I NEED HELP! :(
SirRis
So I'm a bit new to this. Got my POD HD500X yesterday and been having fun with it.
Problem is I can't get the expression pedal to do swells! I'm using a classic distortion for sustain, reverb and a digi-delay but whenever I hit a note, turn the pedal to toe position, and turn it to heel position (for a new note to hit), the sound also cuts off and it's so frustrating coz I play in a church band. I want to be able to do swells seamlessly. :(
Is this normal? Is there any setting I should change to make the sound continuous? Any help is much appreciated!
Thanks!
Thank you guys for the feedback!
Where you do have the Vol in the effects setup?   It needs to be in front of the delay and Verb. Otherwise you cutting those off when you heel down.
Oh, I see! I have the Vol in the end of the signal chain! My bad. Could that be the reason? I'll try it then. Thanks, Mr!
Did you calibrate the pedal?
How to calibrate the POD HD500 Expression Pedal
http://line6.com/support/page/kb/_/pod/pod-hd500-hd500x/pod-hd500xhd500-pedal-calibration-r161?st=0#comment_0
Just a thought because you are as most of us were at first overwhelmed by the manual's instructions.
I have done the calibration and am pretty sure it is calibrated. Thanks, btw!
 That should fix it. Think about it. The vol is a like the volume knob on your guitar or amp. If I want the reverb trails and delayed notes to continue after you heel down, then you can't turn their volume off.
Got it. It made me feel so dumb. :( lol!
Thanks agaain, mate. Can I ask another question? :)
