shane01
Members-
Posts
26 -
Joined
Last visited
Everything posted by shane01
I've sorted it now , Thanks anyway, Reason being = I'm a Fu$%^ng IDIOT!!!!
- 21 replies
Hi thanks for replying, Yes all from your post as per the letter, Can i ask what all your Global settings should be?? Nothing is being sent to the JVM?? Thanks in advance
- 21 replies
Sorry Guys i need Help?? Tried the OP post first and everything went fine ,,, As per should , Did the 3.15 update and now the helix won't talk to the JVM205H???, Nothing is changed maybe from some internal setting on the Helix LT??, can anyone assist ???, I Know it's something stupid but i'm lost???, I've reset the JVM 6 times??, Are their any settings apart from MIDI PC send , i need to adjust?? Thank you in advance. Shane
- 21 replies
I have installed the new firmware to my dt amps so I now can have eight amps instead of four ,but was wondering when using the HD500 and selecting a amp with topology i ,ii ,iii, iv will the new installed amps topology be used with the pre set ? I mean the original top's were i=fender ii= park/marshall iii= vox ac30 iv=high gain , Now I have different amps installed will those top's change , I know when using the amp on its own it will be different ,or is there only four top's for what ever amp is used. If I don't make sense i'll try to think of a better way of putting it. Thanks
variax what amp for acoustic models?
shane01 replied to shane01's topic in James Tyler Variax Guitars / Workbench HD
Thank you. -
Any news on this unit becoming DT compatible?
Thanks guys , I tend to switch the cabs off and use the sound of two of my Marshall 4x12 greenback cabs ,With the cab set to 'off' I take it none of the res',thump' works is this correct?. It still is on the screen ?
Thank you guys I see now ,you just set the other input to a unused instrument , I will never use mic so set to mic it will sort of shut it down . Thanks. I have played for 25 years and have 15 marshall 50/100 watt heads so I have some knowledge of sound but just bit the bullet and bought a dream rig,JTV59 hd500 and dt50 head and dt25 head so it's a big learning curve at the mo. Thanks again
Hi all, Regarding a HD500 This is soo easy for some of you but I just can't see it ,I see in a lot of post's about just running through '1 input ' and silencing the other ,or running both inputs in the signal path, How do you silence a input? Thanks in advance.
That make sense thanks fella's.
Hi all, I have a mission volume pedal not the l6 expression one just a standard volume pedal , now if I try and put it into guitar2 input and use the mission as the volume and the onboard exp as a wah, do I have to input through the input of the mission first ,I tried it but got no sound as I was using variax VDI input to the hd500 ,so in a nut shell will the volume pedal work with no input and me connected via VDI ? Thanks in advance.
I am in the same boat buddy I need some info. Anyone? Thanks in advance.
no windows 8, can get it to load my pc cant read the file ,,never mind.
HD50 head wanted must be in great condition cash waiting , also willing to ship to me In the uk if too far to collect.
I am getting a hd500 in the next few days I already have a hd400 if I save my presets to my pc can I load them into the 500 so I dint have to start all over again or is it a different machine?
Thanks jandrio,
Thanks again Phil, my monkey is 1.71 seems the newest one I can find. where do I find the JTV 2.21 please? as I mentioned in my edit I see the 1.80 is from 2012 .I have the hd workbench ,when you connect to the hd bench does it send the new hd models to the jtv? sorry once again I just need a help to get up and running. what should I have on the guitar to assume its the new hd models? any tell tale signs? Edit thanks again I think I have found it.
Thanks for the reply I have got the latest line6monkey and the HD workbench all installed does this mean the new HD guitars are in my jtv59, I cant hear any difference cant find any download for version 1.80 anywhere ,the monkey says all updates are up to date how can I tell if I have the new hd models in my guitar,, sorry for noob q's but I only got the guitar Friday. Edit. looking at the 1.80 came round in 2012 so I guess my new jtv will have it in already,, correct?
Hi all, if I downloaded the new hd workbench does that update the guitars to the new hd aswell or is this a different update I cant seem to find it on its own?
Ok guys I get the idea ,save me looking for tone that is not there. Thanks for the heads up. -
Thanks for the reply but I have no PA or FRFR speakers what would do the job via the HD400 ,can I bypass the amp and use a power section. I am new to this stuff but been playing 25 years -
Hi all, If I have the line6 link running from my hd400 to my DT50 can I also run a 1/4" jack from the unbalanced outputs to another amp ,,Will this work running two amps? I know the topologies will only work on the DT but will the amp models and effects work on the other amp Thanks in advance.
Hi all. I am waiting on a variax jtv59 coming tomorrow I have a dt50 and a hd400 ,so what I would like to know is when using a acoustic model on the variax what amp should the dt/hd400 be set to , or do you bypass the amps I have no idea please give some tips please ,I know it wont sound pure acoustic through my greenback loaded 4x12 but what amp is what I need to know. Thanks in advance.
