Posts
6,255 -
Joined
Last visited
Days Won
77
Everything posted by TheRealZap
What Is Better?jtv Or The Old Variax 700?
TheRealZap replied to arislaf's topic in James Tyler Variax Guitars / Workbench HD
there's absolutely NOTHING better about the older variax.... NOTHING.... there may simply be some things that some prefer.... but that doesn't make them better.... everything about the JTV's are better by design. you can have and keep your preferences... but make no mistake.... -
Pod Farm 2.5 gifted with no activation
TheRealZap replied to slayvant's topic in POD Farm / POD Studio / TonePort
you might need to contact support... because it should just show up in your account, enabling the license manager to take care of it.. there is no activation code. -
i have a couple of different macs that ive tried on... the newer one (late2012) with usb3 ports still has issues my older on (mid2010) with usb2 ports works fine. just FYI
there is no amplifi utility for windows... i think you mean the line6 updater... that is on the downloads link in top right corner.
Why is there no drivers for Mac for Amplifi TT? Help!
TheRealZap replied to cadams22's topic in AMPLIFi
the amplifi TT is class compliant and does not require drivers. -
they're usually pretty straightforward "dumb" controllers, i can't recall seeing this issue... but at its heart every switch on it sends a midi command. i would call the support number they might have some things they can walk you through.... http://line6.com/company/contact/
is the usb connected to the FBV? it wont work the amp if its connected.
how did you get to this thread and miss the fix... that's long posted.. .and long working..... Follow these step-by-step instructions to temporarily remove the Avid CoreAudio driver: Open the Finder and locate the following folder: Macintosh HD > Library > Audio > Plug-Ins > HAL Copy the "Avid CoreAudio.plugin" to another location, for example the Desktop. Delete the "Avid CoreAudio.plugin" from the HAL Plug-in folder. Type in the admin password when prompted. Restart your computer.
Model differences between Variax, JTV and Standard?
TheRealZap replied to mgroves's topic in Variax Standard
No. you cannot even use the old firmware on the standards. (taking all the old models...) new models only.... -
Spider iv 75...Dont undestand volumes??
TheRealZap replied to ChuchoMaGu's topic in Spider IV / Spider Online
i may be misunderstanding the question... but yes if you hit save after adjusting it will recall the tone as it was saved... the master volume will not be recalled..... that should be the only adjustment you need to make and you're patches should be "relatively" leveled before hand.... -
Sonic Port VX/Pod Farm/Mac OS
TheRealZap replied to tarotmusic's topic in Sonic Port devices / Mobile In
you can use pod farm with the VX.... it does not come with a license though... and the license with your UX1 is tied to the hardware.... but if you buy a pod farm license... you can use the VX with pod farm. although i didn't check any numbers... there was no noticeable difference in latency.- 2 replies
- latency
- direct recording
(and 1 more)
Tagged with:
link toneport ux1 to garage band
TheRealZap replied to jmackc's topic in Computer Audio Setup and Troubleshooting
you may have to change the input in syspref... (unless its a condensor mic, then you may need phantom power) as far as cutting out the sound.... you may need to check for the latest driver? -
toneport ux2 and macbook pro with yosemite
TheRealZap replied to jmills23's topic in POD Farm / POD Studio / TonePort
Pod farm replaced gearbox long ago. Try pod farm if that's the case. -
FW 2.6 and License Manager problem with Pod HD (Bean)
TheRealZap replied to xpanmanx's topic in POD HD
make sure you have the latest driver.... and the latest license manager.... if you havent already.... http://line6.com/software/ -
then remove the app, download from the appstore and try again.... step 1 anyway... :) (if you havent already tried it....)
Line 6 Edit wont open
TheRealZap replied to a1terrier's topic in POD 2.0, POD XT, Pocket POD, FloorPODs
try removing java... and reinstall edit... edit will install the version of java it wants.... will probably work if you update from there.... but it wants that version to start.... -
Pod Xt Live Problem...
TheRealZap replied to brenocunha's topic in POD 2.0, POD XT, Pocket POD, FloorPODs
well the latest (and final) firmware is free.... so worth a try... -
no, the standalone use topologies include the preamps... with HD... the topologies just configure the poweramp section.
Can I update Helix's Firmware without Line 6 Updater?
TheRealZap replied to IanKach's topic in Helix
there is of course other ways... that they are not supporting or releasing.... that's how they rescue "bricked" units in service departments for many products.... typically a set of libraries and a command line app with lots of various switches... i don't expect them to offer any way outside of the current updater utility.... the utility does more than just change the software on your device.... it can also do other maintenance required with a new firmware.... for example modifying existing presets to include new parameters, changing internal settings, etc.... -
not sure what the issue is... but it's 100% downloadable... they do not ship cd's
No. might try a virtual machine if you dont have access to another machine. -
The old Line6 forums.... Can the content there still be accessed?
TheRealZap replied to MaxDread's topic in Line 6 Lounge
you can search it here: http://line6.com/supportarchivenew/ -
i never said it was up to you... and that it shouldn't just work... i just said that most would rather try those few easy things i suggested... because they could be alot easier than calling etc... not every issue is the same and maybe yours was different enough.... but no harm in trying a few things....
i've reflashed many times with the :0 code in the corner... being part of the beta.... it does not mean it 100% needs replacement... i can assure you of that.... many things you can try before return/exchange.... other computers... (mac el cap is the worst for this!) other ports, restarting computer etc.... and by all means contact line6 support...
