TLF2007
Members
  • Posts
    179
  • Joined
  • Last visited
Posts posted by TLF2007
  1. The Poly Pitch will do this. Add it into a patch, set the interval +/- as desired, set the note sync and return time either in ms or beats by tap tempo beat interval and it gives a similar effect. Its a DSP hog tho' so be forewarned.
    EDIT: Remember to change the bypass to a Footswitch and set it to Momentary
    • Upvote 2
  2. I really like the Reverb on the catalyst and being able to tune it for the room by walking over to it to quickly adjust (I use very little anyway) is much easier than adding a reverb to the Helix.  I use the FX loop option rather than the Power Amp option and set the signal to line with volume at 1200 on the Helix so its right in the sweet-spot of the amp and allows me to have that reverb on the amp. ( You lose it if you set to Power Amp) . All amp models (only 2), no cabs, are on the Helix or POD Go (backup) and this works pretty seamlessly and the DI is consistently good this way with a 2X12 SM57 out of the Catalyst in a band mix. Pod Go is the same. I tried using the Clean/Dynamic and Boutique as pedal platforms and have a couple chains set up for a straight through situation,  but this way I didn't have to have 4CM and I have blocks to spare even with a couple effect heavy patches.
  3. The amount of lanes is reduced from the Helix which would be a drag for my acoustic thing with another guitarist and vocal process etc. Also looks like less overall model/patch availability but I don't ever come close to max out the Helix as it is. The lack of an editor is a bit of a killer for me. I'm surprised there aren't any captures out there at time of launch maybe they will do them soon or via a third party. I liked how you could capture pedals but I'm sure controls wouldn't exactly match. There was a baseline set of controls to set for the capture so at least the clone would have a tonal reference. I think the Headrush in general stuff sounds fine when compared to the Helix. Definitely different but for a PA/cover thing, more than fine (at least to me).  The thing is BIG and a shallow comment: I don't like the color scheme with the gold.
  4. On 1/13/2023 at 5:31 AM, cumminsn said:
    This one caught my eye,as I recently moved to my first paid DAW in 16 years(Studio One 6 Pro),and from the get-go have been having severe audio distortion on playback,even with the simplest single stereo audio track with no plugins,with the Helix as my USB interface.It works fine with my other DAW(SONAR) and Wavelab,and Studio One works without issue using my Focusrite USB Interface.So some sort of interworking issue between Helix ASIO and Studio One.
    PreSonus support sent me straight to Line6 without any attempt to investigate,so while I'm on my fifth day of waiting for Line6 Support to look at the ticket,I may try the above suggestion as a workaround.
    I've had similar issues in Studio One with the Helix (versions 4 & 5). I ended up using Asio4all whcih allows me to use my Focusrite Scarlett for playback but also record form the Helix simultaneously. Its not the cleanest thing but works well enough.  I only find I have to re-assign lanes once in a while in "song setup".
  5. Ha- I did the original JSON edit that was around that kept the EQ and Amp but tried the same thing before and it does indeed work but its flaky beyond 7 effects .  Since there isn't a Wah option in the category list I kept that and opened up 9 other slots to try and make a very flexible in-front-of-amp patch for quick jam get togethers which is mainly what I'm using this for over lugging my Helix around.  If you try to make a patch with that though that is beyond 7 additional effects it wipes the patch on the unit etc. I made a send/return variant as well but haven't used that one yet. If you use the eq/amp included JSON patch that removes the volume / wah, etc,  but keeps the Amp, the Del Sol amp uses very low DSP and is very stable. I'm only 'really' using 4-6 blocks per patch with different mods / delays or grit box types etc. Hoping they actually integrate this feature in lieu of doing this patch mod. Being able to do this was the decision to keep the unit versus letting it go for a different compact option, actually.
  6. As another had said, when looking for a Helix backup, I went with the Pod Go. It's very similar in terms of use, etc so it was a no brainer. I used the JSON patch edit technique to get some active additional blocks on the Go and as stock, there is plenty of DSP for a cover situation. Its to the point where if I'm just going to jam with a bunch of different, non-gig, situations, I just bring the Go with an Amp or No Amp set of patches and it meets the needs. I tried the HX Effects. It definitely seemed very powerful but the Go is sonically similar.
  7. I did the script edit out of the box for one additional free block and it added a huge amount of flexibility. Hope they recognize and add that in some way so future firmware recognizes it and we don't lose it. I use this as a gig backup to the Helix and its not paramount it remains but it made my life in interface usability and getting "close enough" fast a game changer. I've faced a couple DSP challenges that don't dissuade me from thinking differently about patches and getting very close for cover work. Moreover, for the price of the Pod Go to the Helix, that added functionality "felt right" in terms of value/cost/feature set.
