Kilrahi
Members
  • Content Count
    1,431
  • Joined
  • Last visited
  • Days Won
    27
Everything posted by Kilrahi
  1. That means you have the expression pedal set to switch between expression 1 and 2. I don't have my Stomp by Mr right now, but it's a global setting. Do you actually have an expression pedal with a footswitch? Because if it's just a regular expression pedal, no toe switch, try a TS cable first.
  2. Kilrahi
    HX Stomp FAQ
    Only if there isn't an amp/cab block since the HX Effects can't do that stuff.
  3. It kind of depends on how much you want to spend and how many options you really want, but in my opinion one of the best decisions I ever made gear wise AND budget wise was the purchase of the HX Stomp ($520 after coupon) + Helix Native ($100). Seriously loads you up with insane options.
  4. As a fellow hobbyist, aren't we the ones who have the least to risk of all? And as for that "risk," I really don't think it's very much risk. I updated to 2.71, 2.8, and 2.81 day one, without hesitation (well, I had to wait for work to end, sadly). If you live in the US, Line 6's customer service is practically bullet proof at this point. If tomorrow my Stomp becomes sentient and tries to kill me, I really have zero fear that Line 6 will send a swat team over to take it out and then replace it with a new one.
  5. That's one way to do it. Or simply put the Talkbox in the FX loop and turn the FX block on, but then if you use it it will be impacted by reverb. So if you don't want that, then do like your idea above and chain them.
  6. Kilrahi
    My update story
    I am not doubting the experience of people like the OP who say that their update process was a hairball. However, I can only speak from the perspective of what I've experienced. The Line 6 products I've owned are two Spider amps, a Pod HD500X, a Firehawk 1500, and a HX Stomp. Every single update has been a painless process. I got KIND of apprehensive when I was doing the 2.8 update for the HX Stomp, even though my thinking was that if I were to run into problems, it would probably be on the devices that were not already on HX Core. However, despite my apprehension, it went off smoothly in a matter of minutes, and I was cranking out that blessed KOT sound in no time. However, I tried to plunge a toilet the other day and that was a very lollipop ordeal, so I don't lead a charmed life if that makes you feel better.
  7. It kind of sounds serious, unfortunately, but if it were me I would try a factory reset. Turn the Stomp off, and then turn it on again, BUT as it boots hold down footswitches 1 and 2 as it boots up. If still no dice, yeah, the support ticket is the next step . . .
  8. Yeah, I finally tried it on a whim the other night. I really had been pretty focused on the King of Tone model, but WOW . . . that thing is awesome. I may end up loving it more than the King of Tone (and I love the KOT).
  9. Kilrahi
    HX Stomp UI freezing
    I haven't had anything like this happen, but I haven't tried to do the exact setup you are trying either. Since you've done a good job of documenting everything, I would open up a Line 6 support ticket and get their take on it.
  10. It depends on what you're asking. Firehawk goes great into a PA, and great with the four cable method into a real amp. If you're wanting to do both it can get harrier, especially if you're wanting to use the Firehawk's modelled amp and cabs for the PA (in which case I think you have to choose one or the other, real or modelled, not both).
  11. Well, that kind of depends on what you want. What if I asked you, "Are all speaker types and brands the same thing?" Right away you'd be thinking, "Uh, not even close . . ." Now, are there tons of great FRFR options out there? Absolutely. Powercab is my favorite, but if people are on a budget I recommend the Headrush 108 for 112. Seriously though, there are a lot of solid FRFR options out there. The advantage to the Powercab is it comes closer to nailing that "amp in a room" sound that a lot of people miss going with modelers.
  12. You can't do that. It's one or the other.
  13. Could you provide a few more details? What other pedals are you hoping to combine with the Stomp? Including those pedals, what is the actual exact signal chain you're wanting? (Example: Boss DS1 >>> HX Stomp >>> Amp >>> Strymon Timeline)
  14. My school focused on problem solving and critical thinking in a way that, in my opinion, is not taught anymore. I usually solve my own problems or find existant material that does and I think some of it came from that. This most recent update was clearly a hairball brought about by L6's discovery of a way to improve their product in a way that they never originally envisioned. I don't know that there was an easier way to bring it about or I'm sure they would have done it. No company WANTS a complicated update.
