biggreydog
Amplifi 2.1 iOS crash
I have an Amplify FX100.  I am using iOS 8.2 on my iPhone.  Whenever I open the Amplifi application, it quits before I have a chance to login.  I have also tried to bypass logging in but it still immediately quits after that.  I have rebooted my phone and deleted the app and redownloaded it.  It still crashes/quits.  Any advise appreciated.
I am having the same problem (AmpliFi app crashing) since upgrading to iOS 8.2. Problem occurs on iPad, iPhone 6, iPhone 5.
Have you tied forgetting the Bluetooth connection in settings before doing a fresh install of the app?
I have the same problem, with both iPhone 6 Plus and iPad Air 2 with iOS 8.2. App crashes consistently after about 10 seconds whether I am connected to AMPLIFI 75 via Bluetooth or not.
Here are all the troubleshooting steps I have tried:
- Uninstalled app, forget Bluetooth device, restart iDevice, reinstall app, reconnect via Bluetooth, restart app, crash.
- Connected amp via USB directly to Win7 PC, use AMPLIFI utility to reinstall 2.1 firmware, retry the steps above with the same result.
- Connected amp via USB directly to Win7 PC, use AMPLIFI utility to downgrade to 2.0 firmware, retry the steps above with the same result.
I'm out of ideas at this point.
I am having the same problem with my iPhone 6 Plus. At IOS 8.2 - App crashes after launch - phone shows it is running but it crashes whenever I try to use it.
Interestingly - I have an older iPad (iPad 2 - retina display) also at IOS 8.2 - Amplifi Remote works just fine with it - all aspects of the app are functional
On my phone I have tried the usual
Forget the Bluetooth connection
Uninstall the App and re-install
Reset Network
Cannot get Amplifi Remote to work with my phone
May be time to post a support ticket
same problem here, crashes on startup using iphone 6, ios 8.2.  tried all of the above troubleshooting with no luck.  the app works fine on my old iphone 4.
