Boolean, Boolean, System.Threading.StackCrawlMark ByRef)
at System.Activator.CreateInstance(System.Type, Boolean)
at System.RuntimeType.CreateInstanceImpl(System.Reflection.BindingFlags, System.Reflection.Binder, System.Object[], System.Globalization.CultureInfo, System.Object[], System.Threading.StackCrawlMark ByRef)
at System.Activator.CreateInstance(System.Type, System.Reflection.BindingFlags, System.Reflection.Binder, System.Object[], System.Globalization.CultureInfo, System.Object[])
at System.Activator.CreateInstance(System.Type, System.Object[])
at System.Xaml.Schema.SafeReflectionInvoker.CreateInstanceCritical(System.Type, System.Object[])
at System.Xaml.Schema.SafeReflectionInvoker.CreateInstance(System.Type, System.Object[])
at System.Xaml.Schema.XamlTypeInvoker.CreateInstance(System.Object[])
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstanceWithCtor(System.Xaml.XamlType, System.Object[])
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstance(System.Xaml.XamlType, System.Object[])
at System.Xaml.XamlObjectWriter.Logic_CreateAndAssignToParentStart(MS.Internal.Xaml.Context.ObjectWriterContext)
at System.Xaml.XamlObjectWriter.WriteStartMember(System.Xaml.XamlMember)
at System.Xaml.XamlWriter.WriteNode(System.Xaml.XamlReader)
at System.Windows.Markup.WpfXamlLoader.TransformNodes(System.Xaml.XamlReader, System.Xaml.XamlObjectWriter, Boolean, Boolean, Boolean, System.Xaml.IXamlLineInfo, System.Xaml.IXamlLineInfoConsumer, MS.Internal.Xaml.Context.XamlContextStack`1<System.Windows.Markup.WpfXamlFrame>, System.Windows.Markup.IStyleConnector)
at System.Windows.Markup.WpfXamlLoader.Load(System.Xaml.XamlReader, System.Xaml.IXamlObjectWriterFactory, Boolean, System.Object, System.Xaml.XamlObjectWriterSettings, System.Uri)
at System.Windows.Markup.WpfXamlLoader.LoadBaml(System.Xaml.XamlReader, Boolean, System.Object, System.Xaml.Permissions.XamlAccessLevel, System.Uri)
at System.Windows.Markup.XamlReader.LoadBaml(System.IO.Stream, System.Windows.Markup.ParserContext, System.Object, Boolean)
at System.Windows.Application.LoadComponent(System.Object, System.Uri)
at MainApplication.WindowsCommon.App.MainContainer.InitializeComponent()
at MainApplication.WindowsCommon.App.MainContainer..ctor()
at MainApplication.MainWindow.<paramValueServerInitializationComplete>b__2_0()
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(System.Object)
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at System.Windows.Application.Run(System.Windows.Window)
at MainApplication.App.Main() -
Faulting application name: Spider V Remote.exe, version: 1.0.0.0, time stamp: 0x59a0ac3d
Faulting module name: KERNELBASE.dll, version: 10.0.15063.608, time stamp: 0xadaa6ed6
Exception code: 0xe0434352
Fault offset: 0x000eb832
Faulting process id: 0x3b60
Faulting application start time: 0x01d338681bcbdb60
Faulting application path: C:\Program Files (x86)\Line6\Spider V Remote\Spider V Remote.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 8b985866-6bda-442d-88ec-e19354e9acda
Faulting package full name:
Faulting package-relative application ID:
I always have to mic my amp because if I go to the console from the XLR output it clips pretty bad. I haven't found a way to lower the output from an XLR. Is this a problem or do you know of any solution I am not aware of?
@deadlocked... Actually, you can still use the Amplifi Remote witht the Spider V. N ot the BT capability BUT you can still edit and get tone matching via USB!!! I do it all the time!
What would be the advantage to using the Amplifi Remote app vs Spider Remote? Do you get a different set of tones from the cloud?
Spider V Firmware 2.00 gets a buzzing sound all my tones
in Spider V
Posted
You could be right. If that is the sound, it is horrible. I will try to tinker with the settings to see if that helps.
