guitarslinger16 Posted February 17, 2015 Share Posted February 17, 2015 I used my amp yesterday morning and it was working fine. I then went to band practice and hooked everything up like normal and the amp was not functioning, just making clicking sounds. All four tone lights are lit up along with the Bluetooth. I use a FBV short board along with it. I tried to reset it by pushing the volume and tone buttons while starting up, and tried to update it via computer (which my PC was not recognizing it ) with no luck. Does anyone have any other solutions? It should be still under warranty since I purchased it on march 10th of 2014. Thanks for any input! Quote Link to comment Share on other sites More sharing options...
bilnye Posted February 18, 2015 Share Posted February 18, 2015 I had a used Mk1 express that I thought was making a low hum when connected to the Amplifi. Took it back to Guitar Center and got a newer (but still returned) MkII. Same issue. But what was odd using them on GC's demo Amplifi 75 it didn't hum, but made clicking noises. Tried different CAT5 cables, and no change. The 75 was dead quiet when the pedal was disconnected.Then I ordered a NIB (new in box) Amplifi 150 and new MKII Express. So far no more weird noise issues.But I may have another issue. If I have Wah enabled on, say preset B and switch to another letter, the pedal loses the wah control and also the volume. Then if I switch back to the original letter, the pedal is still not working. All the while, the Wah LED is still lit.I expect the the wah to still be on when I go back to the original letter preset. Or this actually how it is supposed to work? (note: I can re-enable the pedal by pressing all the way forward [hard] till it clicks. That resets it to volume. Then I can set it back to Wah.)I haven't updated the software on the pedal yet.Anyone? For more info on updating via PC vs Apple see this /http://line6.com/support/topic/10129-amplifi-windows-interface-failure/ Quote Link to comment Share on other sites More sharing options...
hollowman666 Posted October 9, 2016 Share Posted October 9, 2016 I have the exact same problem with mine. all 4 tone lights and bluetooth but no sound, was working then all of a sudden nothing. Did you find any solution?? Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 10, 2016 Share Posted October 10, 2016 Has anyone tried this procedure? http://line6.com/support/page/kb/_/amplifi-products/ampl/4-tone-lights-flashing-on-amplifi-3075150tt-r713 Also for FX100 you would need to hold down FS A and C during power up. http://line6.com/support/page/kb/_/amplifi-products/ampl/how-to-update-amplifi-3075150fx100tt-with-w-r701 Quote Link to comment Share on other sites More sharing options...
hollowman666 Posted October 11, 2016 Share Posted October 11, 2016 I submitted a trouble ticket for this problem and this is the response I got. "Hello,Sorry to hear you're having this issue. Can you please try to re-boot your amp in update mode. Be sure to press and hold the TONE and TAP buttons while you power on your amp. You'll hold those buttons for about 5 seconds when you power up.Then, you'll want to perform the update using a MAC or PC computer.http://line6.com/sup...0tt-with-w-r701Once you re-install the firmware, you should be able to boot up your amp as normal.Be sure to follow these instructions, and let me know what results you get." I tried this and no change. still 4 solid tone lights and a dim Bluetooth light. also I tried the factory reset thatg is in the manual that came with my amp "it says to hold volume knob down and the tone at same time when powering up still nothing. pc will not recognize it when plugged in usb still as well. very discouraging as I believe my warranty has just ended. this amp has been treated great it basically was placed in my living room and used occasionally always updated. and now it is sitting here like a very expensive brick, I will update on the next respose I get on my ticket. Quote Link to comment Share on other sites More sharing options...
