Sign in to follow this
Dat510man
Need a Clean Patch in the HD500X
Is there a function or utility to delete settings from a A, B, C, D in a given bank so I'm starting with everything blank? I don't want to reset the factory settings. I want to select a bank, select "A", and then remove all settings so I can create from scratch.
Thanks for any help.
David
Select a blank patch, hold down the control key, and drag it to the patch you want to be empty. This is with the edit software on a pc.
On the device, select an empty patch, hit save, then use knob 2 below the screen to select the destination (the patch you want to make empty), hit save again.
