Sign in to follow this
Guram
Is there any software to control amp via FBV pedal input?
hello my AMP is Line 6 Spider IV I have noticed that it has FBV pedal input which is same as LAN cable... I was thinking is there any way to switch between channels via computer? any software or any other way? computer can communicate via LAN port and send packets...
there will be some way to give AMP order to switch channels
no.... the port looks like a lan part and uses the same cable etc....
the port operates completely different and even sends power...
if you hook up anything besides an FBV in that port you WILL damage something.
+ 1 to TheRealZap!  DO NOT hook up your amp to a computer via LAN connector - it will fry components in your amp.
