joaomb Posted January 15, 2015 Share Posted January 15, 2015 Hi there, I bought a spider iv 75 w and a mkii express 2 and a half years ago. Both have been working great till 2 months ago. Now, when I plug the mkii to the amp it make a wierd noise, kinda distorted/ fuzzy and kinda tremolo too. I think this may be 1 of 3: - cable is not good, which I already tried to change and nothing changed, so no; - amp port is not working good; or - mkii is not working good. The amp alone works fine. Can anyone help me with this? Have anyone had this problem? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted January 15, 2015 Share Posted January 15, 2015 So the amp sounds fine when you use it without the FBV MkII? Have you tried connecting the FBV to your computer wiht a USB cable and reflashing the memory using Monkey? Quote Link to comment Share on other sites More sharing options...
joaomb Posted January 15, 2015 Author Share Posted January 15, 2015 So the amp sounds fine when you use it without the FBV MkII? Have you tried connecting the FBV to your computer wiht a USB cable and reflashing the memory using Monkey? Yes, the amp without the FBV work perfect. I haven't tried that, I will try it later today or tomorrow and tell you if it worked. Quote Link to comment Share on other sites More sharing options...
