coreyhchan 0 Posted January 1, 2015 When you use the acoustic guitar models on a Variax with the POD HD, do you need an amp block to get the acoustic tone when running through a PA system? I can't seem to get any sound unless I run it with a amp block in my signal chain. Quote Share this post Link to post Share on other sites
xpanmanx 15 Posted January 2, 2015 I use the JTV-59 v2.x Martin D-28 model for the bulk of my acoustic work. I've attached my HD Pro primary acoustic tone. You might enjoy kicking the "stomp" button with the volume pedal at 100%. I use that setting to back my lead guitarist on solo at the end of Pink Floyd's Comfortably Numb. JTV Acoustic.zip Quote Share this post Link to post Share on other sites
coreyhchan 0 Posted January 2, 2015 I'm sorry, so do you have an amp in your signal chain? Quote Share this post Link to post Share on other sites
xpanmanx 15 Posted January 2, 2015 My primary acoustic tone, attached to post #2, is a complex dual-tone preset. You might like to load it up in HD Edit and check it out. To answer your question directly, I didn't use an amp model on the first tone. My "stomp" effect engages the second tone, comprised of the Bomber Uber model plus other toys, and it's mixed way back. Have fun! Quote Share this post Link to post Share on other sites
jandrio 459 Posted January 2, 2015 check out this patch: http://line6.com/customtone/tone/488104/ read more dtls on the comments section. hear+watch actual live performance: btw, if no amp is used, set BYPASS VOL = 100. Quote Share this post Link to post Share on other sites
