MikeMaben Posted December 15, 2014 Share Posted December 15, 2014 ...new TT, everything seems to function OK but thru headphones only. I've connected to my Vizio soundbar which streams tunes from the app but not thru the Amplifi device, only when streamed straight to the bar (which of course means no guitar). I connected to my PE60 and guitar works but no tunes. The only out that works fully is the headphone jack. Could this be a faulty unit or am I doing something wrong ? Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 15, 2014 Share Posted December 15, 2014 I don't have a TT, but on the FX100, plugging a cable into the AMP out disables the guitar from the main outs and only the guitar is routed to the AMP out. Quote Link to comment Share on other sites More sharing options...
Rowbi Posted December 16, 2014 Share Posted December 16, 2014 Here's a bit of help from the manual. If using the amp out, only your guitar would be heard from the amp out and only Bluetooth audio via main outs. If you disconnect amp out, the main outs would send guitar and Bluetooth. Optical output would always send both, as would the headphone output. Check out the manual (page 7): http://line6.com/data/6/0a064389d07d547e33636c04b/application/pdf/AMPLIFi%20TT%20Manual%20-%20English%20(%20Rev%20C%20).pdf Hope this helps Rowbi Quote Link to comment Share on other sites More sharing options...
MikeMaben Posted December 16, 2014 Author Share Posted December 16, 2014 I did see that in the guide Rowbi, but it kinda doesn't make sense since the TT appears to be the same as an Amplifi 75/150 but without the speaker, so I thot plugging into a speaker (like the PE60s) would work the same. I think I need to swap the unit as it works fine thru the headphone jack but nothing else. Thank you both for your input . Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 16, 2014 Share Posted December 16, 2014 Route your main out(s) of the TT to the PE60s and do not plug anything into the TT AMP out of the TT. This should give you both guitar and BT stream to the PE60s. Keep in mind the main outs are line level. Quote Link to comment Share on other sites More sharing options...
MikeMaben Posted December 17, 2014 Author Share Posted December 17, 2014 Thanks T, Yeah, I thot I'd try that. It's just one PE60 so I'd run out of the TT right or left main only, right ? I still need to get out to my soundbar setup in the living room tho. I've tried both optical and RCA and neither work so I have a feeling it's a hardware defect. I've opened a ticket so we'll see. Thanks again... Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 17, 2014 Share Posted December 17, 2014 On the FX100 Left main out will mono sum if nothing is plugged into the Right main out. I am not sure if it behaves the same with the TT. Quote Link to comment Share on other sites More sharing options...
MikeMaben Posted December 18, 2014 Author Share Posted December 18, 2014 Yep that works. Still have no out to soundbar (which is why I bought the thing). Still no response re my ticket. Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 18, 2014 Share Posted December 18, 2014 Sorry, I misunderstood your original post. The TT will not stream audio via BT to anything if that is what you are try to do. Quote Link to comment Share on other sites More sharing options...
MikeMaben Posted December 20, 2014 Author Share Posted December 20, 2014 I'm just trying to get the TT out to my soundbar. The app can BT to it and it works with headphones but not the optical or RCA. Got a response to my ticket : "If you do not have anything connected to the amp out or the headphones, the guitar blend is turned up, and you still are unable to receive guitar signal from the optical/RCA outputs I would suggest that you either exchange it with your dealer for a replacement or send to us for a replacement. -Don Customer Support Line 6" Setting up an exchange with Sweetwater. Thanks again for helpin' out. Quote Link to comment Share on other sites More sharing options...
