gtrman100
Members
  • Content Count
    192
  • Joined
  • Last visited
  • Days Won
    3
Everything posted by gtrman100
  1. I had a Vetta years ago, and my memory is a bit foggy but I think the Spider V sounds better. It's much easier to navigate with the simpler interface which makes tweaking easier. The mid/ high gain tones seem more dynamic. I had the "lost in the mix" syndrome when I had the Vetta, I believe a function of the lack of headroom in the power amp section. I've got none of that with the Spider V 240.
  2. gtrman100
    Amp Record out Buzz
    You have a ground loop between your computer and the amp. You can check it by using a ground lifter (3 to 2 prong adapter) on the amp. That will most likely solve it. Be aware though, it isn't the safest way to operate, but usually there isn't a problem in a simple setup.
  3. Glad I could help. BTW, why have you given up on the amp as a guitar amp? I'm getting some stellar tones out of mine.
  4. It's pretty simple, plug a 1/8 inch into the Aux In jack on the back of the amp. The master volume control on the amp will control overall volume of your external device. The amp models do not affect the sound of what you send to the Aux input.
  5. The XLR outputs are line level. You would have to patch them to a powered full range speaker to get your desired result. You could patch them into your PA system also to get a wider sound.
  6. I tried holding the position parameter, nothing happened on my Ipad mini...
  7. That's actually not the way it works. Double tap on the blank area( outside of the slider) of the parameter you want to control with the Exp. pedal and a dialog box will pop up. BTW, is there a manual or guide on the Spider Remote App? I've had to discover things by experimenting- not the best way to learn it.
  8. gtrman100
    Transfer Tones
    Nope- different amps, different software. You can only get tones from the Cloud through the Spider App or create them yourself.
  9. My experience: Samsung Galaxy S6 phone- unstable. It works ok until you try to download from the Cloud. Ipad mini- 10.2.1- very stable
  10. gtrman100
    Worst amp ever?
    Have you downloaded any presets from the cloud? You should be able to find a few good ones quickly. Try searching for Hindmarsh. He's the guy in the Line 6 demos, and has created some good ones. Maybe try a different guitar too. Have you updated the software? That affects tone also. If you've done all that and it still doesn't sound good, the amp might be defective.
  11. You have to go to the delay effect and select "note" instead of time. You then use the slider to determine the note value of the tap tempo. Then the tap button will control the delay time.
  12. According to Digital Igloo, the modeling engine in the Spider V series is an updated and reworked version of the Pod Farm modeling engine. I think they started with that version because there are so many different amps modeled, and then massaged them to work with the Spider series.
  13. Is it me, or is this a totally bug ridden app? Almost every time I create a new preset, save it to My Tones, then try to download the preset to the V-120, it crashes my Samsung S6. I can't even restart the app or phone, I have to reboot the phone. Is this happening to others, and is there a solution? I'm trying to create banks of tones as a backup rig to my Helix. So far it's really frustrating.
  14. DI mentioned that they would be reviewing and updating the Helix reverbs in the future.
  15. It sounds like the modeling and effects are the same as the combos. The only difference is that the 4x12 is a regular cabinet, and the tweeter is in the head with the 2 stereo speakers. Pretty ingenious...
  16. Thanks for the info. It's what I thought- with an amp with this many options, a real editor is really necessary. I'll vote and hopefully there will be a solution soon.
  17. I just got a SV120 and downloaded the app. Linked to my Samsung S6, the app is glitchy, but operational. Question: is there any way to drag and drop, or cut and paste presets using the app without saving to the cloud and then downloading down to the amp? It's unwieldy to have to go through all those steps to create banks of presets for gigging. Also, I haven't found any manual for the app. Is there one?
  18. When you plug in an external expression pedal and it becomes the default volume pedal, it frees up Exp 1 for wah or other effects control. The internal pedal is the only one with a toe switch, so it's the best for a wah wah effect.
  19. I have a 59(and a 69). Both have been flawless for years, and integrate with the Helix extremely well. I have big hands(unlike some :D) and find the necks very comfortable. The shape is different than my Fender and Gibson guitars, but I got comfortable with them in no time. The ability to change guitars and amps with a single footswitch is a godsend to a cover band player like me. As mentioned before, you can determine if you want to send both the mag and modeled pickups to the Helix in the input stage of the Helix. Like any mid range guitar, having a setup by a pro, maybe a bit of fretwork with increase the playability to match just about anything out there because the design of the guitars is good out of the box.
  20. The product is only 6 months old... do you consider music equipment an investment?
  21. I have it set up basically like I did with my HD- amp model changes with preset and the Topology, Class, and tube state follow. It works great after a bit of programming. The Dream Rig lives on...!
  22. I'm not understanding either- when you add a wah block, unless you have the EXP-1 toe switch reassigned to another function, it will default to turning the wah on and off.
  23. The secret is- you have to turn off the preamp section of the DT amp, so that the Helix will replace it. Download DT Edit- http://rome2.github.io/dtedit/ Connect your DT amps midi in and out to a quality PC midi interface. The M-Audio ones work well. With the amp on standby, open DT Edit In the upper left corner, you'll see the 4 Topologies. Click on 1 In the preamp section, select none. It defaults to a Fender Twin. Once you do that, the mic models disappear too. In the output section on the upper right, select Topology one. Select the class and triode/pentode mode etc for that topology to default to. Repeat #4-6 for the other topologies. Close DT Edit Now when you connect the midi out of the Helix, it will take the midi CC commands that you program in the Helix Command Center for each preset to the desired output mode of the DT. You program the Helix "instant" switch, not a footswitch unless you want to select it separately. It works great, and it is a bit of a pain, but once you've programmed it, it's done. I'm getting stellar tones with the Helix/DT setup using the "Amp" models- not Preamp or using the Cab models. You can experiment to find out what works best for you.
  24. They did show the Firehawk 1500, which I'm hoping is not a replacement for the DT series. It's a FRFR system with built in Firehawk level modeling and interface.
  25. I'm going to chime in on this discussion, because I've been experimenting with the integration of the Helix with my DT amps in the last month, and have finally found the answer. True, it's not as easy as the HD500 Line6 link integration, but with a little bit of work, I think you'll be happy. The fact that they released Helix without a promise of full integration, doesn't mean it might not happen in the future, but I have a feeling that they're moving to the Firehawk 1500 as the Helix mate rather than the DT series. Heres how it works: Download DT Edit from http://rome2.github.io/dtedit/, load and connect to DT with 2 midi cables with a good USB midi interface. Select Channel A under master section. On the left side of the DT Edit control panel, select "none" for Topology 1 Preamp selection (eliminating the DT preamp) On the right side of the DT Edit control panel, select Topology 1 and select the desired class and pentrode/triode configuration Repeat steps 2 and 3 for the other three topology settings. Close DT Edit. Connect 1 midi cable from Helix to DT amp midi in Create a preset with an Amp model (not Amp + Cab, or preamp) Press the menu button and select Command Center Instant 1 will default, use default midi channel "base", and select CC# 122 Select the desired Value #- 0 Topology 1, 1 Topology 2, 2- Topology 3, 3- Topology 4 Save the preset. Now when you select this preset, it will change the amp Topology to the desired one, with the class, and triode/pentode selections. I find that the amp models without cabs sound the best, much better than the amp + cab or preamp models. Since the DT has it's own speaker, and the cab model in the DT has been disabled, you have a good place to start tweaking. I find I need to do just a little EQ to get the desired sound. The Helix sounds so much better than the HD, it's worth the extra work to get it integrated with the DT. And it's still just 2 cables- the Link and midi. I hope you give it a try, and it works for you.
