stump8268 Posted November 6, 2014 Share Posted November 6, 2014 I have an early Tone Port UX1 and can't use it with OSX Yosemite. Pod Farm1 and Gearbox don't work with this version. Is Line 6 releasing a fix for this soon or authorizing a free upgrade to Pod Farm 2.58? I need a solution ASAP, I use the Tone Port frequently and have a client recording date coming up in a few days that I need to use this on. Help please. Thank you. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted November 6, 2014 Share Posted November 6, 2014 i suggest you call or open a support ticket if you want a response "ASAP" http://line6.com/company/contact/ Quote Link to comment Share on other sites More sharing options...
stump8268 Posted November 7, 2014 Author Share Posted November 7, 2014 All set. Ticket opened, problem solved, ticket closed. Quote Link to comment Share on other sites More sharing options...
gmenuet Posted November 9, 2014 Share Posted November 9, 2014 Can you tell how you made your toneport and GearBox running on Yosemite ? Quote Link to comment Share on other sites More sharing options...
daveoo Posted November 12, 2014 Share Posted November 12, 2014 Yeah, would love to know how you got Pod Farm working on Yosemite too, cheers. Quote Link to comment Share on other sites More sharing options...
BadHouses Posted November 22, 2014 Share Posted November 22, 2014 Same problem here, ticket open but just told to re-install.... :S Quote Link to comment Share on other sites More sharing options...
uslimey Posted December 30, 2014 Share Posted December 30, 2014 I managed to install and run gearbox successfully on Yosemite.... The solution is a follows: Download and open Gearbox 3.72.dmg Right click the GearBox.mpkg icon Left click 'Show Package Contents' Double click 'Contents' folder Double click 'Packages' folder You should now see 10 individual packages... Install each one Note: If you previously installed other Line 6 software with a newer driver, it will not allow you to install the drivers in this package... You will need to uninstall the newer drivers first, then you should be good to go. Search the forum for details on how to uninstall the drivers using command prompt. Someone else posted instructions on how to do this... They also suggested another driver to use... I tried to install that one first and it wouldn't let me, so I ended up installing the drivers from the from the GearBox package above... Anyway, I am running Yosemite 10.10.1 on a MacBook Pro Retina, with a POD X3 Live, and so far it is working fine... No panic attacks... I was able to create and upload a tone to one of my user presets... By the way, before this, I did update the firmware on the X3 using a a separate version of Monkey that I had downloaded previously. I am not sure if this have any relevance with regard to MAC and the X3 playing nicely together once I reinstalled the old drivers. Quote Link to comment Share on other sites More sharing options...
johnnyduncan Posted January 4, 2015 Share Posted January 4, 2015 I did the same, and it couldn't install the first things in the list of packages.. Start at the bottom with the actual POD Farm package itself and don't worry too much about the top ones... You can update them through Monkey.?? Im hoping this get me going. It seems to have got the earlier Farm running on my Yosemite. 1 Quote Link to comment Share on other sites More sharing options...
johnnyduncan Posted January 4, 2015 Share Posted January 4, 2015 I did the same, and it couldn't install the first things in the list of packages.. Start at the bottom with the actual POD Farm package itself and don't worry too much about the top ones... You can update them through Monkey.?? Im hoping this get me going. It seems to have got the earlier Farm running on my Yosemite. Quote Link to comment Share on other sites More sharing options...
omikl Posted April 9, 2015 Share Posted April 9, 2015 Worked for me too. Thanks guys. Quote Link to comment Share on other sites More sharing options...
