Cygnus64
Output on my HD desktop too low
My output levels are ridiculously low. I'm outputting to a home stereo receiver with KRK St6 monitors. I also have a Boss BR800 interface which is running perfectly (not at the same time of course), I'm swapping the same cables (with 1/4 inch adapters as Boss uses RCA) so I know everything is fine in that regard. The usb to my computer works fine, levels all correct etc. It's just the output from the Pod that is the problem.
Could it be my adapters? AFAIK they are TRS. I did notice that when I pulled one out a bit, the volume was fine on one channel (but buzzed if I pulled out both). I'm not well-versed on my electric, I'm I doing something wrong there.
As far as output, I see on page 4 of utilities that I'm using the studio/direct setting and I don't see any other settings. Thanks for any help.
confirmed.
from "POD HD Quick Start Guide - English ( Rev E )":
18. Unbalanced Output - Connect 1/4" cables here to send your sound to
a guitar amplifier, recorder, mixer or PA system
THanks for the responses. I switched cords, and now I have sound on one channel only. Somewhat bizarre, because it's consistent. Are there any known defects with the beans (this unit was purchased about a year ago)?  I'll get some different cords today. I had two amps (Alesis RA 150) die on my so I'm using a home stereo receiver until I can upgrade my monitors.
I'll do some more experimenting today, thanks again.
Problem solved. Crappy cords and a crappy receiver were to blame. And now if you'll excuse me, I'm gonna rock down to Electric Avenue.  :D
