jtashiro
Posts
17 -
Joined
Last visited
Days Won
1
Posts posted by jtashiro
I'm experiencing an issue after upgrading to 1.22. When I power ON the POD GO with the volume knob and pedal set to off position, that when I turn up volume and open the pedal to full there is still no sound output of the main or amp outs. I need to leave the volume knob and open the pedal to full and switch on/off repeatedly until I get sound. Are others seeing this as well? I'm past my Amazon return window and this is my second unit - first unit arrived bricked ... ugh.
1 hour ago, voxman55 said:
This is partly why I was struggling to see the point of the Pod Go Wireless, as it would make more sense if the G10T II receiver could be powered when PGW was plugged in but without having to power up PGW.
Agreed, this is a miss on Line 6 design, but not end of the world. Perhaps they have something smart in their firmware that will offer charging in the storage unit, since it has some form of capacitor to maintain charge over time ... Nonetheless, I have other G10 Relays and will plug into to those Receivers to charge overnight when the Pod Go is powered off. Then when I power up Pod Go, I'll plugin to Guitar In jack to pair. So I'll be fine...
I agree doesn't seem right to leave the unit powered on the charge the G10. Would have been a better design to have the transmitter charge in the Storage well. I wonder if the Line 6 design team thought of this but had to cut costs and not route a phantom power supply to the storage well. Oh well, live and learn.
The manual is not clear on this point, and should be updated to clearly state, "to charge the G10 transmitter, the Pod Go Wireless unit MUST be powered on."
- 1
52 minutes ago, pianoguyy said:
delete the old tone
add the new one
I am using Amplifi Remote app on iOS and don't see an option to delete the old tone from the Cloud. Would appreciate if someone could provide the steps to do that action. I don't want to publish new versions of a tone to the Cloud.
Thanks, I see your point and am hopeful such a small technical change could be quickly delivered by the Yamaha/Line 6 dev team.
I would like to edit a tone that I have published to line 6 cloud but don’t see a path to do that. Is it possible or not? The only option I see is to create a new tone which is not my goal and will only proliferate junk tones.
When I want to go neutral I select Clean: No Amp tone and have it set on preset 01D for easy access. If you dont see that available on your device or cloud then simply create a preset.
Just purchased the new iPad 9.7" to replace my iPad Air, hoping it would fix the Bluetooth connectivity issue - no such luck. After 3-5 seconds of playback to Amplifi 150, gets disconnected. Note, this happens also with Firehawk FX and Firehawk app as well. Back to feeding from the headphone jack into the Line 6 amp Aux in for proper playback. Line 6 please put some resources into resolving the poor bluetooth support.
UPGRADE WITH CAUTION!.
Update - out of the blue, starting just after I posted that all was well, my iPad Air 2 with iOS 11 began, and continues to DISCONNECT from Amplifi 150, consistently, at the 7 second mark, during audio playback. Performed the usual steps of disconnecting and forgetting the Amplifi 150 from iPad, rebooted the iPad, shutdown/startup the Amplifi, even uninstalled Amplifi app and reinstalled ... no luck. Totally screwed up now. After a few attempts, will play past the 7 second mark. Why is Bluetooth connectivity such a problem for Line 6 Amplifi? The distance between iPad and Amplifi is about 3 feet...
- 1
Thanks. I've upgraded and all good thus far. Hopefully this will solve some of the bluetooth drop-offs that have plagued Amplifi amps...
Before I update my iPad Air 2 to iOS 11 I'd like to hear any feedback on this. Don't want to find out after upgrade that the Amplifi app doesnt work for some odd reason..
Let us know how this goes, in particular the latency of RF wireless transmission.
there are 2 BT options I have been using with my Amplifi 75. I have pair of Avantree APTX bluetooth transmitter and receiver, as well as Avantree wireless bt pro headphones - APTX technology is low-latency bluetooth. There is some latency but for my ear, it works well. Check on Amazon for Avantree APTX low latency bluetooth transmitter/receiver and the Pro headphones. You can simply get the transmitter/receiver set and plug the transmitter into headphone out on Amplifi and plug receiver into your favorite studio wired headphones (put the small receiver in pocket). If you want to go wireless headphones, then get the transmitter and pair it to the headphones - its easy.
I received a response from Line 6 about the support ticket I submitted last week. They thanked me for providing the info and will share this information with Quality Assurance team for them to look further into it.
Thanks, I had just received a new Amplifi 75 and was experiencing the same bluetooth disconnect issue as others have reported. I'll try disabling those Setting parameters and report back as well. I have an Amplifi 30 (love it) and it doesn't have same BT issue.
Hi guys I have an amplifi 150.it has only slight volume when turned up all the way with or without the app, it will play music via bluetooth not loud and sounds very tinny i have tried resetting factory presents numerous times to no avail and have updated firmware. Please help
You should check that the volume on the paired device (iOS or other) is set to maximum. Found this out with my iPad - sound is controlled by the iPad volume control in addition to the amplifier. It's not like a 'standard audio out' with a fixed volume. Hope this helps!
What does the function 2 button on the Shortboard MKII do, when connected to an Amplifi 30 or a 75? Doesnt seem to do anything.
FBV3 expression pedal died.
in FBV Controllers (MKI / MKII / 3)
Posted
Having the same issue with FBV3, volume doesn't work, but the wah/vol switch does. I've ordered replacement board from Full Compass - looks to be back-ordered and am thinking of plan B to replace the LED D1 and receptor Q1 and would appreciate some guidance as well as links to parts that worked, preferably from US parts provider.
Opened the case and I don't see any light from D1 led - should I expect to see visible light from D1?
When I wave flashlight over to Q1 I am not hearing volume change from connected Amplifi or Spider amp ... does this mean Q1 or entire board is bad?
thanks for help.
