psarkissian
Service Engineer Moderator-
Posts
4,574 -
Joined
Last visited
Days Won
18
Everything posted by psarkissian
Variax 700/705 Bass Volume Pot
psarkissian replied to Mcabell76's topic in Variax Guitars / Bass / Workbench
Check with Full Compass. If it is not in stock, then see if they can special order it for you. https://www.fullcompass.com/ -
Take it to an authorized service center with experience with this product. Being a 15+ year old product, it's more than likely an issue with the main processor board, intermittent connection.
There are two kinds of XLR type AES/EBU cables,... Low impedance Mic cable at 50-Ohms for analog use. Line 6 Link or L6 Link cable at 110-Ohms for digital use. Do Not mix or swap them. Correct impedance for the correct usage, or problems can occur.
Variax Acoustic 300 'Program' Not Working
psarkissian replied to AugieM59's topic in Variax Guitars / Bass / Workbench
No problem,... https://line6.com/legacy/variaxacoustic300steel ... have one of those too. Shows how to use Monkey for checking Firmware and Workbench for doing custom patches. -
https://line6.com/legacy/variax300 Start with the manual, how to use it, how to do reset or re-install Firmware, how to use the Workbench application. -
Workbench and OS Monterey
psarkissian replied to magsterone's topic in James Tyler Variax Guitars / Workbench HD
Check the Downloads page on the site for computer OS compatibility. And that it's for Workbench HD. -
Cannot remove tone knob on Variax 270
psarkissian replied to Jae1978's topic in James Tyler Variax Guitars / Workbench HD
Very good. -
https://www.stewmac.com/luthier-tools-and-supplies/tools-by-job/tools-for-knob-and-bushing-pulling/pullit-knob-puller I've used these in my work servicing and repairing guitars. https://www.stewmac.com/luthier-tools-and-supplies/tools-by-job/tools-for-knob-and-bushing-pulling/schatten-knob-and-bushing-puller These days I use this one. Got it back when the cost was somewhat less. Some people use the two spoon method, with something to pad underneath, so the spoons don't scuff the finish. -
JTV-69 Dead? Replacement parts?
psarkissian replied to Euripide's topic in James Tyler Variax Guitars / Workbench HD
No work around, it's a older earlier one. Best to have a service center check it out. Could be anything. If they want to consult me at any point during servicing, they can through the normal technician channel here. -
And early number unit,... https://line6.com/find/service_center/ Several service centers between Cambridge, Toronto, Pickering and Oshawa. -
Using Google Translate from Italian,.... I'm a left handed guitarist so finding guitars I like has always been difficult. Today easier than once, but always difficult. Although I own 18 beautiful instruments, including vintage ones, out of curiosity I switched to digital by purchasing a PODHD 500 which, after six hard months of learning, is giving me great satisfaction. Now I wanted a Variax to explore new horizons with POD, but unfortunately nothing. No new models, no used old models. In the end I decided, also encouraged by some line6 users who had already done so, I bought a used Variax 300 for right-handers and this morning I made it left-handed. Four hours of work in total: turned the nut, disassembled the bridge and inverted the direction of the connector of the 6 piezoelectrics (there is no need to do anything else) reassembled everything, new strings, for safety even if it is not necessary, I rewound the firmware with line6 Monkey and ............... Amazing!!!! The acoustic 6 and 12 string sounds have got me guys dreaming. The guitar is not particularly uncomfortable even if it is Hendrixian. I arrive well at the 20th fret and with the bend of two semitones I play a full D, sufficient for most of the songs. The controls are a bit awkward, but don't bump your arm while playing. With POD you dream: I can store Variax models and controls in patches and go from a growling Les Paul with a Mesa to a dreamy Martin D12 with effects. Great how this has been around for 15 years and I'm using it now. I won't be selling my analog gear, but the Variax and POD will definitely feature prominently in my rig. Give it a try, it's worth it. Good job, Tris.
Help with a seemingly bricked Variax 500
psarkissian replied to barsiem's topic in Variax Guitars / Bass / Workbench
Something as old as a 500 Electric can have oxidized and intermittent solder point. Recommend a Line 6 authorized service center in your area that knows the product, they can give it check out. https://line6.com/find/service_center/ -
Monkey is used for Firmware updates, Variax Workbench (not Workbench HD) is used for creating custom patches and tunings. Original Workbench is compatible with Windows 7 and 8,... but not 10. 500 Electric,... should be able to do alternate tunings manually. That would be in the manual. https://line6.com/legacy/variax500 -
Variax 500 with MacBook M1 OS Ventura
psarkissian replied to donnief3's topic in Variax Guitars / Bass / Workbench
What silverhead said, original Workbench won't run on an Mac using M1. If you still have or can borrow an older Mac for this purpose, that might work. It's why I still keep and use a couple of previous revision Macs. Always check the Downloads page for compatibility. Thank you silverhead. -
Other volume pot options for JTV-69?
psarkissian replied to Nos402's topic in James Tyler Variax Guitars / Workbench HD
Burbank,... Valley Sound,... I know them. Use to work for Stretch at Westlake Audio Recording tech service department, back in the day. He's a really good tech as are his other techs. -
https://line6.com/find/service_center/ For the authorized service center near you. -
External Battery for the Variax 300/500/700
psarkissian replied to dgnyberg's topic in Variax Guitars / Bass / Workbench
Do not alter or modify. Certain components may fail (I can't get into which component, proprietary stuff). And parts for older guitars are scarce or no longer available, depending on the model of he older Varaix guitar. TS can drain battery faster. Yes, Li-Ion in older Variax is not compatible with older Variax. Someone tried that years ago, it ended badly for the electronics. -
DO NOT use the Cameron-Sino batteries, they are unreliable. Had a Variax in a week and a half ago,... battery would charge. I've had nothing but toruble with those Cameron-Sino batteries. I submitted a request to have the service center map checked and updated. pinfos,... no deception. They are out there. But because they are Li-Ion, they can only ship in small bundles at a time for safety reasons. They are getting through, just not fast enough.
Variax acoustic 700 stopped working
psarkissian replied to NoCoolUserName's topic in Variax Guitars / Bass / Workbench
Log a support ticket. Older product like that might be oxidized solder point or loose internal connection. Check with Line 6 Support. -
Yes,... silverhead is tech and knows these things.
Fitting a GK3 to aJTV89F
psarkissian replied to billyalfetta's topic in James Tyler Variax Guitars / Workbench HD
As I recall, the Parker Fly Mr Belew uses, has an early Variax 500 or 700 Electric processor board in it, so JTV (Standard and Shuriken) which use a different newer processor board, might not be compatible. -
Reminder,... We'd like to remind everyone that by using our forums, you are agreeing to our Terms of Use, found at http://line6.com/termsofuse.html. Please remember to treat everyone with respect, and expect the same from your fellow community members. We're looking forward to your continued contributions to our community.
