knoxdaz10
Members
  • Content Count
    100
  • Joined
  • Last visited
Everything posted by knoxdaz10
  1. knoxdaz10
    Best Power Amp for Helix
    powercab no good?
  2. knoxdaz10
    Helix floor footswitch failing ?
    contact cleaner maybe
  3. knoxdaz10
    Helix or Powercab as my soundcard?
    hi guys i got myself a powercab plus to go with my helix floor. its really great. but i have a problem because i use ableton live on a pc, means i can only choose 1 soundcard. Either the helix or the powercab. what i really want is to record the powercab, but use the helix for playback of abelton because thats where my monitors are plugged in. (into the xlr's of helix) thx in advance for ur help guys.
  4. knoxdaz10
    i think i know why i thought Reaper did 2 soundcards at once. when i used to use reaper i was on a mac. with the Aggregate Soundcards
  5. knoxdaz10
    i just went into reaper and ur right. why was i thinking different? i think because everything was set for the focusrite. sorry man i made a mistake there
  6. knoxdaz10
    you basically never need to look at Ableton, and never need to touch the mouse. it can be in the background while u have youtube up or something, and it still works with Push 2
  7. knoxdaz10
    ya i can write and record songs with 0 touching the mouse. all with push 2
  8. knoxdaz10
    or being able to select ONLY usb1/2 AND Digital. but nothing else. that would fix it. (in ONE output block on the Helix)
  9. knoxdaz10
    or i can spend more money for a 3rd soundcard and run all the outputs of the line 6 gear into it. which is what i used to do but i cant do that anymore because it broke and it wasnt any good really just a focusrite. i been eyeing the universal audio soundcard...
  10. knoxdaz10
    this is an ableton problem really. as you can only choose 1 soundcard. where as using Reaper i can use as many soundcards that r plugged in i like. but making helix and powercab share the same soundcard would make everything so easy
  11. knoxdaz10
    the helix is 1 soundcard. and the powercab is a 2nd soundcard. both have there own usb port on the pc. seamless would merge the 2. i dont think u understood that part
  12. knoxdaz10
    maybe they will update the helix and powercab to work with better routing, maybe instead of multi on the output, we could choose exactly what we want. or make helix and powercab seamless so that we only need 1 soundcard
  13. knoxdaz10
    but my main issue i think is that every patch i make has to include the path 2 being split like in my patch i uploaded https://line6.com/customtone/tone/4384526/
  14. knoxdaz10
    this is my patch i use with the Powercab on the helix. https://line6.com/customtone/tone/4384526/
  15. knoxdaz10
    1. Helix signal path without cab block plugged straight into Powercab. (so i need to set the output block to Digital, because Multi will have the guitar coming out my monitors on performance 2. Powercab using LF Raw as the amp in the room sound. 3. Output from Powercab to DAW w/DAW set to use Powercab as sound card. ( this wont let me playback my DAW from the helix XLR, if Ableton is set to use powercab as the soundcard.) i really need helix for playback in Ableton, and to Record from the Powercab. sux because i can do this so easy in Reaper. but i just got Ableton and i wanna use it lol
  16. knoxdaz10
    yeh i really want to record what the powercab is doing. i have to split every patch i make at the end of the chain (so it takes up both bottom rows), with one output with a IR to USB 1/2. and the 2nd output goes to DIGITAL which is the powercab. im not sure what to do
  17. knoxdaz10
    Preset volumes
    channel volume of ur amp is where u do it
  18. knoxdaz10
    Looking for presets
    if u just want to use someone else's presets and not do the work yourself, fremen has some great ones. ive brought all his patches and u will find a goto few in his packs that are great and also help you by showing how he makes them. especially for headphones, his patches rock
  19. knoxdaz10
    Drivers
    line 6 updater not working?
  20. knoxdaz10
    im jones`n for this new 2:80 update
    i was planing on buying either a revv pedal or maybe the amp, but since i found out about this new update ive been holding off. gonna be a great day when it gets here.
  21. knoxdaz10
    Delaune vs Fremen vs MBritt patches - a review
    i agree all 3 are good. others who sell presets should take a note of these before just willy nilly selling patches after 1 month with the unit. rhett "cough cough" shull
  22. knoxdaz10
    i love the fremen patches the most. perfect for headphones or monitors. but after getting the powercab, i can just load up one amp and use lf raw mode and its great without even making a preset. just choose an amp and go. then i use the frfr mode for fremens patches
  23. knoxdaz10
    FRFR is good, but LF Raw is really fun!
    im not
  24. knoxdaz10
    Confused about the use of Volume Pedal
    put the volume pedal right after the cab or ir. then ur delays and what not after that so you still hear them
  25. knoxdaz10
    wow i just tried the LF Raw , omw! sounds so good
