teovai 0 Posted January 1, 2015 Hi, Can someone tell me What s The ADC - DAC bit resolution of The pod HD 500? Maybe also The processor frequency, The sample rate frequency, time latency of The signal etc... Where can i read these specific informations? Thanks Quote Share this post Link to post Share on other sites
pfsmith0 228 Posted January 1, 2015 The only thing I know are the sample rates, which are 44.1kHz, 48kHz, 88.2kHz, and 96kHz. Latency is probably dependent on which FX you have engaged. I know there's some because when you adjust the mix between wet/dry on some FX you inadvertently get nulls due to time delays thru the wet path. I really wished they would have incorporated some delay compensation thru the dry path so the signal sums properly. 1 Quote Share this post Link to post Share on other sites
