gp4leigh Posted February 26, 2015 Share Posted February 26, 2015 Hi, I currently plug my Ketron Audya keyboard main L & R outputs directly into the l3t RCA inputs, I'm going to start using a DI Box which will be wired inline. As the DI Box sends out Balanced mic level, should I now be plugging into the side mixer board section of the L3t, or the XLR Line input at the back on the speaker? Hope you understand my question, Thanks Leigh Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted February 27, 2015 Share Posted February 27, 2015 Hi, since you now have a 2 balanced outputs (L+R) the side panel mixer inputs are the best way to do this. You may have to use the pad switches if the signal is too hot. Quote Link to comment Share on other sites More sharing options...
gp4leigh Posted February 27, 2015 Author Share Posted February 27, 2015 Thankyou very much. Quote Link to comment Share on other sites More sharing options...
gp4leigh Posted March 1, 2015 Author Share Posted March 1, 2015 Hi, I did my first gig last night using my new DI box plugged into the mixer section of the l3t as you suggested. The sound was excellent, very smooth, very well balanced, all was going well until volume output dropped by about half just for a couple of seconds, then came back to normal. This happened twice during a four hour gig. Any Ideas or suggestions? Tonight I thought I would try the XLR line input on the back of each speaker. Left to one speaker Right to the other. What do you think? Regards Leigh Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted March 2, 2015 Share Posted March 2, 2015 If you have both XLR's connected to the first speaker and the second speaker connected via Line 6 Link you get the proper stereo routing. Left goes to one speaker, right goes to the other one. The problem you are describing is hard to solve without being there. It sounds most likely like a broken cable or connector anywhere in the chain starting on the keyboard. Quote Link to comment Share on other sites More sharing options...
gp4leigh Posted March 3, 2015 Author Share Posted March 3, 2015 Hi thanks for your reply, I have started the process of checking cables/connection to find the intermittent cause for the drop in volume. I have noticed the speaker fans are not working? Is there a user reset I can do? Thanks Leigh Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted March 3, 2015 Share Posted March 3, 2015 The fans only go on when the unit gets hot. A complex regulation circuit with teperature sensors controls the fan speed. Quote Link to comment Share on other sites More sharing options...
gp4leigh Posted March 3, 2015 Author Share Posted March 3, 2015 Yeah, I seem to remember unpacking the speakers from new, playing a few minutes on my keyboard running through them and noticing the fans were on? Thanks anyway, Leigh Quote Link to comment Share on other sites More sharing options...
gp4leigh Posted March 15, 2015 Author Share Posted March 15, 2015 Hi, Channel 1 on the mixer section of the L3t has stopped working? any suggestions where to get it fixed by a recommended service engineer in North Norfolk England? Thank you Leigh Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted March 16, 2015 Share Posted March 16, 2015 Call Line 6 Technical Support If your issue involves using a computer, to help us better assist you, please complete your support profile. The US support team can be reached at 818-575-3600 (option 2), Mon-Fri 8am - 5 pm PST. Our busiest hours are from 11am to 2 pm. The UK support team can be reached at +44 (0) 1788 566 555, Mon-Thurs 9am – 5pm GMT and Fri 9am – 4pm GMT. Quote Link to comment Share on other sites More sharing options...
