Beacheshome Posted October 30, 2014 Share Posted October 30, 2014 I just picked up a Fender Hotrod amp and have my M13 hooked up using the 4 cable method. The Fender manual tells me to use TRS cables between my effects and the amp's FX loop. I know the advantages of balanced connections, but does the M13's FX send and return support a balanced connection or would I be throwing good money away on cables that won't perform any better than regular instrument cables? (I do have a bit of noise with the 4 cable method set up, but I'm pretty sure it's a ground loop issue). Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 30, 2014 Share Posted October 30, 2014 No advantage whatsoever. All of the M13's jacks are unbalanced. Quote Link to comment Share on other sites More sharing options...
JTSC777 Posted November 6, 2014 Share Posted November 6, 2014 Yeah just use the best cables you can afford.I have used my M13 with all kinds of amps with no problems.Always great tones and great in the studio too! Quote Link to comment Share on other sites More sharing options...
