assmonger Posted December 12, 2014 Share Posted December 12, 2014 Hi there. So I'm using my POD HD500 over headphones to monitor my guitar while listening to playback from the computer through the USB port (MacBook Pro, Mac OS X 10.10). The problem is, compared to the output from the guitar simulation, the computer's volume is WAY too loud. The volume control on my computer doesn't seem to do anything, neither does sliding the stereo output knobs in Audio MIDI Setup. How can I adjust the overall volume output of the computer? Thanks! Quote Link to comment Share on other sites More sharing options...
NBell Posted December 12, 2014 Share Posted December 12, 2014 Hey there, Your computer is reading the HD500 as the main audio device for ins/outs. The master knob on your HD500 should be the overall output of your computer. Just like with a traditional interface. Quote Link to comment Share on other sites More sharing options...
assmonger Posted December 12, 2014 Author Share Posted December 12, 2014 The master knob works to adjust the overall volume into my headphones but that makes the guitar volume lower too. Any way to adjust the mix between the two? Thanks! Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 12, 2014 Share Posted December 12, 2014 Check the Preferences for the HD500 device on your Mac. Is there a control for the mix of guitar vs. hardware playback? Quote Link to comment Share on other sites More sharing options...
assmonger Posted December 12, 2014 Author Share Posted December 12, 2014 There's a Hardware Monitor Level, which works to bring the guitar volume down in the mix but it's at the max setting already (+0dB). :( Quote Link to comment Share on other sites More sharing options...
NBell Posted December 12, 2014 Share Posted December 12, 2014 On the face of the 500 next to the expression pedal , is the Guitar in switched to normal instead of 'PAD'? If you haven't tried yet: System Preferences>Sound> Input (select HD500)>Output (select HD500) What exactly is producing your audio playback from your computer? Internet, iTunes, Protools?.. Quote Link to comment Share on other sites More sharing options...
Palico Posted December 12, 2014 Share Posted December 12, 2014 Turn down the computer volume on using the computer itself. On Windows 7 the little speaker in the corner. Does not affect your guitar level, just the output to the POD. 1 Quote Link to comment Share on other sites More sharing options...
assmonger Posted December 12, 2014 Author Share Posted December 12, 2014 nickbell_: Yup, output/input is on POD HD500 and what's playing music is different things, sometimes Spotify or Audacity or iTunes edit: yup, the guitar is at "normal" rather than pad Palico: The volume control doesn't seem to change the computer level, even if it's turn all the way down to mute it's still at the same volume. edit: also my "Amp" in the signal chain has volume set to 100% and the drive is in the middle Quote Link to comment Share on other sites More sharing options...
Palico Posted December 13, 2014 Share Posted December 13, 2014 If you are in Windows, open the Volume mixer. You should see the POD there. Lower the level there. Quote Link to comment Share on other sites More sharing options...
dzuwenden Posted January 29, 2015 Share Posted January 29, 2015 I'm having this issue as well. Did you ever figure out how to fix it? Like you, I'm on Mac, and the volume control has no effect. Quote Link to comment Share on other sites More sharing options...
scias23 Posted January 29, 2015 Share Posted January 29, 2015 Just lower the volume of the music app or DAW ? Quote Link to comment Share on other sites More sharing options...
assmonger Posted April 27, 2015 Author Share Posted April 27, 2015 I'm having this issue as well. Did you ever figure out how to fix it? Like you, I'm on Mac, and the volume control has no effect. Unfortunately not... hopefully they'll release a driver fix. My solution for now is to use a 3.5mm jack from my computer to the CD/MP3 in slot on the POD. Then I use built-in-ouput for outputting sound from my mac and the PODHD500 device for input, so then the volume control works. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 27, 2015 Share Posted April 27, 2015 The fix is.... Turn your pc volume down. It doesn't matter what I hook up to my pc, the volume will run to 100. My Pod. My TV's. My phones. If sound from my pc is coming out of another device, the volume maxes out. And it goes back to 'normal' when I disconnect. Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted April 27, 2015 Share Posted April 27, 2015 You built your patches too quiet. Or you can lower the level of the tracks in whatever app your playing them off of (iTunes, your DAW, whatever). Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted April 28, 2015 Share Posted April 28, 2015 I noticed kind of the same thing while recording into my DAW. All I did to solve the problem was turn the master volume level down on the DAWs mixer. Quote Link to comment Share on other sites More sharing options...
