ickeauch 0 Posted April 2, 2015 i have two m5 in line. the relevant midi program change signal comes from my effect looper pedal and goes to the midi in of the first m5. the midi out from the first m5 goes to midi in of the second. when i step on the looper, the first m5 gets the signal and changes his preset. but the second m5 does nothing (because the program change message is not thru). here i want the second m5 to change his preset too. ( when i step the first m5 to change the preset, everything is fine, the second m5 reacts as expected and changes his preset too. it is also possible to make a sync tap on the fist m5 and the second m5 synchronizes ). to solve my problem, one idea is to use a thru box after the looper and then merge the signal from the loopers thru and the out of the first m5 into the second m5's in. but this solution costs between 140 and 300 euro. is there a cheaper or more simple way to do what i want to do? greez & thanx Quote Share this post Link to post Share on other sites
arturoastocondor 0 Posted August 26, 2016 No answers or help yet right?? Im with the same problem. Did you solved your problem? Quote Share this post Link to post Share on other sites
lucasramiro 0 Posted August 3, 2017 I'm Have the same problem. Any configuration on the M5 that sends the signal to the second? If you have "IN" and "OUT" would have to work .. Right ? Lucas Ramiro From Brazil. Any configuration on the M5 that sends the signal to the second? If you have "IN" and "OUT" would have to work .. Right ?: Quote Share this post Link to post Share on other sites
plumber 4 Posted January 12, 2018 Have you tried different midi channels for M5s? Quote Share this post Link to post Share on other sites
