XCrossroadsX2000 14 Posted February 14, 2015 I have been restringing using the stock Dadario ,10s that came with my Variax. I would prefer to go to 9s or 8s as 10s are a little more work than I prefer. Couple of concerns, I play slide with a standard setup, a little concerned I will lose some sustain and amplitude with 9s or 8s. As it is I feel the high E doesn't ring as loud as it should. Wondering if I can fix it via Workbench but then I would have to do every model? I figure 8s will require a nut change but should be able to use existing nut with 9s When I first got my Variax I went through a bit of a learning curve playing it as the high E kept sliding off the fretboard, Probably sloppy finger attack but lighter strings may start this up again. So has anybody gone lighter with/without problems? Also any reccomendations on strings for bluesy slide work? Thanks, Kevin 1 Quote Share this post Link to post Share on other sites
ricstudioc 91 Posted February 14, 2015 Well, I've run both on my 69, once I swapped out to a fender neck I settled on 10's - that neck just feels right with'em. Didn't notice any particular issues with the 9's on the original neck. Played slide on both gauges, no real issues other than expected - higher gauges certainly are a better choice, obviously. Oh, and Ernie Ball guy here for the most part, tho I don't really care that much. A piece of wire..... Quote Share this post Link to post Share on other sites
cruisinon2 2,638 Posted February 14, 2015 Can 8's actually be seen by the naked eye? 1 Quote Share this post Link to post Share on other sites
fr0sty 12 Posted February 14, 2015 I normally use 9's and they seem a bit better with the alt tunings than 10's. Quote Share this post Link to post Share on other sites
ricstudioc 91 Posted February 14, 2015 Can 8's actually be seen by the naked eye? Apparently Billy Gibbons can see 7's, according to his gtr tech. How he gets such high cholesteral swamp gristle outta those spider webs is beyond me. Quote Share this post Link to post Share on other sites
cruisinon2 2,638 Posted February 15, 2015 Apparently Billy Gibbons can see 7's, according to his gtr tech. How he gets such high cholesteral swamp gristle outta those spider webs is beyond me. Yeah, not sure I buy it, lol. No outdoor gigs with 7's...a stiff breeze will snap them. 1 Quote Share this post Link to post Share on other sites
jandrio 459 Posted February 15, 2015 69s with d'addario NYXL0942 09-42 no problem... both electric+acoustic models AND mags sound super (genre: classic rock). previously used d'addario EXL120 9-42... restringing from the stock d'addario 10s requires setup. Quote Share this post Link to post Share on other sites
yelldog 9 Posted February 16, 2015 I use 8s and have no problems at all. You just have to have the guitar adjusted so that the intonation and stuff is set up for 8s. They don't sound 'thin' or anything. 1 Quote Share this post Link to post Share on other sites
jpmull 11 Posted February 17, 2015 I typically play 10's, but I tried 9's on my 59 based on Sean Halley's recommendation I saw on YouTube. I had a lot of trouble with them. I wouldn't consider my touch to be real heavy, but the 9's, combined with the jumbo frets was giving me real problems with chords and power chords being in tune. I guess I was pushing the lighter strings all the way to the fretboard, far enough to throw the chord just slightly sharp. Switching back to 10's fixed the issue. I suppose if you are used to the frets and have a lighter touch, your results may vary. If you have been playing an Ibanez with thinner frets and a flat neck like I was, you may have the same problem. But hey, it costs you less than $10 to try them out for yourself, that's the best way you'll find out. Quote Share this post Link to post Share on other sites
wilson69978 32 Posted February 17, 2015 Been playing 10's for years. I am a bit heavy handed I feel, so lighter is not right for me! But I suppose it really is whatever you get used to. If I put on 8's I would probably hit my chin when I bent a note! Quote Share this post Link to post Share on other sites
toasterdude 57 Posted February 17, 2015 All of my xplants have 25.5 inch scale necks and all are strung with 11s. I could not even imagine what playing on 8s is like! Quote Share this post Link to post Share on other sites
psarkissian 364 Posted February 17, 2015 "jandrio" is right,... "restringing from the stock d'addario 10s requires setup". Because, changing string gauges changes the tension on the neck, and when you change the tension on the neck, the whole set-up changes (action, pick-up height and intonation). Whenever you change gauge, get a new set-up done on it. Factory strings are D'Addario XL-110's. 1 Quote Share this post Link to post Share on other sites
