Posts
69 -
Joined
Last visited
Everything posted by Sacco_Belmonte
Nevermind, I fixed it. Opening the transmitter was a breeze knowing there was a screw in the back of the sticker. Upon inspection, nothing was clearly bent, but I decided to lift the metal tongue that touches the pole because it might be a bit misaligned. By lifting I mean centering it around the pole by carefully wedging it up. It seems like the tongue was a bit misaligned, by a nanometer or so. I had one go at it, clearly something aligned because the unit now works as intended. Like brand new :D
- 1 reply
- 1
I bought a second hand G10 Seems like a slightly newer model, as the base LED is much brighter than my first unit. The transmitter it came with however, has a very flimsy activator pole (the small pole button near the TRS plug)...just a slight touch activates it and stays on, another tweak at it and turns off and so on...basically unreliable when it it comes to turning off. Does anyone knows why? Like a common cause and how to fix it? The unit seems ok, no signs of abuse or scratches. Maybe someone knock it while in the guitar, or dropped it, I don't know. Also, another side symptom of the loose bit is that sometimes the transmitter doesn't start charging. Is not too bad, I found its quirks, but would like to fix the transmitter.
G10 transmitter heating up while charging
Sacco_Belmonte replied to gargolo's topic in Relay Digital Wireless
I should not heat up. Not something I noticed myself. Is it hot enough so you cannot keep your finger on it? If that's the case either the base or the transmitter is faulty. -
Forum deleting text as you reply.
Sacco_Belmonte replied to Sacco_Belmonte's topic in Relay Digital Wireless
I just wrote it on the top, the forum deletes text after posting/replying. Forum admin: Please? -
Is because that specific guitar pickus up signal from the transmitter. You need an extension cable, I use a Y cable cause I happen to have that one, it's a 1 female TRS to 2 male TS.
Using two transmitters in one base?
You can pair them both to the base so you don't need to plug them each time you switch. Still, you cannot use them both at the same time on the same base, the base only listens to one signal. -
No problem with my G10 whatsoever. I actually wanna buy another base, as I bought two transmitters, I don't wanna buy a kit with transmitter...I don't need a third one. So where can I buy a base alone?
Relay G10 USB input poor design
Sacco_Belmonte replied to Driheaves's topic in Relay Digital Wireless
Got one of those mini magsafe cables. Best solution ever. -
Here fellas. Some Acoustic body IRs I did a while ago: (Stereo and Mono), I like them more than those around in the internet, as they are all mono. https://drive.google.com/open?id=1sw11vJPne33Oh9aVFctduwD3aB31esgn They work in my HeadRush and should work fine in your Helix. Works best if you use with an EQ and crank the highs up. Gitane DG300 Jumbo J200 Jazz Guitar Samick JZ4 Nylon Classical
- 12 replies
- acoustic guitar
- impulse response
(and 4 more)
Tagged with:
Stupid forum deleted what I wrote! (it was somewhat long) grrrr....whatever! Ah well...is the way these chips are. And that's that. Thanks for your answer.
Question: Can one use reverb IRs in the Helix? such as some long verb out from a Bricasti unit in wav format? Thank you.
I guess by now is about time Line 6 releases an updated receiver base with a beefier USB connector. Mine hasn't failed, but I'm extremely careful and the base stays always in it's place. Glad I have a few soldering stations though. -
Wireless transmitter inside instrument, anyone?
Sacco_Belmonte replied to cags12's topic in Relay Digital Wireless
Yeah I guess something like that would work. -
Correct. With the ATG I do need the L shaped adapter, otherwise it will not work. It does if I turn off the unit and use the provided pickups. -
Ah cool :) buenisimo! -
I also have an ATG guitar. Honestly the transmitter doesn't introduce any noise on that system. (not at least from the plug position) You can pull the plug out, connect the transmitter and wave it close to the circuit to see what happens. -
At least on my shadow active system, which has the plug in the circuit box. The noise is unbearable, I need to use a 30cm cable to put the transmitter away. Just saying. -
the angled metal one works on all my active guitars. the only real problematic one is my shadow system for maccaferri guitars. the circuit box has the plug on it and the transmitter being so close induces noise. For that you'll need an extension cable to put it away or just use a regular cable. Besides that all my active acoustics work, also my ATG equipped guitar. I suggest you to buy 2 or more of these plugs, the male plug part is inserted into the female cylinder and is not soldered. So one of them already came off. I bought some more for that reason, and I'm gonna try soldering one to see if it helps.
Or even worse. The wireless signal getting into the hot signal inside the circuitry. The transmitters are generally clean, but if you put it too close to a hot wire you'll hear it quite clear. -
At least one of my transmitters (latest FW) discharged while plugged in the guitar. It turned off after 4min but I picked it up some days ago and it was depleted. Oh well....
G10 high pitched overtone.
Well, a firestudio project costs around 350 Euro. And has 8 high quality pres and high quality DA converters too. Also SPDIF and ASIO. At half that price the G10 has only 1.....and you tell me they couldn't make it better?
