Pull-OH
Posts
4 -
Joined
Last visited
Posts posted by Pull-OH
Playing in a fairly loud rock cover band, I tried the Spider V120 at first, with the volume dimed, it was just about the right level. I traded up to the Spider V240.. which fits the gig perfectly volume wise.
As far as stereo sounds... I honestly cannot hear any stereo effect.
I record with the XLR mono output to my DAW Audio interface.. it sounds great. Never tried micing the amp, never tried the USB interface either.
The amp sounds great at low volumes. i originally expected that the tone would be the same at all volumes, but there does seem to be an increase in treble when the volume goes up. Keep that in mind when you set up tones at home and then bring them out to play with the band in a volume environment
May you upload any example of your records?
Thanks for the advice I am going to keep this on my mind! ;)
I bought both. The 120 is great for my 9x9 studio, but the 240 is better suited for gigs in larger rooms. Since the presets are the same on both amps, I backup the presets to my PC and any changes I make to one amp I can duplicate on the other amp.
The advantage that the stereo gives you are some sound options for more significant echo, chorus and other effects that are more pronounced with 2 speakers. But using stereo effects live gives your sound engineer a more complicated setup.
Did u had any experiences with the recording ? Usb or XLR output or Microphoned?
Anyway the differences it's about 40 euros for the 2 version, I think it's worth to spend those money for the double of the power!
I am going to receive the amp at the end of this week (hopefully)
Thanks anyone for the answer, waiting for some recording experiences feedbacks ;)
I initially bought the 120 figuring it would be loud enough to keep up with a loud drummer, wanting the most portable rig possible. I had a Fender Mustang 100 that was plenty loud.
Unfortunately, the 120 wasn't loud enough to keep up with our drummer, so I swapped it out for the 240 and couldn't be happier.
The 240 is plenty loud, the sound quality is enhance with the 2-12" speakers and and stereo output. If you're playing metal I would definitely go for the 240 because you're going to need more power for the bass heavy metal tones.
That's the answer I was looking for!
I think I'll go with the 240! ;)
Thanks Maaaan
Hi eveyone!
I am thinking to buy the Spider V, but I actually tryed just the 60w version of the amp, and I actually like it!
I actually play Death-Metalcore and I need this amp for recording at home (USB/ Emulated Output to Audio interface / Shure SM57), and also to play some live concerts (small gigs) and with my band in small practise room.I am reading about REALLY BIG differences between the 120w and 240w version about:
-Volumes (people changed their 120w with the 240w because it was not enough loud to play in live concerts)-Sound Quality (stereo vs mono seems to make a big difference)
Since I don't have the possibility to try them in the store, is anyone able to tell me if there's really all this big difference?
Is worth to spend more money to have 240w?
Is really the 120w not loud enough?
Is the 240w good to play at low volumes?
Also, did anyone have any issues about latency while recording with USB ?
Thanks everyone! :D
Keep playing :lol:
PROBLEMS LIVE SETTINGS: WHISTLE - NOISE
in POD HD
Posted
Hi everyone!
I am a begginer with PODHD 500x, that's why I need your help.
I dowloaded differents patches from the LINE 6 website, and when I tried them at home everything worked fine.
When I went to play with my band in our small room, I attached the POD direct in front of a combo (LINE 6 SPIDER IV - CLEAN).
Problem is that when I play a distorted patch, it start to whistle and make unsupportable noise.
I read on http://foobazaar.com/podhd/toneGuide/setup
This that I report:
"I recommend setting your output mode to the appropriate non-"Studio/Direct" mode. If you want to use your Pod for both "direct" and "live" purposes, I recommend leaving the output mode as "Studio/Direct" and setting your "live" patches up with "no cab" as your cabinet selection. When you use "no cab", you get the same output in every output mode (more-or-less) - all cab/mic simulation is simply disabled. "
Now what I would like to try is to set INPUT 1: GUITAR and INPUT 2: VARIAX for all the patches;
And then I would like to put this "no cab" suggested, but I don't really understand how to do this.
About the "mixer" Path A and Path B should be Centered ? Or should I leave it 100%R and 100%L?
May you help me through this? Any other reccomandations?
