G30 Cutting Off
Holdensh
About a month ago, I used my brand new G30 wireless for the first time.  I move quite energetically because of the genre of music I play.  Every time I jump or move abruptly my receiver would shut off.  Then I would go back and forth between "On" and "Off" none of the lights came on indicating any signal.  I left the receiver on after packing up to get off stage, and later that night I pulled it out and it was on.  I'm assuming its a connection problem.  Does anyone else have any problems similar to this?  I have a 2-year warranty.
It is the battery door. I just sent mine in for service. When your signal cuts out, if you hold the door shut tight it won't lose signal. I searched the forum and found that this has happened to others. One guy said that he uses a Velcro band around this unit to keep the door tight. When mine returns, I'll probably start doing this to prevent a future drop out. Thankfully, mine has only cut our during rehearsals.