roadrob Posted July 10, 2016 Share Posted July 10, 2016 Hi there, It is still with 10.11.4 the same: - turning down the mac volume doesnt work when input is the line 6 usb device, the volume doesn't change - turning down the master volume turns down everything, also the guitar input There is only one workaround: turning down the volume of the app that is used for playing the music / jam tracks / whatever But I still get headache when system sounds or other apps pop up for notification. :wacko: @Line6:why is there still no fix for this issue in 2016? I bought an expensive device and struggle with such little piece of developers' work. -_- Cheers Robin Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted July 10, 2016 Share Posted July 10, 2016 There is only one workaround: turning down the volume of the app that is used for playing the music / jam tracks / whatever Not a workaround, but a solution But I still get headache when system sounds or other apps pop up for notification. In Windows, there's a virtual sound mixer, where you can control the level of the system sounds. @Line6:why is there still no fix for this issue in 2016? I bought an expensive device and struggle with such little piece of developers' work. -_- If you haven't heard, here in 2016 they have things called the Helix that can do all that. Expensive device? You can't even get a decent guitar for $500. If it ain't broke.. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted July 11, 2016 Share Posted July 11, 2016 @Line6:why is there still no fix for this issue in 2016? I bought an expensive device and struggle with such little piece of developers' work. -_- This would not be a problem for L6 to fix. It is an issue with the computer. Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted July 11, 2016 Share Posted July 11, 2016 You should be able to justify all levels using the system tool "Audio-MIDI-Setup" on your Mac. Quote Link to comment Share on other sites More sharing options...
thepackrat Posted February 27, 2017 Share Posted February 27, 2017 At least on the Pod HD, the levels set in the AudioMidi setup (while changeable on the mac) have no effect on the level of the audio that's hitting the pod's headphones output at least. Quote Link to comment Share on other sites More sharing options...
snifflestink Posted March 18, 2017 Share Posted March 18, 2017 Im having this issue too. The preset volume is really low from the headphones, but god forbid I hit the volume button on my MacBook, it might wake the whole neighborhood up. Quote Link to comment Share on other sites More sharing options...
SuprSpy79 Posted July 7, 2017 Share Posted July 7, 2017 Same problem, anyone contact Line 6 about this yet? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted July 7, 2017 Share Posted July 7, 2017 Same problem, anyone contact Line 6 about this yet? Read this http://line6.com/support/topic/10819-usb-output-to-pod-hd500-too-loud/?p=163688 Quote Link to comment Share on other sites More sharing options...
SuprSpy79 Posted July 7, 2017 Share Posted July 7, 2017 btw I have been using an 1/8 cable from the headphone hack to the cd input on the pod, just an extra wire. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted July 7, 2017 Share Posted July 7, 2017 then you have a completely different problem, even though it is the same answer.... The Pod does not control the volume from the cd input. You'll need to control it with the playing device. Quote Link to comment Share on other sites More sharing options...
loopology Posted June 10, 2020 Share Posted June 10, 2020 The POD HD Desktop exhibits the exact same problem. In particular I'm live looping with guitar and a loop software on the mac. The tracks played back are substantially louder than the guitar while recording. Or when I simply record some audio through the POD with sox and then play it back with play through the POD I observe the same phenomenon. A solution would be to attenuate the audio coming from the USB as a setting in the POD. As mentioned, I can't turn down the POD's MASTER Volume, as this would further quiet the directly monitored guitar. Weirdly, I can lower the input levels in the OSX Setting Audio MIDI Setup but lowering the output levels doesn't do anything. Also when muting the outputs from within Audio MIDI Setup, the audio comes through unimpeded. When using the POD as an audio interface this is very annoying. Yes, you can turn down the master volume from within your DAW, but all other sound sources (e.g. system sounds) will still be too loud. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted June 11, 2020 Share Posted June 11, 2020 Thread is 3 years old. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted June 11, 2020 Share Posted June 11, 2020 16 hours ago, loopology said: The tracks played back are substantially louder than the guitar while recording. Or when I simply record some audio through the POD with sox and then play it back with play through the POD I observe the same phenomenon. Doesn't your looper software have its own volume level controls? If yes, use them to lower the playback volume level.. If the guitar signal needs to be louder on recording you should use the level controls available in the chain, eg the mixer block faders and/or the amp model output level. The master volume physical knob doesn't affect in any way the recording level through USB, it's only an input/output global monitoring level. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
