celil
Posts
5 -
Joined
Last visited
Posts posted by celil
Are you solved this problem?
No unfortunately I still have the same problem with a little change. This time it goes to preset B (FS6) instead :) .
The problem with swithing does not show itself so often though. I also use a tube screamer as a backup in case it changes in the middle of a solo... So that I can boost the channel and be safe on stage. It's a shame such a nice unit has this kind of stupid problem..
Pitch shifter has the same delayed/echoed sound even without any effect on. It seems like the sound is not seamless, but a processing error is happening... :(
My first problem with POD HD500X is that, it switches itself to preset A (FS5) and sometimes I can not go to other presets or open the tuner. This problem is temporary, sometimes it works fine. This happens especially when I press FS1 to activate an effect.
I tried to install the latest firmware, and did the global reset on the unit by holding the LEFT ARROW (<) button as I plug-in the Power adapter. But the problem was not solved. I suspect of a switch error.
Another problem I face is when pitch shifting, the sound is not sustained, but delayed. As if there is an echo on. I do not have any other effect on. Just amp/cab simulation is on with pitch shifter.
Is there any solution to above problems?
Thanks in advance
I exactly have the same problem with you. Sometimes my HD500X is stuck in preset A, I can not change anything or open the tuner etc... Or it switches itself to preset A when I am on some other preset. Sometimes it works perfectly and no problems happen... I am crazy about this problem as I have no warranty left... Could you be able to solve this problem?
Hi there,
I am using HD 500x for about half a year. The problem started week ago. I am using ABCD mode for switching presets.
When I switched for B,C or D preset it automatically is switching back to preset A and I can not switch to any other preset. Even when I am using preset A and I am trying to use any of the additional switches to add delay, reverb or whatever other setting assigned to top 4 switches it is coming back to original. It happens after 10 or 15 minutes of normal use. In the worse scenario I can not use Tuner because it is keep on switching back to preset A.
I used monkey to reload flash and it did not change anything. I am using normal guitar and variax. I was thinking that maybe my variax cable is making that error but it is not the case.
Please help solve this problem. Right now HD 500x is completely useless.
POD HD500X switches itself to preset A (FS5) and sound problem with pitch shifting
in POD HD
Posted
I bought it more than a year ago when we go with my band a tour in Germany. It does not have a warranty left, and I live far away from the shop.. I'll try to do your comments, thank you!
