Sign in to follow this
irrikan
error in my POD HD500
Hi
The other day I turned on the Pod HD500 and restarted about 5 seconds, it appeared the logo of line 6 and ran another 5 s, the screen went black and forth to restart. This makes it constantly.
I tried putting reset to factory settings, and again solved a constant reboot, mov pressing the key. Left at the beginning. It did not work
With the Line 6 Monkey saw the icon Flash Memory was gray, so I tried to update it but it gave me an error, too icon drivers turned yellow and the computer gave me a message that did not recognize the USB.
I went to install the drivers from file and I went to connect the POD to Monkey but while trying to install the Flash Memory turned to disconnect the USB.
I repeated the process but the connection time was shorter and did not give me time to update the Flash Memory from file that was downloaded from the website of Line 6. Furthermore icon drives go from green to yellow and if reinstalled does not fail but the icon passed back to yellow
As much as I repeated the process I no longer get that recognizes USB drives or that are set. I tried it in different connections of the computer and another computer too.
Thanks
