lukazhalfar Posted February 8, 2015 Share Posted February 8, 2015 Hi, I´ve got problem with set up the preamp on the channel B, on my DT amp. I would like to set two amp, which I can switch each other. When the amp A is on, I can set up parameters of the amp. But, when I switch to amp B, I can´t control parameters of the amp B by HD500. I have read the manual, but they talks only about controlling amp A on the amp 1. THANX A LOT! Quote Link to comment Share on other sites More sharing options...
grandinq Posted February 8, 2015 Share Posted February 8, 2015 The Pod can only control channel A on the DT25. Channel B will always be whatever manual settings are there. You can access channel B via the Pod by turning off the amp in channel A. You can thus make a "channel B" patch on the pod. You can also throw some pre effects on there if you like. Quote Link to comment Share on other sites More sharing options...
