Sign in to follow this
lvandenberge
Expanding on the Dual Cab Technique
Hi there, first post here.
So I'm sure many here are aware of MeAmBobbo's pod guide, http://foobazaar.com/podhd/toneGuide/ . Being fairly new to the pod (I've had a few weeks to make myself comfortable), I have read most of this guide at least once and referenced many sections repeatedly. I've learned a great deal, but being that the guide is clearly pointed at people looking to create metal tones I've had to adjust accordingly. I've also found that I rather like taking dual amp chains and applying compatible cabs and mics (the dual cab technique) and carving out space for each amp/cab to have their strong points emphasized.
So this is all great, I'm having a blast, but my favorite amp in there isn't even mentioned in the guide and cab/delay spread sheet ( https://docs.google.com/spreadsheet/ccc?key=0AsSFadRSa9zYdG1kc1J2b1ZvRFVlUVIydXRMVVoyZnc&usp=sharing ) doesn't touch on the PhD, Super O, or Celest cabs, to name a few. I can only assume that these other cabs have potential as well, but I am automatically less keen on using them in dual cab or dual amp/cab chains due to the fact I'm wandering the dark in terms of compatible mics to deal with phasing.
Does anyone have any thoughts here? I know Bobbo moved on and the guide seems a few years old so maybe some of these cabs weren't even around back then, I'm too new to know. Perhaps if I knew how to test for compatible combos I could take a crack at it.
We hear from the Wizard every once in awhile when he is summoned. I hear you have to go into a dark room and look in a mirror and spin three times saying his name. Kick on the lights and he appears.
I think the guide pre-dates some of the newer amp models that were added in a (fairly) recent firmware update.
I looked at that spreadsheet. Man that's a lot of effort! On the other hand, you could tryout some combinations on your own and use your ears. There may be some "wrong" setups that actually sound quite appealing.
Sure, I've found some decent sounding combinations using cabs not documented there. However, once you eliminate the phasing the difference truly is light and day so if I could figure out how to quantify the samples as Bobbo did I'd be happy to work this out for the new cabs myself since it doesn't seem like anyone else has.
In the end it is all about what sounds good and it sounds good.
How about determining the phase of each signal (amp+cab), using a DAW and a
phase/spectrum analyser VST, then adjust the phase of one to match the other ?
Example > http://www.voxengo.com/product/pha979/
or            > http://www.fluxhome.com/products/Freewares/stereotool
Info         > http://atoragon.blogspot.it/2012/03/frequency-phase-analyzers-and-metering.html
               > http://atoragon.blogspot.it/2013/07/phase-coherence-in-multiple-mic.html
Awesome, I'll look into it. Thanks!
Create an account
Register a new account
Sign in
Sign In Now
