Where Is Pod Pro?
shadowlight
  • 3 years later...
I just bought a used Pod Pro, and I have downloaded some great tones by title. I have downloaded monkey but it seems that the pull down menu has every line 6 product but the Pod Pro. I have registered it with line 6 and I cant seem to get what I need in Monkey to update the unit much less get these custom tones on it. I may burn it and go back to my boss floor board for my recording needs. Am I doing something wrong here possibly??? Also, i don't have cheap midi cables.
cheers
don't think you need monkey with the pod pro... to work with tones, you likely need either line6 edit or gearbox.
cheers
  • 5 years later...
Hi! I bought last year an old POD PRO Rack. Can I save the actual presets patches and add a new ones? I think that L6 Edit or Gearbox don't run on Macs. There's a new software or any other solution?
Thanks
Thanks
The program you want is called POD HD Pro Edit. You can download it from the Downloads tab at the top of this page. Choose POD HD Pro in the Hardware column and choose POD HD Pro Edit in the Software column. Then download and install.
I can’t recall whether this includes the required driver. If not you will need to download and install the driver too. Leave the Hardware column with the Pro selected and choose Driver for the software column.
