diggerbarnz Posted December 2, 2014 Share Posted December 2, 2014 Can someone please direct me to link as to the where & how please & thanks Quote Link to comment Share on other sites More sharing options...
radatats Posted December 2, 2014 Share Posted December 2, 2014 you have 4 amps in each channel. you change amps with the topology switch. you can use a 3rd party program DT Edit found in the POD HD forum to connect by midi and configure your amps, cabs, mics and reverb to taste. if you connect with your HD500 you don't need to worry about it because EVERYTHING is done in the POD and the DT gets configured to match. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 2, 2014 Share Posted December 2, 2014 keep in mind its STILL a 2 channel amp.... best strategy is to put your lower gain amps on one channel and your higher gain ones on the other... because remember... it reads the tonestack and channel volume etc for all the topologies on the channel... the settings that sound killer for that fender twin... will rip yer friggin head clean off if you switch to the uber..... just get your midi connections and get one of these: http://line6.com/support/topic/124-user-created-dt-editors/ much easier than trying to midi through it yourself. :) 1 Quote Link to comment Share on other sites More sharing options...
diggerbarnz Posted December 2, 2014 Author Share Posted December 2, 2014 thanks guys Quote Link to comment Share on other sites More sharing options...
