JFrankParnell Posted February 11, 2015 Share Posted February 11, 2015 Looper on 'pre', record a riff. Hit play, loop is playing with current patch, as expected. Hit loop button to get out of looper, change patch, loop has not changed, same sound as before. Even changing sounds, within the current patch is not changing the loop. However, live sound from the guitar is chaning. So, I am trying hard to figure out how to use the looper as an audition tool for the sounds. Can I please get a step by step on this? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 12, 2015 Share Posted February 12, 2015 You may actually have the looper in post mode. Note that in the looper controls display, the display tells you what mode the looper WILL be in if you hit the corresponding footswitch. In other words, if the display says PRE the looper is currently in POST mode. Quote Link to comment Share on other sites More sharing options...
JFrankParnell Posted February 12, 2015 Author Share Posted February 12, 2015 if the display says PRE the looper is currently in POST mode. Uhhh... what, is this opposite day, and no one told me?!?! :D Yes, that solves it, thanks Quote Link to comment Share on other sites More sharing options...
amsdenj Posted February 12, 2015 Share Posted February 12, 2015 The signal chain view shows you where the looper actually is, at the head (pre mode, post displayed on the footswitch) or tail (post mode, pre displayed on the footswitch). Anyone found a way to turn the looper effect on and off? I want to turn the looper off so that I can use the MIDI CC messages on the Looper footswitches to control MainStage. Currently I'm turning the looper volume all the way down - but that is a global parameter and doesn't get saved with a patch. Quote Link to comment Share on other sites More sharing options...
russgoos Posted February 13, 2015 Share Posted February 13, 2015 Looper on 'pre', record a riff. Hit play, loop is playing with current patch, as expected. Hit loop button to get out of looper, change patch, loop has not changed, same sound as before. Even changing sounds, within the current patch is not changing the loop. However, live sound from the guitar is chaning. So, I am trying hard to figure out how to use the looper as an audition tool for the sounds. Can I please get a step by step on this? I was not aware of being able to use the looper as a patch audition tool. Great idea! Quote Link to comment Share on other sites More sharing options...