  15. I wouldn't say it's THAT big (though I understand everyone is different) but it is very close .... very ... close ....
  16. There's an ideascale on this if you want to vote for it.
  17. Yeah, it does go a bit faster, but there is still a bit of a delay.
  18. Did you make sure in the global settings that the Stomp is set to pass on Midi messages? You have to go to Global Settings > Midi/Tempo > Midi Thru > On, and Global Settings > Midi Tempo > Midi PC Tx > Both. Keep in mind the HX Stomp is not a midi controller. It can only pass on either its own program changes (so if you are changing from program 20 to program 21, it's going to pass on to your Multiwave Distortion pedal "PC 21," and there's no changing that) or program changes it receives from an external midi controller. You can't tell it to pass on to a second device "PC 2" unless you are selecting "PC 2" on the Stomp or you have a Midi controller sending to the Stomp "PC 2" which it then will also pass on to your Multiwave Distortion pedal.
  19. Kind of. I have the Firehawk 1500 and I love it. The processor for the Firehawk modelling in the 1500 is actually slightly more powerful and a little faster than the original Firehawk. There are some key differences though. In some ways the 1500 is closer in comparison to the Powercab 212 with its stereo separation capabilities. The neat thing about the 1500 is it's been designed to provide a pretty amazing amount of stereo separation between all of its various speakers. The Firehawk also has bluetooth connection ability which is pretty cool, and an awesome rig for practicing along to backing tracks. Those are pluses for the Firehawk when comparing it to the standard Powercab 112. However, there are some strengths that the Powercabs have that the Firehawk does not. The biggest and most obvious is weight. The 1500 comes in at a massive 63 pounds. Really, to gig with the thing you need to buy the carrying case which is another $200. Next, the Firehawk is a solid flat response speaker, but it does not have the cab modelling abilities that the Powercab has. The Powercab was designed to mimic the "amp in a room" feel that a lot of traditional people miss, and so it does that where the 1500 does not. Finally, the Powercab 212 offers a lot of the stereo strengths that the 1500 offers, but weighs A LOT less. I love my Firehawk, and use it for a ridiculous number of things (guitar amplification, stereo speaker system, attaching it to PS4 or other movie player, blasting music from a parade float, etc.). It's incredibly versatile and powerful. However, I bought it BEFORE any of the Powercabs ever existed. I later bought an HX Stomp to supplement (and by supplement I mean largely take over with the 1500 stepping in when I need more DSP) the 1500. If I could snap my fingers and do it all over again, my dream rig would be a Helix LT + a Powercab 212. I just think that the speaker modelling, IR loader abilities, significantly lighter weight, and the simulation of the "amp in a room" feeling push the Powercabs ahead of the 1500. Still happy with the 1500 though. I'm keeping it for a few years yet . . . maybe I'll jump on the bandwagon of the NEXT big multi effects unit and FRFR speaker system.
  20. Ummm, no. Yes you can do that, but it doesn't compare at all to a solid acoustic amp.
  21. Kilrahi
    HX Stomp
    Ummm I'm confused. In snapshot mode the switches are never another color besides white. That's how it's always been.
  22. Interesting . . . well . . . I always liked the sound of it. lol It does have an acoustic setting though as one of the defaults. How can they pull that off without a tweeter?
  23. Maybe . . . I have the 20 though. Got it for my son, and to me, it's perfect. I keep hoping they give it the new update eventually. It's honestly not necessary, but more features is always cool.
  24. In my opinion, XLR all the way. Nice and clear exactly as the amp has it. About a hundred times easier too.
  25. I don't see how that could possibly be true. A acoustic cab is just a fuller range cab with a bunch of EQ. That's it, and like you said, you even have the option of IRs, so I don't see what we'd be gaining with the model of an acoustic amp.
