Sign in to follow this
ickeauch
m5 midi power supply ?
midi power supply?
no... if i understand you correctly, there is no way to power the m5 over a midi cable.
hi guru, thanks for you answer.
but thats not exactly what i meant.
i don't need the power for the other m5 (this device needs much more power than a midi power supply can give).
normally the midi out of a keybard or a midi expander has a power supply with one of the pins of the midi connector.
that means that you can connect for example a midi thru or a midi merge box whithout extra power supply.
if you want to connect a midi merge box to an output which has not that feature, you have to buy one with extra power supply.
(normally this is much more expensive and i want  to save money)
Create an account
Register a new account
Sign in
Sign In Now
