slateboy
PC edits corrupted on transferring to pod
I have seen others on the forum with the same problem, with no solution, so bare with me or point me to the solution.
When making edits and creations in the PC editor the "send" button does not send the data to the pod entirely.
Double-clicking the preset (in editor) loads the sounds and visual representations as expected on pod and PC
However, attempting to save a preset from editor to pod by pressing the send button only sends half the info-
Visually the amp and effects appear to be stored on the pod but the sounds are from whatever was saved in that patch previously and have no reflection on the sound.
The only way to get the "new" preset is to power the pod on then off and then the preset appears AND sounds as expected/saved.
using pod HD500x with the designated editor
IIRC try using the save button on the HD itself.
-B
you have to press save on the pod itself. the patch is only "finalized" on the device when you disconnect the pod or exit the hd500 edit application
Thanks for the replies. I discovered this myself too.
However, i did notice that the "Send" works on the first time after powering up the pod.
I assume this "send" function is supposed to work as an alternative to "save" on the pod everytime?