    • Like 2
  8. I play guitar and bass in bands. So I'll be subjective that while its difficult to replace a bass player,  I've done the Local H / Japandroids thing in a couple side projects for that kind of effect.  I send my signal to a path and pitch shift down and EQ out as much high end needed to eliminate the transients. Here is a template I did: https://line6.com/customtone/tone/3047449/. I've also gone in other direction, as others have, making pseudo power chords up an octave from a bass line, which is more fun than I can effectively communicate.
  9. On 11/16/2020 at 12:35 PM, DugT said:
    Did you find a way to replicate the Boss Tera Echo effect? I love that effect and was considering upgrading from a Boss GT-100 to a Helix but maybe I shouldn't since Helix doesn't have Tera Echo.  If the Helix tone is much better than the GT-100 I should probably get one anyway. I'd love to hear any opinions on this.
    I found a way to come close. There is a sweep echo in Helix that works really well. I had a GT-100. I liked it but it didn't compare to the Helix. The biggest thing about the Tera was how your pick attack could drive the effect. I have come really close with a dynamic split ( basically a gate to the effect), the sweep echo and the chamber echo.
    • Thanks 1
  10. On 11/11/2020 at 4:18 AM, Vic20-Ian said:
    @TLF2007
    I did some back to back testing and my Freqout pedal is now pretty much redundant ;-)
    Many thanks for this TLF2007
    Glad it worked for you! My Freq Out sit in its box as well.
  11. 5 hours ago, tappistrt said:
    That's awesome! Is there an amp in the signal path? Curious if I could use this with an HX Effects.
    There is an amp in it but the signal path for the Feedbacker circuit is separate. Split A/B before the amp on the expression pedal-Logarithmic Volume also on the exp pedal--Simple Pitch +12-Vtron (start U, End A)- EQ with a mid bump-Red Comp (Max Sustain)-Chamber reverb. The Split B path back to the A path is also before the amp...I'm thinking on tweaking it now that the Helix has more effects available than when I first put it together. It does the job tho. The rest of the band likes it. Its good for a taste.
    • Thanks 1
  12. I recreated the Freqout good enough to get me through a couple songs I needed that edge/into feedback kind of sound without having to bring it to a gig. Its on CustomTone.  https://line6.com/customtone/tone/4237762/ . Operates a little bit differently by using the expression pedal but the instructions are in the patch notes and is the "Natural High" setting on the FreqOut. You may have to change outputs. Its set up as a gig patch using Input 2 for a bass path irrelevant to the Guitar Patch on input 1 so ignore that. I tried to use Autoswell on a momentary to bring in the path but that effect is overall frustrating and was better on the Exp pedal. Even with the FreqOut,  I like the Exp pedal over a momentary anyway. If there was available LFO assignments like on the Digitech GNX ( maybe even RP) stuff, the path could be automated for a momentary better.
    • Thanks 3
  13. Seeing a lot of cool immediately usable workflow uses with this update. I'm most excited about the Harmonic Antagonizer model. WOW. I also preordered the POD Go for the more-than-often warm up and cover gig stuff including ease of fit in a carryon. Be interesting to see if the product updates coincide. But I'm not bitching.
  14. I know, for me, the sounds are fine/great out of the Helix already. I don't need/want to change that at all. My basic tones haven't changed that dramatically.  If I can get a more portable solution for the growing number of sit in or quick set up situations I see then its a perfect complement. Still depends on the sound and if the tweakability is enough that the lack of that deep diving isn't a distraction.
  15. That looks like a perfect quick, direct, portable, gig solution which is what I was looking for recently. I'm onboard. No XLR but they are balanced outputs so thats an available cable solution going into a snake/digi-mix box etc. Less tweakability which is fine-hopefully at least sag made the amp tweak list but can get around that. The models are based on HX and legacy stuff which is great. Would be OK without the expression pedal to easily use an outboard one but thats OK. Remains to be seen what it sounds like. 9VDC power supply so hopefully One-spot compatible, etc. ...Take my money.
  16. I think there is more area to trim here. Lose the big knob ( I replaced mine on my Helix Floor with a Phones knob I bought as parts as an example) . Tighten up the switches, Make the Mode/Tap buttons cycle between Bank up/down or snapshot on long-press and you'd lose 1.5"+ on the depth. Put the PS on a wall wart and the height/weight would decrease a lot. I love my floor and love how it works during a gig and set up but its a beast to cart around. Form factor wise my RP500 was the best product I ever gigged with - sonic limitations aside.
