Sign in to follow this
Gerardpfingst
Problem with the expression pedal of the podhd500x
Hey everyone, Im having a problem with the podhd500x, I read the manual over and over again and I've also checked a few forums but cant seem to find a solution for my problem, I bought the hd500x but cant find a way to toggle between the exp1 and exp2, every preset has the exp2 as default (and that one is the default for volume in all the presets) so If I want to use for example a wah wah and that one is assigned to exp 1 I have to change it to exp 2 in order to use it, I saw a couple of videos where the guys just push the expression pedal all the way forward and that automatically changes between exp1 and exp2, mine doesn't change when I do it, is a configuration thing or does my hd500x came defective? :S
You really have to push down on the pedal when it's new. And if you try and use your hand for this, unless you're super strong you'll have to use your entire body weight.
Not sure if you've already done this, but you must also assign the effect you're wanting to control with expression pedal 1 to the toe switch.
