Sign in to follow this
JSpinne
FBV Shortboard Mkii wont work with Pod Hd Pro. URGENT HELP NEEDED
Hello everyone
I recently bought an fbv shortboard for my pod hd pro.
Unfortunately, when plugging the shortboard in to my pod, it simply isn't being detected at all.
No lights, no functions.
I then hooked it up to my computer via USB were it was detected. I updated all drivers and flash via line 6 monkey.
I couldnt find any help on the internet on how to get the fbv to work with the pod! This is really really disappointing.
However, I then plugged the shortboard into to VARIAX input of my pod (I know this is not were it goes, but i needed to find out, whether the cable worked at all) and the shortboard was detected, but i simply couldnt do anything with it.
Would someone please tell me, what I am doing wrong?
P.S. I tried calibrating the pedal and that wont work (via USB to computer) either.
check the FBV port on the pedal... or on the pod.. sounds like you might have some bent pins.
I have the Same Problem here, Has anyone solved it?
Necro thread from 2014 fyi. ;)
You need to see if its the HD, FBV or Cable. 9/10 its the cable. If the cable checks out good then check the FBV on your pc via usb and see if its detected. Last step would be to shine a flashlight into the usb posts of the HD and FBV to look for bent pins.
Create an account
Register a new account
Sign in
Sign In Now
