MIKEY9966
2 questions amplfi
i am trying to turn off all effects and amp, cab, easy to turnoff effect but is there a way to turn of the amps and cabs? I am trying to do this to hook up my pod 500 because there are no outs on amplfi 150, i think this was a bad move by line 6
Is there a pc screen like on the pod 500 to edit on the screen or is the tablet the only way?
Thanks for your help
In the AMPLIFi Remote App click AMP>>Type>>Clean>>No Amp
By default when selecting no amp there will be no cab.
Are you trying to use the AMPLIFi to monitor the 500? If so, use the AMPLIFi's AUX in, it will bypass all the modeling, so no need to disable.
You can use a cable like this:
http://www.amazon.com/Hosa-CMP153-Cable-Inch-Dual/dp/B000068O3C
Currently there is no PC Editor.
Thanks for help, would the no amp work as well as the aux input? I know it wont be streo, , do ypu think a pc edit is on the way?
If you are talking about running the output of the POD HD500 into the AUX in of the AMPLIFi, it does not matter if you have amps or no amp models in the AMPLIFi, that signal is not affected by the AMPLIFi models, same with music streamed via Bluetooth. With the 2 X 1/4" TS to 1/8" TRS cable I linked, it will be stereo if your effects on the HD are stereo.
